rivahmon 2 #1 Posted May 29, 2025 Have replaced carb and also tried running on WD40 but it just cuts out immediately. 1 Share this post Link to post Share on other sites
pfrederi 20,874 #2 Posted May 29, 2025 Model number of tractor it is on may help.... Guessing you have a 520XI way to new for me but someone may be along that knows newer stuff Safety switch issue??? 1 Share this post Link to post Share on other sites
rivahmon 2 #3 Posted May 30, 2025 (edited) This on a 520Xi tractor. I'm trying help a friend remotely. I didn't think it would try to fire at all if there was a safety switch issue. CH20 is spec number 64583 dated 1998 and don't know which ignition system variant it is. Owner can't find model and serial number tag, where should it be located? Edited May 31, 2025 by rivahmon additional info 1 Share this post Link to post Share on other sites
953 nut 67,463 #4 Posted May 30, 2025 Second hand remote diagnosis, that can be challenging. If it is a unit that has the carburetor with a solenoid fuel **** off built into it I would take a look at the wiring going to it. Share this post Link to post Share on other sites
rivahmon 2 #5 Posted May 30, 2025 (edited) We're picking through the fuel system, but it should run on WD40 and does not stay running. Carb does have shutoff solenoid. Fuel pump (vacuum type) seems weak and just spurts so that's next, but I think ignition is suspect since it won't run on WD40. Not sure which variant ignition it has. Edited May 31, 2025 by rivahmon additional info Share this post Link to post Share on other sites
oliver2-44 11,632 #6 Posted May 30, 2025 19 hours ago, rivahmon said: tried running on WD40 but it just cuts out immediately. Just to understand, are you saying IT STARTS, then immediately dies? Or does it not start at all? Share this post Link to post Share on other sites
JoeM 10,099 #7 Posted May 31, 2025 Like 953 nuts said follow the Violet line. I have seen the F2 fuse get loose and have bad contact. just a thought. 18 hours ago, 953 nut said: If it is a unit that has the carburetor with a solenoid fuel **** off built into it I would take a look at the wiring going to it. 1 Share this post Link to post Share on other sites
rivahmon 2 #8 Posted May 31, 2025 15 hours ago, oliver2-44 said: Just to understand, are you saying IT STARTS, then immediately dies? Or does it not start at all? It starts and immediately dies. Share this post Link to post Share on other sites
rivahmon 2 #9 Posted May 31, 2025 3 hours ago, JoeM said: Like 953 nuts said follow the Violet line. I have seen the F2 fuse get loose and have bad contact. just a thought. That diagram is much better than I have found. What is it from? Share this post Link to post Share on other sites
JoeM 10,099 #10 Posted May 31, 2025 520xi and 522xi Electrical File Toro.pdf 6 minutes ago, rivahmon said: That diagram is much better than I have found. What is it from? Share this post Link to post Share on other sites
rivahmon 2 #11 Posted May 31, 2025 18 minutes ago, JoeM said: 520xi and 522xi Electrical File Toro.pdf 2.28 MB · 0 downloads Thanks so much. 1 Share this post Link to post Share on other sites
rivahmon 2 #12 Posted June 14, 2025 Turned out to be faulty ignition switch that had been replaced before. Chinese parts are not my favorite. Quote 1 Share this post Link to post Share on other sites
Wild Bill 633 936 #13 Posted June 14, 2025 9 hours ago, rivahmon said: Chinese parts are not my favorite. Confucius say, "How many more bad parts would you like to replace your bad one?" 1 Share this post Link to post Share on other sites
