Pullstart 68,403 #1 Posted May 29 I’m looking for bushings for Rylee’s 875, among maybe more machines we have that could use them. The local ACE has no such items. I even considered a shoulder bolt, but didn’t find anything close there either. Thoughts, ideas or suggested modifications are welcome to get this seat level again! thanks! 1 Share this post Link to post Share on other sites
ri702bill 10,265 #2 Posted May 29 Kevin - are those flanged bushings?? A sketch with ID, OD length, etc and material would be helpful.... 1 Share this post Link to post Share on other sites
WHX?? 53,079 #3 Posted May 29 You talkin where it pivots? 2 Share this post Link to post Share on other sites
squonk 44,741 #4 Posted May 29 I have redone my 875 with bushings from McMaster. Will get a pic later 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,776 #5 Posted May 29 Automotive door hinges often have flanged bronze or nylon bushings for the pin. Perhaps a body shop could help. From my GM experience. 4 Share this post Link to post Share on other sites
squonk 44,741 #6 Posted May 29 The fender pan was wallowed out. I found bushings that fit the shoulder bolts rear tunnel and drilled the fender pan to fit. 3 Share this post Link to post Share on other sites
Pullhosen’s Pony Express 97 #7 Posted May 29 I think I found what I needed “in stock”! @squonk I was actually looking for a K-181 flywheel for you. Found an engine with no flywheel but no go on the spinner… 1 Share this post Link to post Share on other sites
Achto 30,032 #8 Posted May 29 (edited) 6 hours ago, Pullstart said: Thoughts, ideas or suggested modifications are welcome to get this seat level again! Umm, you have a tool in your shop that spins things and allows you to cut them to make cylindrical parts any size you want. Just sayin' Edited May 29 by Achto 5 Share this post Link to post Share on other sites
SylvanLakeWH 29,509 #9 Posted May 29 26 minutes ago, Achto said: Umm, you have a tool in your shop that spins things and allows you to cut them to make cylindrical parts any size you want. Just sayin' 4 1 Share this post Link to post Share on other sites
ebinmaine 74,946 #10 Posted May 30 9 hours ago, Achto said: Umm, you have a tool in your shop that spins things and allows you to cut them to make cylindrical parts any size you want. Just sayin' Gotta be a corded hand drill.... 2 Share this post Link to post Share on other sites
squonk 44,741 #11 Posted May 30 1 hour ago, ebinmaine said: Gotta be a corded hand drill.... 1/2" metal case with the 2 big handles. 2 Share this post Link to post Share on other sites
