Pullstart 69,961 #1 Posted May 29, 2025 I’m looking for bushings for Rylee’s 875, among maybe more machines we have that could use them. The local ACE has no such items. I even considered a shoulder bolt, but didn’t find anything close there either. Thoughts, ideas or suggested modifications are welcome to get this seat level again! thanks! 1 Share this post Link to post Share on other sites
ri702bill 12,106 #2 Posted May 29, 2025 Kevin - are those flanged bushings?? A sketch with ID, OD length, etc and material would be helpful.... 1 Share this post Link to post Share on other sites
WHX?? 56,598 #3 Posted May 29, 2025 You talkin where it pivots? 2 Share this post Link to post Share on other sites
squonk 46,567 #4 Posted May 29, 2025 I have redone my 875 with bushings from McMaster. Will get a pic later 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #5 Posted May 29, 2025 Automotive door hinges often have flanged bronze or nylon bushings for the pin. Perhaps a body shop could help. From my GM experience. 4 Share this post Link to post Share on other sites
squonk 46,567 #6 Posted May 29, 2025 The fender pan was wallowed out. I found bushings that fit the shoulder bolts rear tunnel and drilled the fender pan to fit. 3 Share this post Link to post Share on other sites
Pullhosen’s Pony Express 98 #7 Posted May 29, 2025 I think I found what I needed “in stock”! @squonk I was actually looking for a K-181 flywheel for you. Found an engine with no flywheel but no go on the spinner… 1 Share this post Link to post Share on other sites
Achto 31,814 #8 Posted May 29, 2025 (edited) 6 hours ago, Pullstart said: Thoughts, ideas or suggested modifications are welcome to get this seat level again! Umm, you have a tool in your shop that spins things and allows you to cut them to make cylindrical parts any size you want. Just sayin' Edited May 29, 2025 by Achto 5 Share this post Link to post Share on other sites
SylvanLakeWH 31,423 #9 Posted May 29, 2025 26 minutes ago, Achto said: Umm, you have a tool in your shop that spins things and allows you to cut them to make cylindrical parts any size you want. Just sayin' 4 1 Share this post Link to post Share on other sites
ebinmaine 78,855 #10 Posted May 30, 2025 9 hours ago, Achto said: Umm, you have a tool in your shop that spins things and allows you to cut them to make cylindrical parts any size you want. Just sayin' Gotta be a corded hand drill.... 2 Share this post Link to post Share on other sites
squonk 46,567 #11 Posted May 30, 2025 1 hour ago, ebinmaine said: Gotta be a corded hand drill.... 1/2" metal case with the 2 big handles. 2 Share this post Link to post Share on other sites
