rmaynard 17,582 #1 Posted May 28, 2025 Short of replacing, is there a simple way to tightening a ball joint on a 701/702 #3940 steering link? I have gotten rid of most of the slop in my 701 steering, but I am left with loose ball joints. Any ideas would be appreciated. 1 Share this post Link to post Share on other sites
peter lena 10,070 #2 Posted May 28, 2025 @rmaynardhttps://www.google.com/search?q=wheel+horse+701+ball+joints&rlz=1C1CHBF_enUS866US866&oq=wheel+horse+701+ball+joints+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigATIHCAIQIRigATIHCAMQIRigATIHCAQQIRigATIHCAUQIRigATIHCAYQIRirAtIBCTE0NDMxajBqNKgCCLACAfEFlyard6NCxzI&sourceid=chrome&ie=UTF-8 this is easy , personally been using heim joints for years , just about bombproof , pete 1 Share this post Link to post Share on other sites
ri702bill 13,068 #3 Posted May 28, 2025 (edited) Bob - the real solution to to toss the OE parts & go with aftermarket Heim Joint assemblies. BUT - look at the 4 swage marks on the rod itself wrere the ball goes in. That metal was displaced in a press to capture the non-greaseable ball. You MAY be able to close up that retaining area a tad using a small punch or chisel and striking it with the BFH's Little Cousin. Work it bit by bit - you go too much, game over... All this does is buy you a bit more time to get a proper replacement (IHMO - even buying a NOS part is one and a half steps up from buying used toilet paper...) Edited May 28, 2025 by ri702bill 4 Share this post Link to post Share on other sites
Achto 32,729 #4 Posted May 28, 2025 2 hours ago, rmaynard said: Any ideas would be appreciated. I have peened the socket closed with a hammer to tighten up a few ball joints. Did this on my 855 to keep ball from falling out of the socket. 5 Share this post Link to post Share on other sites
Handy Don 17,474 #5 Posted May 28, 2025 14 minutes ago, ri702bill said: You MAY be able to close up that retaining area a tad using a small punch or chisel and striking it with the BFH's Little Cousin 7 minutes ago, Achto said: I have peened the socket closed with a hammer to tighten up a few ball joints. Did this on my 855 to keep ball from falling out of the socket. I’ve done this, too, but since I only run workers and dislike the idea of an unanticipated (and possibly dangerous) failure, it was as a temporary step before replacement 4 Share this post Link to post Share on other sites
Ed Kennell 47,371 #6 Posted May 28, 2025 I have successfully peened the socket closed around the balls. I also carried a plastic tie wrap for an emergency field repair. 6 Share this post Link to post Share on other sites
kpinnc 18,969 #7 Posted May 28, 2025 K&B sells repros that are very nice. They come painted and ready to go. I just put one on my 701. 5 1 Share this post Link to post Share on other sites
Wayne0 1,634 #8 Posted May 28, 2025 8 hours ago, rmaynard said: Short of replacing, is there a simple way to tightening a ball joint on a 701/702 #3940 steering link? I have gotten rid of most of the slop in my 701 steering, but I am left with loose ball joints. Any ideas would be appreciated. 2 Share this post Link to post Share on other sites
peter lena 10,070 #9 Posted May 29, 2025 @ Wayne0 . also like SUPER LUBE on those joints , just a drop , might also check out the rest of any movable points , like the vertical shaft gear base , bushing for sloppy set up . most of my WHEEL HORSE ANYTHING , problems has been FUNCTIONAL DETAILING , like snugging up a sloppy connection point , washers , etc . often refer to , roller stooling around , a problem spot with a helper moving that very area, showing you what it needs . have heims on my clutch rods , solid / smooth . the simplest change / addition , to movable areas has made the BIGGEST DIFFERENCE . plow frame and pto lever set up , are gold mine areas for , improvement . shoulder bolts , washers , elastic lock nuts , let you do a dial in a perfect , movement point , add a spring to a buzzing pto cone , connection clip , silence . experiment , pete Share this post Link to post Share on other sites
rmaynard 17,582 #10 Posted June 15, 2025 Finally decided to make a new one. Problem solved. 2 5 Share this post Link to post Share on other sites
Lee1977 7,774 #11 Posted June 15, 2025 (edited) On 5/28/2025 at 7:32 PM, Wayne0 said: It don't get and better then this. I put brass lined heims joints on my C-120 in 1989 they are still tight. I used 1/2" heims joint and bushed them down to 3/8" to fit in the original holes on the triangle and spindle arms. When I got my 520-H in 2019 I used the two from the spindles on my C-120 for the triangle of my 1989 520-H for the triangle on it. I had bought the new 1/2" heims joints with 1/2" stud installed. the spindle arms I drilled out and tapped for the fine tread studs on bothe tractors and also used 1/2" jam nuts on the arms. There is still no loose play in the tierods. Here is the set I put on the 520-H, they may have cost a few dollars more, but they are worth it. Edited June 15, 2025 by Lee1977 3 Share this post Link to post Share on other sites
rmaynard 17,582 #12 Posted June 15, 2025 34 minutes ago, Lee1977 said: It don't get and better then this. Except that won't work on the 701 type steering which has a flat non-adjustable tie-rod bar and a non-adjustable drag link as shown below. Share this post Link to post Share on other sites
Lee1977 7,774 #13 Posted June 15, 2025 If you can use a ball joint , you can used a heims joint. They come in the size you need. You can used what ever you like, just point out a better way. 1 Share this post Link to post Share on other sites
