Tonytoro416 1,387 #1 Posted May 27, 2025 Still in the process of restoring grandpas 953 and PO before grandpa had removed fuel tank from under the seat. I was able to source tank,straps and blocks but I don’t know where the straps actually bolt to. Any help and or pictures would help but I know pictures would be hard to get Share this post Link to post Share on other sites
Achto 32,750 #2 Posted May 27, 2025 1 hour ago, Tonytoro416 said: I was able to source tank,straps and blocks but I don’t know where the straps actually bolt to. There are 2 holes in the rear tool box and 2 holes under the seat. Do you have the wooden spacer blocks that go above the tank? 1 1 Share this post Link to post Share on other sites
WHX?? 58,156 #3 Posted May 27, 2025 1 hour ago, Tonytoro416 said: was able to source tank,straps and blocks 4 minutes ago, Achto said: have the wooden spacer blocks Said he did ... I can get pics tomorrow of a 1054 ... dark out and I is afraid of the dark ... 1 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,387 #4 Posted May 27, 2025 I would appreciate it. Thanks so much. I had to make the whole toolbox area because it was rotted so I’d say I’ll have to drill holes. 2 Share this post Link to post Share on other sites
oliver2-44 11,753 #5 Posted May 27, 2025 @Tonytoro416 Would love to see a thread of you rebuild/restore on this tractor. 1 Share this post Link to post Share on other sites
Ed Kennell 47,375 #6 Posted May 27, 2025 11 hours ago, Tonytoro416 said: I had to make the whole toolbox area Did you make it removable so you could install the fuel tank? Share this post Link to post Share on other sites
WHX?? 58,156 #7 Posted May 27, 2025 (edited) You get the holes close you be alright. Edited May 27, 2025 by WHX?? Share this post Link to post Share on other sites
WHX?? 58,156 #8 Posted May 27, 2025 Bottom of the tool box 2 inches up. Front of seat pan pic Share this post Link to post Share on other sites
WHX?? 58,156 #9 Posted May 27, 2025 Drill some holes in the bottom of the tool box for drain holes. Dan coated his with bed liner I think. 2 Share this post Link to post Share on other sites
Tonytoro416 1,387 #10 Posted May 28, 2025 You guys are absolutely awesome. I never expected such detail. I’ll definitely be able to get mine dialed right in thanks to you guys 3 Share this post Link to post Share on other sites
