Racinbob 11,989 #1 Posted May 21 It seems like I've had even less time to work on Dino now that nice weather has arrived but that's the case. Just an iddy-bitty update to prove I'm still on it as time allows. I made the replacement seat spring bumpers using table leg thingys. Heated in boiling water and press fit then trimmed down. Before trimmimg. I received the new decal set from Terry. I thought about the American series or carbon fiber but decided on the timeless original. I just had to see the fender pan covering the 10.50's. I got the PTO and drive linkages hooked up. I'll say again that this style steering tower sure makes things tougher to get at. I still need to get the main tins sprayed. Hopefully I'll get the final sanding on them done tomorrow and while I wait for a good day to spray I'll attack the fuel lines and rewire. Both quick jobs. I think I'll mount the electric fuel pump directly under the tank. 10 1 Share this post Link to post Share on other sites
WHX?? 51,910 #2 Posted May 21 Lookin really sweet Bob ... 1 Share this post Link to post Share on other sites
stevasaurus 23,303 #3 Posted May 21 Holy Cow Bob !!! That is just beautiful !!! For once, I am speech less.......... 1 3 Share this post Link to post Share on other sites
Racinbob 11,989 #4 Posted May 21 Thanks guys. It's got it's flaws but I originally intended to do a mechanical go thru and a quick makeover. Things just got out of control. I'm just hoping I can get the sheet metal to come out good. I'm still a HVLP newbie. The thought crossed my mind to go rattle can cuz I know I can make that look primo but dang it, I want hardener in it. 1 Share this post Link to post Share on other sites
peter lena 9,309 #5 Posted May 21 @Racinbob sweet looking piece there bob ! https://www.google.com/search?q=bolt+on+seat+springs&rlz=1C1CHBF_enUS866US866&oq=bolt+on+seat+springs&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yCAgCEAAYFhgeMg0IAxAAGIYDGIAEGIoFMgcIBBAAGO8FMgoIBRAAGIAEGKIEMgcIBhAAGO8FMgoIBxAAGIAEGKIE0gEJMTI4NTZqMWo0qAIIsAIB8QXgKpXif6gClg&sourceid=chrome&ie=UTF-8 have different versions of these on my horses , found them to be a great seat additive . very easy to install , pete 1 Share this post Link to post Share on other sites
JoeM 8,433 #6 Posted May 22 Nice looking job you got there Bob! Agree, the paint with hardener is way better! Figure you might want to hide the pump in the back but I mounted one next to the engine and piped the outlet, worked good and picked up power at the the coil connection. Just sharing. 5 Share this post Link to post Share on other sites
WHX?? 51,910 #7 Posted May 22 You got solid mounts on that one Joe? We were just yakking about them. Share this post Link to post Share on other sites
JoeM 8,433 #8 Posted May 22 (edited) 10 hours ago, WHX?? said: You got solid mounts on that one Joe? In the pic they are not on yet, I brew my own using 1/2 x 1 1/2 flat bar. (frugal they say) And there is a chuck of rubber line from the gas tube to the carb for vibratory purposes. Edited May 22 by JoeM 2 Share this post Link to post Share on other sites
Racinbob 11,989 #9 Posted May 22 1 hour ago, JoeM said: In the pic they are not on yet, I brew my own using 1/2 x 1 1/2 flat bar. (frugal they say) And there is a chuck of rubber line from the gas tube to the carb for vibratory purposes. Perzackly what I did. Actually 1/4" x 2. It's what I had lying around. 1 2 Share this post Link to post Share on other sites
peter lena 9,309 #10 Posted May 22 @Racinbob often refer to a frame length 5/16 steel brake line , tucked up into the inner frame corner bend , perfect holding / hiding spot , benefits ? eliminate a long run of fuel hose breakdown , only have tank to line and carb to line , filtered connections , used a barb and swage tube connection at transition points , had also verified fuel cleaning ,at tank to carb bowl , think about it , anything related to fuel hose breakdown was clean / clear , add STA BIL ounce or two to all my tank top offs , never had any return of fuel hose break down at any filter area , often refer to a chronic / repetitive problem as a perfect spot for change . have this in use for years , no rubber break down in my 3 tractor set ups at all . realise this is a contentious issue , my generator sits for months , and starts instantly , no fuel filter debris at all , what is the filter telling you ? also like , bolt on electrical lugs for ground issues , thanks for the photo tour , pete Share this post Link to post Share on other sites
stvski80085 244 #11 Posted May 22 Looks great! I hope mine turns out like that when I start the restore. Steve Share this post Link to post Share on other sites
