Racinbob 12,812 #1 Posted May 21, 2025 It seems like I've had even less time to work on Dino now that nice weather has arrived but that's the case. Just an iddy-bitty update to prove I'm still on it as time allows. I made the replacement seat spring bumpers using table leg thingys. Heated in boiling water and press fit then trimmed down. Before trimmimg. I received the new decal set from Terry. I thought about the American series or carbon fiber but decided on the timeless original. I just had to see the fender pan covering the 10.50's. I got the PTO and drive linkages hooked up. I'll say again that this style steering tower sure makes things tougher to get at. I still need to get the main tins sprayed. Hopefully I'll get the final sanding on them done tomorrow and while I wait for a good day to spray I'll attack the fuel lines and rewire. Both quick jobs. I think I'll mount the electric fuel pump directly under the tank. 10 1 Share this post Link to post Share on other sites
WHX?? 55,340 #2 Posted May 21, 2025 Lookin really sweet Bob ... 1 Share this post Link to post Share on other sites
stevasaurus 23,627 #3 Posted May 21, 2025 Holy Cow Bob !!! That is just beautiful !!! For once, I am speech less.......... 1 3 Share this post Link to post Share on other sites
Racinbob 12,812 #4 Posted May 21, 2025 Thanks guys. It's got it's flaws but I originally intended to do a mechanical go thru and a quick makeover. Things just got out of control. I'm just hoping I can get the sheet metal to come out good. I'm still a HVLP newbie. The thought crossed my mind to go rattle can cuz I know I can make that look primo but dang it, I want hardener in it. 1 Share this post Link to post Share on other sites
peter lena 9,785 #5 Posted May 21, 2025 @Racinbob sweet looking piece there bob ! https://www.google.com/search?q=bolt+on+seat+springs&rlz=1C1CHBF_enUS866US866&oq=bolt+on+seat+springs&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yCAgCEAAYFhgeMg0IAxAAGIYDGIAEGIoFMgcIBBAAGO8FMgoIBRAAGIAEGKIEMgcIBhAAGO8FMgoIBxAAGIAEGKIE0gEJMTI4NTZqMWo0qAIIsAIB8QXgKpXif6gClg&sourceid=chrome&ie=UTF-8 have different versions of these on my horses , found them to be a great seat additive . very easy to install , pete 1 Share this post Link to post Share on other sites
JoeM 9,650 #6 Posted May 22, 2025 Nice looking job you got there Bob! Agree, the paint with hardener is way better! Figure you might want to hide the pump in the back but I mounted one next to the engine and piped the outlet, worked good and picked up power at the the coil connection. Just sharing. 5 Share this post Link to post Share on other sites
WHX?? 55,340 #7 Posted May 22, 2025 You got solid mounts on that one Joe? We were just yakking about them. Share this post Link to post Share on other sites
JoeM 9,650 #8 Posted May 22, 2025 (edited) 10 hours ago, WHX?? said: You got solid mounts on that one Joe? In the pic they are not on yet, I brew my own using 1/2 x 1 1/2 flat bar. (frugal they say) And there is a chuck of rubber line from the gas tube to the carb for vibratory purposes. Edited May 22, 2025 by JoeM 2 Share this post Link to post Share on other sites
Racinbob 12,812 #9 Posted May 22, 2025 1 hour ago, JoeM said: In the pic they are not on yet, I brew my own using 1/2 x 1 1/2 flat bar. (frugal they say) And there is a chuck of rubber line from the gas tube to the carb for vibratory purposes. Perzackly what I did. Actually 1/4" x 2. It's what I had lying around. 1 2 Share this post Link to post Share on other sites
peter lena 9,785 #10 Posted May 22, 2025 @Racinbob often refer to a frame length 5/16 steel brake line , tucked up into the inner frame corner bend , perfect holding / hiding spot , benefits ? eliminate a long run of fuel hose breakdown , only have tank to line and carb to line , filtered connections , used a barb and swage tube connection at transition points , had also verified fuel cleaning ,at tank to carb bowl , think about it , anything related to fuel hose breakdown was clean / clear , add STA BIL ounce or two to all my tank top offs , never had any return of fuel hose break down at any filter area , often refer to a chronic / repetitive problem as a perfect spot for change . have this in use for years , no rubber break down in my 3 tractor set ups at all . realise this is a contentious issue , my generator sits for months , and starts instantly , no fuel filter debris at all , what is the filter telling you ? also like , bolt on electrical lugs for ground issues , thanks for the photo tour , pete Share this post Link to post Share on other sites
stvski80085 279 #11 Posted May 22, 2025 Looks great! I hope mine turns out like that when I start the restore. Steve Share this post Link to post Share on other sites
