Jwright3190 15 #1 Posted May 10, 2025 I rebuilt my carb, new fuel lines and new fuel filter last year. The year before I replaced the fuel pump. After I use my mower for about 15-20 minutes it runs out of fuel. The fuel filter is empty. If I let it sit for about a half hour it will fire right up and do it again. I’m leaning towards the cheap Amazon pump I bought. I thought about installing an electric pump but I don’t understand how it dont over fill the carb. Share this post Link to post Share on other sites
Lagersolut 802 #2 Posted May 10, 2025 47 minutes ago, Jwright3190 said: I rebuilt my carb, new fuel lines and new fuel filter last year. The year before I replaced the fuel pump. After I use my mower for about 15-20 minutes it runs out of fuel. The fuel filter is empty. If I let it sit for about a half hour it will fire right up and do it again. I’m leaning towards the cheap Amazon pump I bought. I thought about installing an electric pump but I don’t understand how it dont over fill the carb. Did you check or replace the fuel shut off at the tank ? They have a fine mesh screen inside the tank - your problem sounds more like a clogged screen or a bad fuel cap not venting . 1 1 Share this post Link to post Share on other sites
Jwright3190 15 #3 Posted May 10, 2025 2 hours ago, Lagersolut said: Did you check or replace the fuel shut off at the tank ? They have a fine mesh screen inside the tank - your problem sounds more like a clogged screen or a bad fuel cap not venting . I will check both tomorrow! Thank you! Share this post Link to post Share on other sites
Ed Kennell 47,374 #4 Posted May 10, 2025 9 hours ago, Lagersolut said: a bad fuel cap Yeah that, just loosen the cap and try it. 1 Share this post Link to post Share on other sites
953 nut 69,359 #5 Posted May 10, 2025 9 hours ago, Lagersolut said: bad fuel cap not venting . As fuel is removed from the tank a slight vacuum will be created if the tank isn't vented. The more fuel is used the greater the vacuum until it reaches the point where the fuel pump can no longer overcome it, then everything stops. 1 1 Share this post Link to post Share on other sites
peter lena 10,070 #6 Posted May 10, 2025 @Jwright3190https://www.amazon.com/CarBole-Universal-2-3-5P-S-I-Operating-Self- have a couple of these in use for years , this is the TYPE YOU WANT , NOT the , fuel filter looking one , very solid , low pressure its self regulating , ignition switch hook up , don.t worry about carb , not an issue , have this on my ignition switch , when you go to start , its on , added a single LED green bulb to my dash , to verify operation . check out tank for debris , typically ethanol gas eats rubber hose , two choices , buy ethanol free gas or add a STA BIL fuel storage to your gas , to stop hose break down , would also recommend , replacing existing gas line , in line fuel filters will show you what's going on , one close to tank the other close to carb . agree with @Lagersolut verify tank venting , we have all delft with this issue , its a learning experience , personal experience has been , fault free . pete 1 Share this post Link to post Share on other sites
Jwright3190 15 #7 Posted May 10, 2025 Cleaned my gas cap with degreaser. It ran for over an hour with no problem! Seems like that was it! Thank you everyone for the help! 1 2 Share this post Link to post Share on other sites
Ed Kennell 47,374 #8 Posted May 10, 2025 (edited) 15 hours ago, Jwright3190 said: . I thought about installing an electric pump but I don’t understand how it dont over fill the carb. The float activated halve in the bowl is what controls the fuel in the carb. Actually, all the fuel pumps pulse, mechanical, and electric run all the time. The electrics can be controlled with an on/off switch and some of them will turn off with an internal pressure switch. The real advantage of the electrics is they start pumping when you turn the switch on. No need to crank the engine to pump fuel to the carb. This is a real advantage with the tractors that have the fuel tank located under the seat. With time the fuel leaks back to the tank and the pump loses its prime requiring a long crank time to get the fuel back to the carb. The electric pump should be located below the fuel tank so it never loses prime. Edited May 10, 2025 by Ed Kennell 2 2 Share this post Link to post Share on other sites
