Toolmanbill 44 #1 Posted May 9, 2025 Have a 1994 314-8 from 1994 that needs new tires.it has 23x9.5x12 turf tires that are original equipment.would like to get tires that have a more aggressive tread but won’t tear up any lawn.the only tires that I can find in this size are all turf tires.there seem to be many in 23x10.5x12 but there doesn’t seem to be enough clearance especially if I want to put chains on for plowing.owned this tractor for 30+years and recently fell off mowing the sand mound hill.glad I still had the kill seat switch working.will ag tires tear up the lawn?the size available for ag tires are 23x8.5x12.any advice would be appreciated. Thanks. Share this post Link to post Share on other sites
pfrederi 21,151 #2 Posted May 9, 2025 There is proabably more size variance between between tire manufacturers than a one step change in tire size. (8.5 to 9.5 for instance) Deestones are notoriously smaller than Carlilse even though they are marked the same size...WH used 8.50 for many years on C series and older... 1 Share this post Link to post Share on other sites
peter lena 10,070 #3 Posted May 9, 2025 @Toolmanbill not having any tire issues , but have been using a light silicone grease on the entire bead sealing area , started doing that with a very slow leaking tire , was just a slight rubber fit to wheel issue, than a solid over pressure sealing slam , obvious wheel rust debris , preventing seal . pete Share this post Link to post Share on other sites
Sparky-(Admin) 26,373 #4 Posted May 9, 2025 I always recommend these when asked. Carlisle All-Trails, although the company name has changed to Carlstar now. When I picked up these they only came in 23x10.5 and 23x8.0, not sure if that’s still the case. The 8.0’s are mounted on standard width wheels and my 10.5’s are on wide wheels like the 520-H’s come with. I can’t explain the height diff. 3 1 Share this post Link to post Share on other sites
Chaz54 102 #5 Posted May 9, 2025 I switched to these - they are golf cart tires mounted on 8.5” wide rims. I don’t even need chains when I plow snow. Wanda 23x10.5-12 All Terrain Golf Cart Tires - Golf Cart Tire Supply.pdf 4 Share this post Link to post Share on other sites
kpinnc 18,969 #6 Posted May 9, 2025 (edited) 2 hours ago, Sparky said: I always recommend these when asked. Carlisle All-Trails, 23x8.00-12 on mine. Edited May 9, 2025 by kpinnc Share this post Link to post Share on other sites
Tonytoro416 1,387 #7 Posted May 9, 2025 2 hours ago, Chaz54 said: I switched to these - they are golf cart tires mounted on 8.5” wide rims. I don’t even need chains when I plow snow. Wanda 23x10.5-12 All Terrain Golf Cart Tires - Golf Cart Tire Supply.pdf 3.18 MB · 2 downloads Same tires I have in my 416. Pretty impressed. Doesn’t tear up grass either that I have noticed Share this post Link to post Share on other sites
JoeM 10,269 #8 Posted May 9, 2025 7 hours ago, Chaz54 said: I don’t even need chains when I plow snow. Same here, I have them on my FEL, I liked them of much I put them on my grass mower too. Share this post Link to post Share on other sites
ineedanother 2,866 #9 Posted May 9, 2025 10 hours ago, Toolmanbill said: .would like to get tires that have a more aggressive tread but won’t tear up any lawn. It's a bit ironic and maybe even counterintuitive but in my experience, aggressive tread doesn't really tear up turf, tires that lose traction do. 2 Share this post Link to post Share on other sites
kpinnc 18,969 #10 Posted May 10, 2025 2 hours ago, ineedanother said: It's a bit ironic and maybe even counterintuitive but in my experience, aggressive tread doesn't really tear up turf, tires that lose traction do. More aggressive tread of course tends to grip better. Turfs in most flavors will spin easily. But if you spin with knobby tires it will dig a hole quick! 2 Share this post Link to post Share on other sites
Toolmanbill 44 #11 Posted May 10, 2025 Can’t seem to find these calstar tires.any links known? Share this post Link to post Share on other sites
Sparky-(Admin) 26,373 #12 Posted May 10, 2025 (edited) 4 hours ago, Toolmanbill said: Can’t seem to find these calstar tires.any links known? Having an issue posting links for some reason. Try searching Carlisle All Trail 23x8 instead of Carlstar. https://www.tires-easy.com/tires/?filtering=carlisle all trail 23x8,relevance Edited May 10, 2025 by nylyon Added link Share this post Link to post Share on other sites
Handy Don 17,474 #13 Posted May 10, 2025 It’s a subtle but important note that the contact patch of a tire can affect the quality of the lawn. Turfs distribute the load to lessen the soil compaction. Ags, by design, concentrate the load on a smaller area. EVERY style of tire embodies a series of compromises aimed at getting the best overall result for its design goals. 3 Share this post Link to post Share on other sites
Lee1977 7,773 #14 Posted May 11, 2025 (edited) I found 5 similar tread tires in 23 x 10.50 x 12. Vision at Summit Racing Duro Tire at eBay Ocelot at Amazon CTW Predator at eBay Wanda at Golf Cart Tire Supply I have Carlisle All Trails II 25 x 900 x 12 on my 316-8, but I did raise the rear fender 1 3/4". Edited May 11, 2025 by Lee1977 1 Share this post Link to post Share on other sites
Toolmanbill 44 #15 Posted May 12, 2025 Seems as though there is only one inch of clearance between the edge of my 9.5 inch tires and the tractor.I think thats too close to use 10.5 tires if I need to use chains.will I be compromising traction if I use 8 inch tires?carlisle only seem to come 8 inch or 10.5. Share this post Link to post Share on other sites
Toolmanbill 44 #16 Posted May 12, 2025 Also do you guys also put tubes in? Share this post Link to post Share on other sites
Tonytoro416 1,387 #17 Posted May 12, 2025 Mine are tubeless and don’t run tubes unless they have to be. I don’t run my tractors in any terrain that I need to worry about tubes Share this post Link to post Share on other sites
Lee1977 7,773 #18 Posted May 12, 2025 Here is the difference between tubeless and tubed. These wheels came off my 520-H in 2019. I replaces the tires after I bought it, the clean rim was tubeless. and the rusty one had a tube. Don't know how long the tube was in there. Share this post Link to post Share on other sites
Toolmanbill 44 #19 Posted May 12, 2025 does anyone have clearance issues using 10.5 tires on a 314-8?would still like to be able to use chains.I have a nasty gravel driveway about 700 feet long with a hill and a 90 dagree turn. Share this post Link to post Share on other sites
pfrederi 21,151 #20 Posted May 12, 2025 I run rubber chains on 10.50 on a Charger 12 no clearance issues. However if your drive way is gravel and sloped I would suggest you get some 6.00 x 12 tires (on the 5.inch rims) add 2 link v chains and weights for winter use. This set up pushes a 56" blade and will drag a M16 down in heavy snow before I lose traction. 2 Share this post Link to post Share on other sites
ineedanother 2,866 #21 Posted May 12, 2025 5 hours ago, Lee1977 said: Here is the difference between tubeless and tubed. These wheels came off my 520-H in 2019. I replaces the tires after I bought it, the clean rim was tubeless. and the rusty one had a tube. Don't know how long the tube was in there. I would have guessed just the opposite thinking that any moisture out of a compressor would be contained by the tube rather than rusting the rim. Share this post Link to post Share on other sites
Lee1977 7,773 #22 Posted May 12, 2025 I've change a lot of tires with tubes that the rust had the tube attached to the rim. The tubes don't seal out moisture at the stem. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #23 Posted May 13, 2025 2 hours ago, ineedanother said: I would have guessed just the opposite thinking that any moisture out of a compressor would be contained by the tube rather than rusting the rim. The moisture enters via the less-than-tight seal around the inflation valve. Rain, washing, etc. 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,373 #24 Posted May 13, 2025 6 hours ago, Toolmanbill said: does anyone have clearance issues using 10.5 tires on a 314-8?would still like to be able to use chains.I have a nasty gravel driveway about 700 feet long with a hill and a 90 dagree turn. I don’t run chains on my 23x10.5’s, so I can’t answer that. Currently I’m about 2500 miles away from home, I’ll try to remember to take a look and a pic of my tires and the clearance when I get back home Friday. Share this post Link to post Share on other sites
Gabe 32 #25 Posted May 13, 2025 On 5/9/2025 at 9:38 AM, Chaz54 said: I switched to these - they are golf cart tires mounted on 8.5” wide rims. I don’t even need chains when I plow snow. Wanda 23x10.5-12 All Terrain Golf Cart Tires - Golf Cart Tire Supply.pdf 3.18 MB · 6 downloads Share this post Link to post Share on other sites
