1968Commando 171 #1 Posted May 8, 2025 Hello all just wanting some input I am soooo close to wiring my tractor and want to know how yall do it, this tractor is a 1968 commando 8 and I am adding a solenoid I was curious as to how yall did it, did you heat shrink the connections or just krimp them, did you reuse some old wires or just start from nothing, when adding a solenoid how do I get my generator light to still work? Share this post Link to post Share on other sites
1968Commando 171 #3 Posted May 8, 2025 3 minutes ago, squonk said: Ok thank you, do you crimp your wires and leave if be or do you heat shrink them as well? Share this post Link to post Share on other sites
1968Commando 171 #4 Posted May 8, 2025 (edited) 10 minutes ago, squonk said: Also when wiring in my starter gen light I have the 5 post switch that you slide connectors over how would I add the generator light wire to the ignition spade when there is already somthing on that Edited May 8, 2025 by 1968Commando Share this post Link to post Share on other sites
8ntruck 8,701 #5 Posted May 8, 2025 Morton, Illinois. That the home of Morton Buildings? Heat shrink is a good idea. It gives the wire more support and adds some water resistance to the joint. @ebinmaine buys 7 conductor trailer wiring harness cable for his tractor wiring harnesses. He breaks it down Iinto separate wires to build the harness. Turns out to be less expensive than buying the different colors and sizes of wire separately. I used this method to rewire my 1948 8N last fall. Worked well. 2 Share this post Link to post Share on other sites
1968Commando 171 #6 Posted May 8, 2025 7 minutes ago, 8ntruck said: Morton, Illinois. That the home of Morton Buildings? Heat shrink is a good idea. It gives the wire more support and adds some water resistance to the joint. @ebinmaine buys 7 conductor trailer wiring harness cable for his tractor wiring harnesses. He breaks it down Iinto separate wires to build the harness. Turns out to be less expensive than buying the different colors and sizes of wire separately. I used this method to rewire my 1948 8N last fall. Worked well. Oh well I just bought some blue wire I forgot what gauge it is, I have 6 guards for battery cables and stuff but the points and coil wires will be the blue stuff,yes Morton Illinois is were Morton building was founded it’s a huge part of our town as well as Libby’s pumpkin is made here we are the pumpkin capital of the world Share this post Link to post Share on other sites
ebinmaine 77,976 #7 Posted May 8, 2025 21 minutes ago, 8ntruck said: Heat shrink is a good idea. It gives the wire more support and adds some water resistance to the joint. @ebinmaine buys 7 conductor trailer wiring harness cable for his tractor wiring harnesses. He breaks it down Iinto separate wires to build the harness. Turns out to be less expensive than buying the different colors and sizes of wire separately 46 minutes ago, 1968Commando said: reuse some old wires If the wires themselves and more to the point, the casing, are okay... there really is nothing wrong with reusing them. As a lot of you guys know, I am not prone to doing that anymore. I do not build restoration projects. Trina and I have workers. We are looking for dependability and ease of maintenance. To that end, I absolutely do not recommend using a blue wire for either positive or negative, and I also recommend using different color wires for different circuits. Definitely heat shrink and weather seal your connections. That won't matter at all for 3 to 5 years but when the corrosion comes back to haunt you, it will be thorough. And tough to find. Share this post Link to post Share on other sites
1968Commando 171 #8 Posted May 8, 2025 3 minutes ago, ebinmaine said: To that end, I absolutely do not recommend using a blue wire for either positive or negative, and I also recommend using different color wires for different circuits. So..I shouldn’t use the blue wire for wiring the headlights and the points coil and then grounding the solenoid I should use different color for everything? 1 Share this post Link to post Share on other sites
squonk 45,899 #9 Posted May 8, 2025 38 minutes ago, 1968Commando said: Also when wiring in my starter gen light I have the 5 post switch that you slide connectors over how would I add the generator light wire to the ignition spade when there is already somthing on that Double spade terminal. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,976 #10 Posted May 8, 2025 1 minute ago, 1968Commando said: So..I shouldn’t use the blue wire for wiring the headlights and the points coil and then grounding the solenoid I should use different color for everything? You CAN use it..... I just WOULDN'T use it. Part of that is because I'm kind of particular about the way that I wire things. But part of that is because if you ever come back to fix something, you may regret having all the wires the same color. When I rewire a tractor I put a ground circuit to every component. You don't have excessive ground circuits until the harness starts to look like black spaghetti. I try to make different components have different positive colors as well. I don't necessarily have a super strict adhesion to a system there but usually yellow or orange would be for lighting. Red would be for coil. Or generator. Nothing at all wrong with mixing it up and making it your own but make sure when you come back to mess with it a few years later, you can. Share this post Link to post Share on other sites
1968Commando 171 #11 Posted May 8, 2025 9 minutes ago, squonk said: Double spade terminal. Holy crap didn’t even know that was a thing Share this post Link to post Share on other sites
1968Commando 171 #12 Posted May 8, 2025 57 minutes ago, ebinmaine said: You CAN use it..... I just WOULDN'T use it. Part of that is because I'm kind of particular about the way that I wire things. But part of that is because if you ever come back to fix something, you may regret having all the wires the same color. When I rewire a tractor I put a ground circuit to every component. You don't have excessive ground circuits until the harness starts to look like black spaghetti. I try to make different components have different positive colors as well. I don't necessarily have a super strict adhesion to a system there but usually yellow or orange would be for lighting. Red would be for coil. Or generator. Nothing at all wrong with mixing it up and making it your own but make sure when you come back to mess with it a few years later, you can. Ok well for cost reasons I think I’ll just wire it all up with the blue 1 Share this post Link to post Share on other sites
Handy Don 16,112 #13 Posted May 8, 2025 (edited) During my career designing business systems, I observed that pretty much no project EVER had a “Phase 2”. Hence, I pushed back strongly whenever someone suggested a feature or capability could be added in Phase 2--my response was “Be real--if it isn’t in phase one it isn’t going to happen". As Yoda said, "Do or do not. There is no try”. I don’t personally care about the specific colors, but it you want to save yourself a LOT of future troubleshooting grief, bite the bullet and keep all the grounds in one color and all the “hots” in other colors. Alternatively, buy a set of durable wire number labels. Then make a list of what you did so you’ll be able to find when you need it. Edited May 8, 2025 by Handy Don 2 1 Share this post Link to post Share on other sites
ebinmaine 77,976 #14 Posted May 8, 2025 1 hour ago, 1968Commando said: Ok well for cost reasons I think I’ll just wire it all up with the blue 14 minutes ago, Handy Don said: During my career designing business systems, I observed that pretty much no project EVER had a “Phase 2”. Hence, I pushed back strongly whenever someone suggested a feature or capability could be added in Phase 2--my response was “Be real--if it isn’t in phase one it isn’t going to happen". As Yoda said, "Do or do not. There is no try”. I don’t personally care about the specific colors, but it you want to save yourself a LOT of future troubleshooting grief, bite the bullet and keep all the grounds in one color and all the “hots” in other colors. Alternatively, buy a set of durable wire number labels. Then make a list of what you did so you’ll be able to find when you need it. Seconded 1 Share this post Link to post Share on other sites
ebinmaine 77,976 #15 Posted May 8, 2025 @1968Commando You PM me with your address. I'll send you three or four feet of this trailer wire harness. No charge. 1 Share this post Link to post Share on other sites
1968Commando 171 #16 Posted May 8, 2025 1 hour ago, Handy Don said: During my career designing business systems, I observed that pretty much no project EVER had a “Phase 2”. Hence, I pushed back strongly whenever someone suggested a feature or capability could be added in Phase 2--my response was “Be real--if it isn’t in phase one it isn’t going to happen". As Yoda said, "Do or do not. There is no try”. I don’t personally care about the specific colors, but it you want to save yourself a LOT of future troubleshooting grief, bite the bullet and keep all the grounds in one color and all the “hots” in other colors. Alternatively, buy a set of durable wire number labels. Then make a list of what you did so you’ll be able to find when you need it. Ok well I do have a short spool of red wire not sure what gauge but I’ll look I have a full spool of blue wire I think it’s 18 gauge and then my battery cables are 6 gauge and there red so I think I’ll just see I do work at a car shop after school so they might have some wire sitting around somewhere I will also check what gauge I got at home I think it’s 18 or somthing close to that I assume 1 Share this post Link to post Share on other sites
1968Commando 171 #17 Posted May 8, 2025 1 hour ago, ebinmaine said: @1968Commando You PM me with your address. I'll send you three or four feet of this trailer wire harness. No charge. Thanks but I think I will pass but thank you for the offer 1 1 Share this post Link to post Share on other sites
ebinmaine 77,976 #18 Posted May 8, 2025 12 minutes ago, 1968Commando said: Ok well I do have a short spool of red wire not sure what gauge but I’ll look I have a full spool of blue wire I think it’s 18 gauge and then my battery cables are 6 gauge and there red so I think I’ll just see I do work at a car shop after school so they might have some wire sitting around somewhere I will also check what gauge I got at home I think it’s 18 or somthing close to that I assume You might want to check the specs. I think most of the wire wants to be 14 gauge but the one that goes to the coil could be 12. Battery wires, 6 is fine Share this post Link to post Share on other sites
squonk 45,899 #19 Posted May 8, 2025 (edited) 6 hours ago, 1968Commando said: 14Ga. is fine for everything on a Horse cept the bat cables Edited May 8, 2025 by squonk 3 Share this post Link to post Share on other sites
1968Commando 171 #20 Posted May 8, 2025 1 hour ago, squonk said: 14Ga. is fine for everything on a Horse cept the bat cables Well shoot if I used 18 would it be dangerous or like risk of fire or would I be ok? Share this post Link to post Share on other sites
squonk 45,899 #21 Posted May 8, 2025 I wouldn't go any smaller than 16 2 Share this post Link to post Share on other sites
1968Commando 171 #22 Posted May 8, 2025 Just now, squonk said: I wouldn't go any smaller than 16 Wellllllll crap. Guess I’m going home to dig out a receipt for it 1 Share this post Link to post Share on other sites
953 nut 64,858 #23 Posted May 8, 2025 Crimp connectors are fine if they are good quality and you have the proper crimper for them DO NOT buy the cheap ones sold at Harbor Freight or on line. Buy then at ACE Hardware or a good auto parts store. Share this post Link to post Share on other sites
1968Commando 171 #24 Posted May 9, 2025 3 hours ago, squonk said: I wouldn't go any smaller than 16 Well unfortunately night 1 of wiring was a bust I hooked up the solenoid and it didn’t even click nothing at all so I guess I’m gonna have to dink with it tomorrow Share this post Link to post Share on other sites
ebinmaine 77,976 #25 Posted May 9, 2025 6 hours ago, 1968Commando said: Well unfortunately night 1 of wiring was a bust I hooked up the solenoid and it didn’t even click nothing at all so I guess I’m gonna have to dink with it tomorrow Can you post pics of the wiring? Is the solenoid grounded? Share this post Link to post Share on other sites
