Redbird 1 #1 Posted September 15, 2009 :scratchead: This is becoming a major problem. I FINALLY located a tranny for my 211-5 and lo and behold, we can't get one of the wheels off. Have tried WD-40, naval jelly, Dep 45, hammer. Anyone run into that problem? Anyone figure out how to get it off? I really don't want to have to open the casing and put in another axil if I can avoid it. Thanks. I desperately need that rear end. Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted September 16, 2009 I had one that I took a torch cut the rim off right at the hub, with the wheel out of the way I took a grinder and split the hub on the axle, was a pain but worked. If the rim has bolt holes for wheel weights you might us a puller that will fit and long bolts with big washers on the back side. Share this post Link to post Share on other sites
Redbird 1 #3 Posted September 17, 2009 Problem solved. Friend who welds is phenomenal with torch. He cut the rim from hub, then split hub and NEVER touched the axel Thank you for the suggestions. I appreciate it greatly. Share this post Link to post Share on other sites
