Wayne0 1,666 #2 Posted May 7, 2025 I like the front "Mags"! 1 1 Share this post Link to post Share on other sites
Eriks Red horse herd 133 #3 Posted May 7, 2025 Nice little 400 stilling her work clothes. Good pick congrats! 2 Share this post Link to post Share on other sites
Pullstart 71,561 #4 Posted May 8, 2025 nice Suburban! 2 Share this post Link to post Share on other sites
Ricky Bobby 27 #5 Posted May 8, 2025 Believe it or not some of the gears are salvageable but the entire cluster gear is missing more teeth than an old school goalie! I will need some help with finding some gears, seals and bearings. 1 1 2 Share this post Link to post Share on other sites
Ricky Bobby 27 #6 Posted May 8, 2025 On 5/7/2025 at 2:36 PM, Wayne0 said: I like the front "Mags"! Ha Ha, they are all yours! 2 Share this post Link to post Share on other sites
Ricky Bobby 27 #7 Posted May 8, 2025 22 hours ago, Pullstart said: nice Suburban! Thank you! Pretty rare find in Texas I think. 1 Share this post Link to post Share on other sites
953 nut 70,656 #8 Posted May 8, 2025 6 minutes ago, Ricky Bobby said: I will need some help with finding some gears, seals and bearings. @stevasaurus has a post on the three piece that is outstanding. He may have a cluster gear or two kicking around too. 2 Share this post Link to post Share on other sites
Ricky Bobby 27 #9 Posted May 8, 2025 On 5/7/2025 at 5:41 PM, Eriks Red horse herd said: Nice little 400 stilling her work clothes. Good pick congrats! Thanks, it was sitting in a back yard for many years, lots of rust inside and out. 1 Share this post Link to post Share on other sites
Pullstart 71,561 #10 Posted May 8, 2025 E-tank will be your best friend for that one! 2 Share this post Link to post Share on other sites
Ricky Bobby 27 #12 Posted May 8, 2025 1 minute ago, Pullstart said: E-tank will be your best friend for that one! I tried that for the first time! fun process, I like to put things on and let them simmer like a nice stew! 2 Share this post Link to post Share on other sites
WHX?? 58,388 #14 Posted May 9, 2025 Lowell has the bearings & seals & I bet @Jake Kuhn has the gears. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/ Nice score ... orginal survivor. Share this post Link to post Share on other sites
oliver2-44 11,847 #15 Posted May 9, 2025 Nice original Suburban. It even has the original belt guard and exhaust shield. Your transmission casting date A30-0 translates to January 30, 1960. The solid seat pan also dates it to possibly be an earlier one. Looks like you missing the foot rest and front rims. Those rims can be hard to find due to the center tube being longer than many later ones. They were only used in 60/61. The tires were filled with calcium chloride for weight which rusted the rims out. On the dash between the throttle and choke levers that plate has a serial number stamped in it. With the rust the stamping can be very light. Polish it with scotch bite or fine steel wool and see if you can make any numbers out on it. I’am 4 hours down the road in Marble Falls, Tx. 1 Share this post Link to post Share on other sites
Ricky Bobby 27 #16 Posted May 10, 2025 On 5/8/2025 at 8:21 PM, WHX?? said: Lowell has the bearings & seals & I bet @Jake Kuhn has the gears. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/ Thanks for the info, I actually tried to message Jake but it wouldn't let me message him... maybe I haven't gone through the secret hazing /initiation yet . Nice score ... orginal survivor. Share this post Link to post Share on other sites
Ricky Bobby 27 #17 Posted May 11, 2025 On 5/8/2025 at 9:52 PM, oliver2-44 said: Nice original Suburban. It even has the original belt guard and exhaust shield. Your transmission casting date A30-0 translates to January 30, 1960. The solid seat pan also dates it to possibly be an earlier one. Looks like you missing the foot rest and front rims. Those rims can be hard to find due to the center tube being longer than many later ones. They were only used in 60/61. The tires were filled with calcium chloride for weight which rusted the rims out. On 5/8/2025 at 9:52 PM, oliver2-44 said: Nice original Suburban. It even has the original belt guard and exhaust shield. Your transmission casting date A30-0 translates to January 30, 1960. The solid seat pan also dates it to possibly be an earlier one. Looks like you missing the foot rest and front rims. Those rims can be hard to find due to the center tube being longer than many later ones. They were only used in 60/61. The tires were filled with calcium chloride for weight which rusted the rims out. On the dash between the throttle and choke levers that plate has a serial number stamped in it. With the rust the stamping can be very light. Polish it with scotch bite or fine steel wool and see if you can make any numbers out on it. I’am 4 hours down the road in Marble Falls, Tx. I will have to look for that plate # , thank you fellow Texan! Marble Falls Is beautiful!! Share this post Link to post Share on other sites
