1968Commando 189 #1 Posted May 5, 2025 (edited) Hey all, my wheel horse came to me missing my headlight so I have nothing to see in person or look at, so from what I can gather this is the headlight I need and if I’m correct is this the light wires that go to it? And is this all I need so then I just get a light bulb and screw it in or am I missing something I guess I’m having a hard time imagining how the light bulb would be held in place…sorry if I make this confusing to yall I just don’t want to buy something and realize I’m still missing pieces Edited May 5, 2025 by 1968Commando Share this post Link to post Share on other sites
Achto 32,250 #2 Posted May 5, 2025 You'll also need one of these. https://www.a-ztractor.com/product_info.php?cPath=1_30_32_49&products_id=8164 The bulbs for it are 1156 or LED equivalent. Share this post Link to post Share on other sites
1968Commando 189 #3 Posted May 5, 2025 3 minutes ago, Achto said: You'll also need one of these. https://www.a-ztractor.com/product_info.php?cPath=1_30_32_49&products_id=8164 The bulbs for it are 1156 or LED equivalent. Okay, do you suggest a new one or a used one they seem to be a pricy item Share this post Link to post Share on other sites
oliver2-44 11,656 #4 Posted May 5, 2025 (edited) @1968Commando Unless your trying to stay showroom correct, you might consider one of the small rectangular bar leds that would fit in the hood opening. If you go with the Wheel Horse reflector some of us have lined the inside of it with reflective shiny silver tape. Edited May 5, 2025 by oliver2-44 2 Share this post Link to post Share on other sites
1968Commando 189 #5 Posted May 5, 2025 1 minute ago, oliver2-44 said: @1968Commando Unless your trying to stay showroom correct, you might consider one of the small rectangular bar leds that would fit in the hood opening. If you go with the Wheel Horse reflector some of us have lined the inside of the with reflective shiny silver tape. Okay so do they have of be silver so that way it reflects light? 1 Share this post Link to post Share on other sites
oliver2-44 11,656 #6 Posted May 5, 2025 You can paint them white, but the silver does seen to reflect more light. 1 Share this post Link to post Share on other sites
Achto 32,250 #7 Posted May 5, 2025 8 hours ago, 1968Commando said: Okay, do you suggest a new one or a used one they seem to be a pricy item Used is good if you find one. If you get a new one I suggest running LED 1156 bulbs, the incandescent bulbs put off more heat & can damage the decal on the inside of the new aftermarket ones. . Share this post Link to post Share on other sites
1968Commando 189 #8 Posted May 5, 2025 4 hours ago, Achto said: Used is good if you find one. If you get a new one I suggest running LED 1156 bulbs, the incandescent bulbs put off more heat & can damage the decal on the inside of the new aftermarket ones. . Okay thank you Share this post Link to post Share on other sites
