Blacklac96 3 #1 Posted April 29 Hello! New to the forum here. Have a C-85 1984 K series engine tractor. The problem I'm having is after the blades are engaged awhile and it warms up, the tractor bogs down after a little and then shuts off. Sometimes difficult to restart if at all until it cools. Replaced, coil, condenser, plug and checked points. All seem to be fine. One time I noticed the online fuse blew for the starting circuit. Any help is appreciated! Share this post Link to post Share on other sites
Ed Kennell 43,775 #2 Posted April 29 to the Does it run and drive OK if the PTO is not engaged? Need to determine if the engine is the problem or is the deck and mule drive the problem. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,841 #3 Posted April 29 Suspect your tractor is a 1983 or older model. The ignition coil is powered by the ignition switch ignition terminal. But The ignition switch is powered by the pto switch when the pto is OFF and not when the pto is ON. Ignition switch is powered by the seat switch when the operator is in the seat with the pto OFF or ON. Strange way to incorporate safety switches. You should have battery voltage at the coil + with the pto OFF and key in Start or RUN position. With the pto ON operator in seat closes the seat switch and sends power to the coil + through the ignition switch with key in Start or RUN position. Click on the fuzzy picture to see the wiring diagram. Share this post Link to post Share on other sites
Blacklac96 3 #4 Posted April 29 I will trace some wiring definitely thank you for the diagram for sure. @Ed Kennell- yes it does seem to run fine without the pto on and hasn't shut off on me, although I haven't ran it much without the PTO on. When its engaged you can hear the engine initially bog down but then smooths out but seems to put strain on the engine more as it heats up. Share this post Link to post Share on other sites
953 nut 62,992 #5 Posted April 29 The problem could be a plugged vent in the gas cap. As the engine is operated fuel is being removed from the tank. If there is no vent for the tank a slight vacuum will be developed which the fuel pump can't overcome. Try operating it with the fuel cap a bit loose and see if this cures the problem. 1 Share this post Link to post Share on other sites
Ed Kennell 43,775 #6 Posted April 29 1 minute ago, Blacklac96 said: yes it does seem to run fine without the pto on Seems you may have a bad deck spindle or mule drive bearing. 2 Share this post Link to post Share on other sites
Blacklac96 3 #7 Posted April 29 Ok I will check both the gas cap and mule drive/spindles. I know I can service or replace the spindles, am I able to service the mule drive bearing or replace it? Share this post Link to post Share on other sites
peter lena 9,555 #8 Posted April 29 @Blacklac96 both those mule drive bearings and the deck spindle bearings are the same , 6203 ( 3/4 ) 2RSC3 , they also have wide bearing side grease shields , do not mean to add to your , bearing issue , but those bearings fail and get very whiney due to LUBRICATION FAILURE , lucas green xtra hd chassis grease , walmart $ 8 , bar code 04980710301 9 , those bearing side shields come off easily with a small flat edge putty knife , do not rough house them , the come off intact , wipe out original grease , carb cleaner , repack with lucas grease to same ammount , done a number of deck and mule upgrades , no noise / rough issues , only a suggestion , that entire pto drive set up is a gold mine , for improvement , difference is amazingly smooth / quiet , pete 1 Share this post Link to post Share on other sites
stvski80085 278 #9 Posted April 29 12 hours ago, Blacklac96 said: Hello! New to the forum here. Have a C-85 1984 K series engine tractor. The problem I'm having is after the blades are engaged awhile and it warms up, the tractor bogs down after a little and then shuts off. Sometimes difficult to restart if at all until it cools. Replaced, coil, condenser, plug and checked points. All seem to be fine. One time I noticed the online fuse blew for the starting circuit. Any help is appreciated! I had the same issue a couple week ago. I reset the carb back to what the manual said and adjusted the governor. The issue was solved after that. Just an idea. 2 Share this post Link to post Share on other sites
Blacklac96 3 #10 Posted April 29 This is extremely helpful. I am going to do all of this as I like to keep up on all service projects. I really love the tractor and it's true that they definitely don't make them like they used to! I can't replace it with this new garbage! 2 Share this post Link to post Share on other sites
stvski80085 278 #11 Posted April 30 (edited) That’s why I got one. Why pay $1200 or more for a cheap piece of junk. I wanted something that will last. They are both quick and easy to set. I would start with that and see what you get. If that doesn’t do it others here know more then me. steve Edited April 30 by stvski80085 Share this post Link to post Share on other sites
Blacklac96 3 #12 Posted April 30 Thanks again! Did get the pulleys off of the mule tonight and they were both dry and clicking, they spin but there was a lot of noise and I could see the inner one was worse and had got hot. So great info in the right direction! Plus I have the manual and I'm going to reset the carb. 1 Share this post Link to post Share on other sites
8ntruck 8,332 #13 Posted April 30 Do the blades spin freely by hand? Share this post Link to post Share on other sites
Blacklac96 3 #14 Posted April 30 Yes, they've been maintained and spin easily. I can see the previous owner kept them greased well. Share this post Link to post Share on other sites
8ntruck 8,332 #15 Posted May 2 My guess is carb adjustment or maybe timing. Point gap affects timing in these engines. Check that. Others have reported good results with a gap setting of .018". Share this post Link to post Share on other sites
