gt14rider 944 #1 Posted April 28 (edited) Good morning, bought a bandsaw at a flea market . Need to reduce speed, so it will cut metal, I was thinking of running a jack shaft. Need to figure out what pulleys to run. Is there a formula to figure out the speed of the pulley combinations I need to be around 100/120 rpm at the bandsaw, one problem is i can only run a 4 3/4" pulley at the bandsaw shaft, 5" would be real close to hitting. Motor turns 1725 rpm Any thoughts? Thanks Edited April 28 by gt14rider Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,444 #2 Posted April 28 Motor rpm x drive pulley diameter divided by the diameter of the driven pulley = rpm of the driven pulley. 2 1 Share this post Link to post Share on other sites
Ed Kennell 41,787 #3 Posted April 28 https://www.ebay.com/itm/356443921022?_skw=110v+electric+motor&itmmeta=01JSYM21Z7H1CX2E6MA33K85HM&hash=item52fdb69a7e:g:4qQAAOSw88xgEczl&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1fepdUCdOCT7Q7l2OSrvZxOE53jT8V9DWTlZar%2BpX4XnOHTI7p1h39kD28uTUwuwL0nBDsE%2F31QoFac%2B%2FPP0KqOZIg1ikuk4NUTTkVfU92u7iy%2FOppAwO6I%2FXLSGbVmvVgccJlgiGGjtuwaErSzdfKxdkV2QKvGcrm0URfs%2Bo4RH9wxqEp78%2F6MCfT%2FmYuYP9G3o1Du1J2ARl%2BN%2FGZLlsYhntdCvO1lWXV45P1DbsQzcs5VWYGXsws0yLprTwftm8%2Fhxoe1zm%2FXM%2BZOjVOMTGhnw3aKGaIZnBN51y%2FMyr7DYQ%3D%3D|tkp%3ABk9SR_afiNTPZQ 3 1 Share this post Link to post Share on other sites
ri702bill 9,347 #4 Posted April 28 The bandsaw most likely has an induction motor on it. If by chance it has a brush motor, you may want to consider a ii0 Volt Motor Speed Controler. Super easy to use - plug the Controller into the outlet, plug the saw into it - done. We use one on an old router to lower the speed for certain materials. The reduced speed still gives decent torque. It will NOT work on induction motors. 1 Share this post Link to post Share on other sites
wallfish 18,060 #5 Posted April 28 I'm with Ed, maybe slow the motor speed with a speed controller. 1 Share this post Link to post Share on other sites
Ed Kennell 41,787 #6 Posted April 28 It's best to be able to set the blade linear speed to match the material and blade tooth specs. Wood, lead, copper, brass, iron, steel,and sst can all be cut but require the correct blade and speed. 1 Share this post Link to post Share on other sites
gt14rider 944 #7 Posted April 29 Thank you all, I like the speed controller, but have a question about the motors horse power rating. I read the saw should have 1/3 hp. How do you figure out what motor will fit my needs. Electrical is a learning experience for me. Thanks Share this post Link to post Share on other sites
lynnmor 7,789 #8 Posted April 29 2 hours ago, gt14rider said: Thank you all, I like the speed controller, but have a question about the motors horse power rating. I read the saw should have 1/3 hp. How do you figure out what motor will fit my needs. Electrical is a learning experience for me. Thanks 1/3 HP is about 240 watts. Share this post Link to post Share on other sites
gt14rider 944 #9 Posted April 29 Thanks for the info, still can't wrap my head it. This is the motor ed sent me the info on. Will it run the saw? 110v. 15w ac. ? Lynnmor said you need 240 Watts to make 1/3 hp ??? Share this post Link to post Share on other sites
Ed Kennell 41,787 #10 Posted April 29 11 minutes ago, gt14rider said: Will it run the saw? Not if the saw needs 1/3 HP. I did not size the motor, just wanted to show variable rpm motors are available. A jack shaft with several different diameter pulleys drill press style may also be a good option. Share this post Link to post Share on other sites
lynnmor 7,789 #11 Posted April 29 For reference this motor is 1/3 HP and draws 690 watts. There are other motors similar to Ed's link that are more powerful but much higher cost. Like Ed says, you may not need the entire 1/3 HP, the current draw will be in relation to the load. Share this post Link to post Share on other sites
wallfish 18,060 #12 Posted April 29 The motors in that link have a gear reduction built in. That adds to the output torque vs using just a straight shaft motor without one. Share this post Link to post Share on other sites
gt14rider 944 #13 Posted April 30 Thank you all, I did like the gear reduction motor, but I think I'll stick with pulleys and jack shaft. Used the formula Gwest posted and I figured out what pulleys to use, now just need some bearings and 5/8 shaft and have an old 1/3 hp motor have to dust it off it's been sitting for a while. I'll post some pic when I do. 1 1 Share this post Link to post Share on other sites
