clueless 3,439 #1 Posted April 28, 2025 Anybody know what non wheel horse front wheel weight go for by the LB. I've got a set of simplicity 50LB weights. Share this post Link to post Share on other sites
rjg854 13,360 #2 Posted April 28, 2025 Non wheel horse about $1 a pound 2 Share this post Link to post Share on other sites
wallfish 20,618 #3 Posted April 28, 2025 50 lbs is a lot weight for fronts. Or, do you mean both of them weigh 50 lbs? 1 Share this post Link to post Share on other sites
peter lena 10,070 #4 Posted April 28, 2025 @clueless front ends are very often neglected at best , what are your wheel bearings like ? HILLMAN MACHINE BUSHINGS , eliminate side shucking / slamming , also use lucas green chassis grease , any increase in weight / side loading stress . will wallow out what ever base you have , also installed XIKE bearings # 532009040, repack lucas green grease . only a suggestion , pete Share this post Link to post Share on other sites
Achto 32,729 #5 Posted April 28, 2025 13 hours ago, clueless said: Anybody know what non wheel horse front wheel weight go for by the LB. Plastic - $1/lb Cast iron - $2/lb 2 1 Share this post Link to post Share on other sites
clueless 3,439 #6 Posted April 28, 2025 1 hour ago, Achto said: Plastic - $1/lb Cast iron - $2/lb Cast iron 1 Share this post Link to post Share on other sites
Achto 32,729 #7 Posted April 28, 2025 (edited) Note: If they are for 8" front rims, they will work on a too. Weight is weight. I'm guessing they look like these. Edited April 28, 2025 by Achto Share this post Link to post Share on other sites
clueless 3,439 #8 Posted April 29, 2025 14 hours ago, Achto said: Note: If they are for 8" front rims, they will work on a too. Weight is weight. I'm guessing they look like these. Good guess, I think their about 25# each, so around $100 for the set? Share this post Link to post Share on other sites
Achto 32,729 #9 Posted April 29, 2025 1 minute ago, clueless said: I think their about 25# each, so around $100 for the set? Would be a fair price. Share this post Link to post Share on other sites
WHX?? 58,149 #10 Posted April 29, 2025 14 hours ago, Achto said: they will work on a too. Weight is weight. Yep ... 1 Share this post Link to post Share on other sites
