Marv 996 #1 Posted April 24, 2025 I debated on putting this here or in the engine forum. Since it applies to both I put it here. My SK486 engine decided to self destruct today. I am thinking about swapping the 145 engine to the SK486. Yes, I realize the 145 is a cradled engine, while the SK is solid mount. Has anyone tried this before.? Seems like it should work/ Marv 1 Share this post Link to post Share on other sites
kpinnc 18,387 #2 Posted April 24, 2025 Just move the cradle with it. Should bolt right in. You may want to consider replacing the rubber mounts with solid ones. Likely because if they haven't failed completely, they will eventually. 4 1 Share this post Link to post Share on other sites
mrc 1,084 #3 Posted April 24, 2025 get the zach kerber solid mounts. last time i bought some they were $55-60. for a set of 4 top notch product! Share this post Link to post Share on other sites
953 nut 66,542 #4 Posted April 24, 2025 With the SK being an 8 speed and the C being an automatic you will want to swap the engine drive pulley but everything else should work well. Are they both equipped with battery ignition systems? Share this post Link to post Share on other sites
ri702bill 12,227 #5 Posted April 24, 2025 10 hours ago, mrc said: get the zach kerber solid mounts. last time i bought some they were $55-60. for a set of 4 top notch product! Bought mine used from an RS member - well worth the time & money.... 1 Share this post Link to post Share on other sites
pfrederi 20,654 #6 Posted April 24, 2025 Or get a couple spacers and mount the engine direct to the frame... You may have to drill a new hole.. I didn't on this one. 3 Share this post Link to post Share on other sites
Marv 996 #7 Posted April 25, 2025 Thank you all for your input. Looks like we all agree. Marv Share this post Link to post Share on other sites
