TC10284
Replacement 9 pin connector
nylyon
If you take the battery tray out and the dash panel, you can reach in from the dash side and loosen the nuts on the screws that hold the bracket on, they are 5/16.  Then the bracket holding the fuse holder comes out and you can do the same for the fuse holder itself.
TC10284
I need some help. I'm stuck. I got the fuse block in today and connected it up like I THOUGHT it should be, basing it off the old fuse block and the wiring diagram for my model.
Original fuse block:
https://photos.app.goo.gl/p5q52ygh9VaTnJVG8
Replacement fuse block after my work:
https://photos.app.goo.gl/SU75zHks2pttF9nc9
Explanation:
Someone put a tap from the red wire to provide power to the two white wires. This worked previously, although the wires in the fuse block were loose and losing connection, causing the tractor to die.
On the NEW fuse block, I attempted to do this by using a joined terminal, as shown in my pics, that SHOULD (in my mind) provide power from the red wire to the two white wires through the fuse for white. My problem is that when I turn the battery booster on, and key switch on, I get NOTHING. Wiggling the wires does nothing. I get absolutely nothing. I don't get any voltage on either red wire when putting a multimeter red lead on either red wire and the black lead to a good engine ground.
I am confused.
I then went to review the wiring diagram and I can't figure out what I'm missing. I've reviewed closely the wiring diagram here for my model/serial (73421 4900770) where the red wire from the battery "splits" into two at the fuse block the 25A and 30A fuses, which is where I THOUGHT the double fuse terminal would come into play.
But something is off...
I also noticed there was a blue wire tapped into another blue wire and cut on a relay, but that has not affected anything before and I will address that later.
nylyon
The red wire which feeds the fuse block is comming off the red wire on the 9-pin connector.  Check for +12v on the starter terminal, the engine side of the red wire on the 9-pin and the tractor side of the 9-pin.  Finally on the fuse block.  If you have the power everywhere except the fuse, you have a bad red wire.  That wire should be hot all the time regardless of the position of the key.
My 416-H is serial number 479 and 100% original, so I can check anything on that for you as well, except it is in the shed and it is raining now so would have to be tomorrow.
I think you are on the right track, but need to chase down that red wire to see why you don’t have power.
One of those red wires goes to the battery via the 9-pin and primary on the starter, the other side to the key.  If you are getting nothing on either side, work backwards to the 9-pin and to the starter.
TC10284
It was the red wire that is supposed to provide 12v to everything on the engine side of the 9 pin connector that I "fixed" previously. It came loose. 🙄😡
I haven't tried starting it, but I have power and the idiot lights come on as normal now.
Thanks!
Edited by TC10284
nylyon
Should be all set once that is secured. The rest looks like it’s the way it should be, except that blue wire, sounds like it;’s the starter circuit for “fixed” at one point, or a safety switch bypassed.
TC10284
It turns over so hopefully, if my wiring work is good enough, I should be in a better position.
I'll prob address that blue wire next but will prob need a new relay switch connector.
I appreciate your help!
nylyon
Have to find where to source the relay connector.  Glad you’re back in business now!
953 nut
