ebinmaine
Garden/ Forest access bridge & stone path project.
ebinmaine
Our property consists of "something over 10 acres". Actual size unknown. We know exactly where the borders are. We know the edges aren't negotiable. We pay taxes on 10.
I originally bought  EXACTLY 10.
The reason we don't know the actual size is that back about 12 or 15 years ago there was a logging project done on the 16 acres that surrounds me on two sides.
At that time the permitting process required them to get a legal Land Survey done. My back border stayed put. My side border however moved AWAY from the house building 65 feet ONLY at the front (street) pin.
I gained a wedge shaped sliver of land on the long side.
Hence.... "something over 10 acres".
The front 3+ is separated from the rear 7+ by a mountain runoff stream that has a wide marshy area.
This year one of our main projects is to construct and improve the access to the back 7 ish acres.
In the past we've gone by foot or machine over to the far left side and crossed the temporary pallet bridge near that border.
Note I wrote temporary.
After 6 or 7 years it's time to replace or relocate that bridge.
We choose to relocate the access to a more central point of the acreage.
Over the years we've had two good sized clearing and flattening projects done. We cut and harvested the trees for firewood. Then the stump clearing was done by the excavator. He also relocated a bunch of rocks and boulders along with flattening out the ground surface making it passable by machine.
We built the garden in the first cleared area a few years ago.
This new bridge location happens to align with the garden access as well. Double positive.
The span distance is pretty short. If stones were set on both sides of the stream most people could jump across.
The bridge dimensions will be:
48" span by 50" or so wide.
The widest tractor we have is 42". The splitter has a slightly offset pull.
This should be just fine.
While delivering to a lumberyard several months ago I noticed a piece of 4" x 6" x 16' PT setting on a cull pile. It was wickedly curved. Perfect for making bridge beams.
I cut that to four pieces just under 4 feet each.
For the top boards we're using some pieces of rough cut 2" x 8" red oak. This isn't the ideal outdoor wood but it'll be able to dry in the sun all year so it should last many years if treated.
Yesterday I spent a few hours reorganizing in the barn again and part of that was getting the lumber out from its buried hiding spots.
I cut the 2 x 8s to an even half, about 50".
I sanded the edges of the red oak and used a wood rasp to deburr the PT.
Then I started painting. I'm using the solid color exterior stain we originally bought for the barn.
That color is being changed this year so we had leftover paint.
Here's where I left off...
  • Like 4
  • Excellent 4
ri702bill
Looks good... my 2 cents  - seal all surfaces & edges of all the wood. It is going over a high moisture ares, exposed on all sides...
Edited by ri702bill
ebinmaine
3 minutes ago, ri702bill said:
Looks good... my 2 cents  - sall all surfaces & edges of all the wood. It is going over a high moisture ares, exposed on all sides...
ALL the edges and corners and ends will be painted a minimum of two coats. Maybe more.
I figured on repainting the top surface every two years.
ebinmaine
While looking for pics of this bridge I realized I'd failed to update this thread...
Here's a post from many moons ago showing the final product.
We've been in a holding pattern for installation due to being in a holding pattern for getting the excavator back over here.
This past week that finally happened.
At some point fairly soon we'll move the new bridge into place and get a good pile of stones on the path before n aft...
RandyLittrell
Looking good Eric!!!!
c100rider
I like it.
953 nut
Eric, those photos of you doing WORK remind me of my wife's opinion of the "Home Renovation" shows on TV.  She always tells me the host of the show is filmed holding tools and then gets out of the way so the workers can actually accomplish the task.        :ychain:    Nice of BBT to allow you to look like you did the job.
  • Haha 5
ebinmaine
:ROTF:
BBT said the guys would think we were staging those!!
  • Haha 5
ebinmaine
Over the last couple weeks Trina's been adding a few small loads of rocks and stones to the edges and approaches of the bridge as she goes by doing other things.
Yesterday I loaded some rock from the front yard into the black trailer.
This morning I finished up the approach ramps with the load from the front.
The bridge and first couple feet of path are now done.
This morning I was able to take the first cruise all the way around the entire house & barn circle since the most recent excavation was done.
Long way to go with rebuilding some old pathways and making new ones... but it's fully drivable with only moderate roughness in comparison to the past.
  • Excellent 4
