adsm08 4,747 #26 Posted March 15, 2025 10 hours ago, pfrederi said: grab a battery out of one of your WHs. Hook it up to the E-Tank then put the charger on the battery That's what I do. I put an old battery on the charger, and then run jumper cables to the work and sacrificial pieces. The problem is it usually ruins the battery after a few weeks of use, and so it still poses a problem. I don't have that many spare batteries laying around. Share this post Link to post Share on other sites
Yossarian 210 #27 Posted March 16, 2025 The jungle site has DC power supplies in the $40-50 range. Lots of folks on the E-tank group on FB use them. Easier to dial in and won't wear out a charger or batteries. I need to get one myself. 2 Share this post Link to post Share on other sites
Chaz54 100 #28 Posted March 16, 2025 1 hour ago, Yossarian said: The jungle site has DC power supplies in the $40-50 range. Lots of folks on the E-tank group on FB use them Do you have a specific model that they recommend? Share this post Link to post Share on other sites
EB-80/8inPA 2,028 #29 Posted March 16, 2025 Has anyone suggested trying a heat gun yet? Or a torch, lol. Share this post Link to post Share on other sites
RED-Z06 2,718 #30 Posted March 16, 2025 Just now, EB-80/8inPA said: Has anyone suggested trying a heat gun yet? Or a torch, lol. Makes it worse, the paint tends to burn on, the amount of heat needed to incenerate it would require some resources... 1 Share this post Link to post Share on other sites
Yossarian 210 #31 Posted March 16, 2025 4 hours ago, Chaz54 said: Do you have a specific model that they recommend? I just went through the group real quick to see what popped up. The latest one mentioned was "Galook" . There are a bunch of them that look pretty much the same and have equally silly sounding names. Looks like the prices have gone up recently though. Share this post Link to post Share on other sites
Thor27 891 #32 Posted March 18, 2025 Thank you all for the great info. Gathering up stuff now for an e tank. I used to be a fan of vinegar, last batch I did had a cast iron engine and hydro pulleys. It, for lack of a better word "delaminated" them. 1 Share this post Link to post Share on other sites
HyperPete 939 #33 Posted March 19, 2025 On 3/14/2025 at 10:59 PM, WHX?? said: Is that right blaster? Come to think of it some leaked out of a Harley master cylinder and it took off pain. Or was it dot 5 ? CRS but prolly got some of both in a open container that can't be used in brakes. DOT3 is the paint remover. DOT5 is silicone based and won't hurt paint. BTW, is Naval Jelly still around? I used to use that for a mild rust remover. HCL for tough stuff. Share this post Link to post Share on other sites
RED-Z06 2,718 #34 Posted March 19, 2025 12 minutes ago, Pete D said: DOT3 is the paint remover. DOT5 is silicone based and won't hurt paint. BTW, is Naval Jelly still around? I used to use that for a mild rust remover. HCL for tough stuff. Naval Jelly is still around, it can be hard on your base metal, its Phosphoric and Sulfuric Acids...works though 1 Share this post Link to post Share on other sites
OoPEZoO 605 #35 Posted March 19, 2025 I'm partial to the E-tank method as well. For my power supply, I grabbed an old Lenovo laptop power supply I had kicking around. It was rated at 20V 10A. I cut the DC plug off of it and spliced on a battery tender quick disconnect. That gives me plenty of options for quickly connecting and disconnecting ring terminals or the small spring loaded battery clamps. I tend to pressure wash my parts first, then drop them in the tank. It always takes off like a handful of alkaseltzer tablets. I knew it would handle rust, but it surprises me how well it does with removing old paint as well. It will typically lift the paint and eat all the rust in a matter of a day or 2. Then I clean the parts and put them on a shelf with the intent to prime them. I never get around to it in time and they all collect surface rust. Then I repeat. 4 1 Share this post Link to post Share on other sites
HyperPete 939 #36 Posted March 21, 2025 (edited) On 3/16/2025 at 12:18 PM, Chaz54 said: Do you have a specific model that they recommend? Would an old computer power supply work? They are available, a dime a dozen. Edited March 21, 2025 by Pete D Share this post Link to post Share on other sites
Wayne0 1,571 #37 Posted March 22, 2025 On 3/20/2025 at 8:27 PM, Pete D said: Would an old computer power supply work? They are available, a dime a dozen. On my shelf! 1 Share this post Link to post Share on other sites
HyperPete 939 #38 Posted March 22, 2025 2 hours ago, Wayne0 said: On my shelf! I owned a computer business years ago. I had a LOT of power supplies, but ended up pitching all of the old computer parts when I moved. I do have old laptops and their power supplies, however. Now that my sandblaster is upgraded, I guess I can make an e-tank for good measure. (I have an unused / undesignated plastic 55 gallon drum gathering dust.). I just need to find a spouse-approved outdoor location for it. Hydrogen gas accumulating in the shop where I weld isn't a great idea. Share this post Link to post Share on other sites
