midpack 1,073 #1 Posted March 10 Thinking about options for the 312-8 with the bound transmission, I do have a hydro off a 312 Classic, similar era. The 312-8 is early with a K 301, the hydro was a M12. It's still connected to the lift piston and lever. Is it doable? Share this post Link to post Share on other sites
ebinmaine 75,513 #2 Posted March 10 @cleat Has done this. And reverse? Share this post Link to post Share on other sites
ri702bill 10,497 #3 Posted March 10 Perhaps download the Parts List for both and look for similarities and differences on Part Numbers for each as a start??? 1 Share this post Link to post Share on other sites
oliver2-44 11,036 #4 Posted March 10 I've been look at doing something like this on a C series. The easiest way is to move the complete hoodstand which has all the linkages in it. you could leave the upper dash which has the steering shaft through it and just bolt that dash back onto the traded hoodstand. 1 Share this post Link to post Share on other sites
kpinnc 16,140 #5 Posted March 11 There are alot of linkages and pedals and such you'll need from the donor machine, but on the tractor itself the frames and sheet metal are the same for both setups. You won't have to modify anything. You'll just have alot of small parts to swap with it. 1 Share this post Link to post Share on other sites
ebinmaine 75,513 #6 Posted March 11 13 hours ago, oliver2-44 said: I've been look at doing something like this on a C series. A#1. I'm NO authority on the 300 400 500 series. I believe one of the advantages of manufacturing with the 1980 something and up is the sheet metal being usable for both manual and hydro. As you know, on our older B and C Series the entire transmission tunnel / lower steering tower needs to be swapped for a conversion either way. Share this post Link to post Share on other sites
953 nut 62,877 #7 Posted March 12 (edited) On 3/10/2025 at 1:36 PM, midpack said: Thinking about options for the 312-8 with the bound transmission, I do have a hydro off a 312 Classic, similar era. The 312-8 is early with a K 301, the hydro was a M12. It's still connected to the lift piston and lever. Is it doable? It would be much easier to put the K-301 on the 312 hydro, just need to swap out the engine pulley. Swapping the hydro in place of the 8 speed will involve swapping out the sheet metal, linkage and the whole tunnel that resides between the hood stand and the seat. Read thread thread, has all the info you need. Edited March 12 by 953 nut Add thread Share this post Link to post Share on other sites
