1968Commando 189 #1 Posted February 16, 2025 Hello all, I am restoring a commando 8 and from the factory it had a cigarette lighter that is now missing, now before you ask no I don’t smoke and I don’t plan on smoking I just want it back because it looks cool I think haha, anyways I found one on az tractor do yall think this is what I need or do I need more pieces Share this post Link to post Share on other sites
WHX?? 58,146 #2 Posted February 16, 2025 (edited) Any cigar lighter will work. Trick is to get the orginal style knob, Hen's teeth sometimes and can command a hefty price if you do get lucky. If A-Z has an original for that coin order it NOW!! Edited February 16, 2025 by WHX?? 3 Share this post Link to post Share on other sites
1968Commando 189 #3 Posted February 16, 2025 10 minutes ago, WHX?? said: And cigar lighter will work. Trick is to get the orginal style knob, Hen's teeth sometimes and can command a hefty price if you do get lucky. If A-Z has an original for that coin order it NOW!! So did that look like a complete plug and go set or no? Share this post Link to post Share on other sites
WHX?? 58,146 #4 Posted February 16, 2025 No the socket is missing but your pic isn't showing us squat. . 1 Share this post Link to post Share on other sites
1968Commando 189 #5 Posted February 16, 2025 (edited) 2 minutes ago, WHX?? said: No the socket is missing but your pic isn't showing us squat. . So sorry I just realized I totally cut off half the picture Edited February 16, 2025 by 1968Commando 1 Share this post Link to post Share on other sites
kpinnc 18,968 #6 Posted February 16, 2025 I um, never found originals. Decided to just make a funny... 6 1 Share this post Link to post Share on other sites
1968Commando 189 #7 Posted February 16, 2025 Here is a socket I found I will look at the part numbers and see if they match Share this post Link to post Share on other sites
1968Commando 189 #8 Posted February 16, 2025 Just now, kpinnc said: I um, never found originals. Decided to just make a funny... 😂😂😂😂 Share this post Link to post Share on other sites
WHX?? 58,146 #9 Posted February 16, 2025 (edited) Yes that is the entire correct assembly. Order it ... Linc at A-Z is a good guy to deal with. BTW I have seen those at the BS for upwards of 75 clams. Much more if in a original blister pack. Your a hamster KP ... Edited February 16, 2025 by WHX?? 2 1 Share this post Link to post Share on other sites
1968Commando 189 #10 Posted February 16, 2025 1 minute ago, WHX?? said: Yes that is the entire correct assembly. Order it ... Linc at A-Z is a good guy to deal with. Your a hamster KP ... ok thank you, now I saw there is a wire that Goes to it l, do I need anything special to hook that up? Share this post Link to post Share on other sites
WHX?? 58,146 #11 Posted February 16, 2025 2 minutes ago, 1968Commando said: special to hook that up No just wire it to ACC on the ignition switch or I on the switch if you don't have a ACC. Make sure the socket is grounded to the dash and so forth. 53 minutes ago, 1968Commando said: restoring a commando 8 and from the factory And we know you are doing this because the are where??? Share this post Link to post Share on other sites
1968Commando 189 #12 Posted February 16, 2025 4 minutes ago, WHX?? said: And we know you are doing this because the are where??? Theo photos of the restoration are in the wheel horse forum restoration section, the title is “commando 8 restoration” 2 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #13 Posted February 16, 2025 I hoard these cigarette lighters lol I think i have 6 now 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #14 Posted February 16, 2025 3 hours ago, 1968Commando said: Here is a socket I found I will look at the part numbers and see if they match That is 1/2 the socket. There is an outer shell that threads onto the large threads at the base to hold it in the dash. There were only two major lighter suppliers back in the day. Rochester and this one I believe is Casio - totally different. 1 Share this post Link to post Share on other sites
ri702bill 13,068 #15 Posted February 16, 2025 9 hours ago, WHX?? said: 9 hours ago, 1968Commando said: special to hook that up No just wire it to ACC on the ignition switch or I on the switch if you don't have a ACC. Make sure the socket is grounded to the dash and so forth. And be sure the wire has a fuse inline.... 2 1 Share this post Link to post Share on other sites
WHX?? 58,146 #16 Posted February 16, 2025 1 hour ago, ri702bill said: And be sure the wire has a fuse inline Not factory original but not a bad idea either. Many variations available and not real pricey. https://www.amazon.com/Inline-Fuse-Holder-Waterproof-XIOGZAXI/dp/B0C9V2SW8K/ref=asc_df_B0C9V2SW8K?mcid=b0ca75d5514730258193ee498f894dd2&tag=hyprod-20&linkCode=df0&hvadid=693507722822&hvpos=&hvnetw=g&hvrand=16965254652665945570&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9209409&hvtargid=pla-2204758633098&th=1 Share this post Link to post Share on other sites
WHX?? 58,146 #17 Posted February 16, 2025 (edited) Awesome dude keep the pics coming. I noticed you said you have a starter gen. My fav motor. '68 ish was the last year for them. Some Raiders had them some didn't in 68. If you do have a S/G the lighter should be wired off the "L" terminal on the regulator. Along with any lighting or other accessories you may run. Edited February 16, 2025 by WHX?? Share this post Link to post Share on other sites
WHX?? 58,146 #18 Posted February 16, 2025 You might have this file but wiring diagram along with other good info here. Share this post Link to post Share on other sites
1968Commando 189 #19 Posted February 16, 2025 1 hour ago, WHX?? said: You might have this file but wiring diagram along with other good info here. Thanks for all the info Share this post Link to post Share on other sites
1968Commando 189 #20 Posted February 16, 2025 10 hours ago, gwest_ca said: That is 1/2 the socket. There is an outer shell that threads onto the large threads at the base to hold it in the dash. There were only two major lighter suppliers back in the day. Rochester and this one I believe is Casio - totally different. Ok soooo now I’m confused, do I have the right pieces or not, I want to make sure I have all the pieces for the cigarette lighter I need because currently I have a dc switch in the cigarette hole. Share this post Link to post Share on other sites
1968Commando 189 #22 Posted February 16, 2025 2 minutes ago, WHX?? said: Ok so I got the lighter and the socket now I just need too find the case to tie it all together. 1 Share this post Link to post Share on other sites
rjg854 13,360 #23 Posted February 16, 2025 If AZ has those 2 pieces, I would think he would most likely have the case too. Share this post Link to post Share on other sites
WHX?? 58,146 #24 Posted February 17, 2025 3 hours ago, rjg854 said: most likely have the case too One would think so and he would sell as one piece. Sometimes they are so rusted they shred getting them off. Share this post Link to post Share on other sites
Bar Nuthin 3,245 #25 Posted October 13, 2025 On 2/16/2025 at 8:21 PM, WHX?? said: Sometimes they are so rusted they shred getting them off. And sometimes you find them in the bottom of a bucket of stuff you didn't even know you had! 1 5 Share this post Link to post Share on other sites
