RED-Z06 2,718 #1 Posted February 8, 2025 Ive done the thrust washer mod, and lubed everything on my 416-H but im still unhappy with the steering effort with the blade on front. Im thinking about how to add counter weight in back, it has the sleeve hitch to pull the small brinly attachments. Share this post Link to post Share on other sites
ri702bill 12,399 #2 Posted February 9, 2025 Not a sleeve hitch, but a later "spanker" style hitch on my 854. Added a 50 pound weight on it, along with wheel weights and 150 pounds of lead ingots under the seat for traction when using my swing down scarifier on the 42" plow.... Share this post Link to post Share on other sites
Handy Don 16,917 #3 Posted February 9, 2025 2 hours ago, RED-Z06 said: Ive done the thrust washer mod, and lubed everything on my 416-H but im still unhappy with the steering effort with the blade on front. Im thinking about how to add counter weight in back, it has the sleeve hitch to pull the small brinly attachments. I’m sure the hitch can handle the weight, but wouldn’t the weight want to go up and down along with the blade? 1 Share this post Link to post Share on other sites
Lee1977 7,688 #4 Posted February 9, 2025 (edited) Most of us add a receiver hitch to the rear bolted to the top of the axle and braced down to the WH hitch. Either bought or home made. I don't have a weight bracket for mine, but do have pulverize that adds weight. Guess about 80 #.. As you can see there are other mods going on here. winch for rear lift. raised fender seat bracket and gas tank. This receiver hitch is braced off the top of the transmission. The trick to using the sleeve hitch with the receiver hitch is it has to be modified also. Move the lift lever to the out side. The reason for the home made sleeve hitch I built the pulverizer hitch too short. The tractor is raised with 25" tires rear and 16" tires on 6" spindles. Edited February 9, 2025 by Lee1977 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #5 Posted February 9, 2025 1 hour ago, Handy Don said: I’m sure the hitch can handle the weight, but wouldn’t the weight want to go up and down along with the blade? It would, im hoping the cylinder is up for it. It lifts the tiller without any hesitation and that sob is heavy. Theres just not alot of options in back because theres no frame, no rockshaft, just a transmission and the plow mounts currently occupy the axle tubes. Share this post Link to post Share on other sites
Lee1977 7,688 #6 Posted February 9, 2025 (edited) 1 hour ago, RED-Z06 said: It would, im hoping the cylinder is up for it. It lifts the tiller without any hesitation and that sob is heavy. Theres just not alot of options in back because theres no frame, no rockshaft, just a transmission and the plow mounts currently occupy the axle tubes. The receiver hitch mounts on top of the axle housing using the same bolt as the plow mount. Edited February 9, 2025 by Lee1977 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #7 Posted February 9, 2025 (edited) 2 hours ago, Lee1977 said: The receiver hitch mounts on top of the axle housing using the same bolt as the plow mount. What hitch is that? My drawbar and clevis/sleeve hitch use the pivot pin down on the bottom. This? https://wheelhorsepartsandmore.com/product/heavy-duty-removable-receiver-hitch-with-axle-mounting-hardware-if-you-do-not-have-a-104659-bracket/ Looks like you have to knock out the pin, remove the clevis hitch entirely to use this reciever because it interferes, really dont want to have to do all that, ill figure out a way to make it work, too bad wh didn't use power steering like so many others did at the time. Edited February 9, 2025 by RED-Z06 Share this post Link to post Share on other sites
wallfish 20,158 #8 Posted February 9, 2025 9 hours ago, RED-Z06 said: the plow mounts currently occupy the axle tubes. 8 hours ago, Lee1977 said: The receiver hitch mounts on top of the axle housing using the same bolt as the plow mount. https://wheelhorsepartsandmore.com/product/heavy-duty-removable-receiver-hitch-with-axle-mounting-hardware-if-you-do-not-have-a-104659-bracket/ Share this post Link to post Share on other sites
sergeant 350 #9 Posted February 9, 2025 Well This works fine on a Wheel Horse Clevis Hitch called the 4X Multi Suitcase Pinned Weight Receiver from Johnny Products. https://johnnyproducts.com/ordermain.htm#SLVACC $125.00 + shipping. I am still a little Leary of it though because of the cable on the Clevis Hitch. But My Other Tractors with Sleeve Hitch with Mechanical Linkage or Actuator Linkage it works fine on 2 Share this post Link to post Share on other sites
RED-Z06 2,718 #10 Posted February 9, 2025 1 hour ago, sergeant said: Well This works fine on a Wheel Horse Clevis Hitch called the 4X Multi Suitcase Pinned Weight Receiver from Johnny Products. https://johnnyproducts.com/ordermain.htm#SLVACC $125.00 + shipping. I am still a little Leary of it though because of the cable on the Clevis Hitch. But My Other Tractors with Sleeve Hitch with Mechanical Linkage or Actuator Linkage it works fine on That's pretty much what im needing, and i have 4 JD 42lb weights on hand too. Awesome Share this post Link to post Share on other sites
Goldnboy 1,126 #11 Posted February 9, 2025 3 hours ago, RED-Z06 said: That's pretty much what im needing, and i have 4 JD 42lb weights on hand too. Awesome You also use this on the front too! Share this post Link to post Share on other sites
RED-Z06 2,718 #12 Posted February 9, 2025 10 minutes ago, Goldnboy said: You also use this on the front too! I made a nice front weight with an old mule drive and a 40lb simplicity weight, welded it on and i can install or remove it with the mule drive quik tach 1 Share this post Link to post Share on other sites
Handy Don 16,917 #13 Posted February 9, 2025 17 hours ago, Lee1977 said: The trick to using the sleeve hitch with the receiver hitch is it has to be modified. Move the lift arm to the outside. This is a great insight, thanks! The interference concern has so far prevented me from adding a receiver hitch. Now it’ll go on my list! 1 Share this post Link to post Share on other sites
sergeant 350 #14 Posted February 9, 2025 1 hour ago, Goldnboy said: You also use this on the front too! I use it On the front, But it sticks out a Little Far as I am using this WHEEL HORSE/TORO LAWN GARDEN TRACTOR TEMP. FRONT HITCH RECEIVER DRAWBAR ATV | eBay Then I use this https://heavyhitch.com/product/sleeve-hitch-adapter-2-inch-receiver/ and then I finally add the Johnny Bucket weight bracket. 2 Share this post Link to post Share on other sites
Goldnboy 1,126 #15 Posted February 11, 2025 On 2/9/2025 at 1:08 PM, sergeant said: I use it On the front, But it sticks out a Little Far as I am using this WHEEL HORSE/TORO LAWN GARDEN TRACTOR TEMP. FRONT HITCH RECEIVER DRAWBAR ATV | eBay Then I use this https://heavyhitch.com/product/sleeve-hitch-adapter-2-inch-receiver/ and then I finally add the Johnny Bucket weight bracket. Yes i have exactly the same setup! Share this post Link to post Share on other sites
kpinnc 18,723 #16 Posted February 11, 2025 Given the simplicity of the front hitch (just a 5/8 steel rod locks in nicely) and the flat bar needed for the weights- a front hitch setup is one of the easier things to fabricate. This is mine. I wish the weights were still available. I'd buy about 10 more for use on the back. 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,669 #17 Posted February 12, 2025 17 hours ago, kpinnc said: This is mine. I wish the weights were still available. I'd buy about 10 more for use on the back. @Pullstart has a source I believe...? 1 1 Share this post Link to post Share on other sites
Pullstart 70,447 #18 Posted February 12, 2025 Not this Pullstart… 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,669 #19 Posted February 12, 2025 (edited) 8 minutes ago, Pullstart said: Not this Pullstart… Didn't you post a source for all kinds of new weights last week or so??? Am I nuts? Don't answer that... Edited February 12, 2025 by SylvanLakeWH 1 Share this post Link to post Share on other sites
kpinnc 18,723 #20 Posted February 12, 2025 32 minutes ago, SylvanLakeWH said: Didn't you post a source for all kinds of new weights last week or so??? Am I nuts? Don't answer that Thank you! Can't speak for pricing yet, but they have several versions in the 25- 40lb size. Very interesting! 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,669 #21 Posted February 12, 2025 13 minutes ago, kpinnc said: Thank you! Can't speak for pricing yet, but they have several versions in the 25- 40lb size. Very interesting! I am a bit concerned that there may be an AI version of @Pullstart out there... 3 Share this post Link to post Share on other sites
kpinnc 18,723 #22 Posted February 12, 2025 1 hour ago, SylvanLakeWH said: I am a bit concerned that there may be an AI version of @Pullstart out there... Well, isn't he a "Kevin"? I am one of them Kevins, and I can't remember what I said/ did yesterday... My grandfather said Wiley Coyote was drawn with him in mind, so I figured I inherited it at least! 1 Share this post Link to post Share on other sites
Pullstart 70,447 #23 Posted February 13, 2025 The weight chart I found, was purely for reference. I’m not the foundry 2 Share this post Link to post Share on other sites
Lee1977 7,688 #24 Posted February 13, 2025 (edited) Tractor Supply has them on line. Troy-Bilt weights 42# ship to store $74.89. Edited February 13, 2025 by Lee1977 2 Share this post Link to post Share on other sites
Pullstart 70,447 #25 Posted February 13, 2025 6 hours ago, Lee1977 said: Tractor Supply has them on line. Troy-Bilt weights 42# ship to store $74.89. That’s including 11.99 shipping. Order about 30 of them, and you’ll save a ton of money 1 Share this post Link to post Share on other sites
