mike avad 49 #1 Posted February 6 I have a 1976 B-80 wheel horse. the front rim seen to come lose on me and I'v clean the bolt and put Loctite on it and it still not keeping Tite it has 2 big washer one in the front and one in the back of the rim and a bolt to hold it in place. the other side seem to be ok but it just the one side that coming lose am thinking that the outer washer might not be setting right cuz when I titeing the bolt the rim is hard to turn. Share this post Link to post Share on other sites
Ed Kennell 43,804 #2 Posted February 6 Both are right hand threads, so the right one tends to tighten and the left one tends to loosen. A small punch mark on the outside thread of the nut may make it a locking nut. Share this post Link to post Share on other sites
mike avad 49 #3 Posted February 6 This doesn't have a locking nut on it just a bolt and when I tighting the bolt the wheel hard to move? Share this post Link to post Share on other sites
Ed Kennell 43,804 #4 Posted February 6 3 minutes ago, mike avad said: This doesn't have a locking nut on it just a bolt and when I tighting the bolt the wheel hard to move? Again, I have made a regular nut a locking nut y using a punch to make a small dent in the outside thread of the nut. Share this post Link to post Share on other sites
Ed Kennell 43,804 #5 Posted February 6 3 minutes ago, Ed Kennell said: Again, I have made a regular nut a locking nut y using a punch to make a small dent in the outside thread of the nut. Or just buy and use a nylock nut. Share this post Link to post Share on other sites
pfrederi 19,278 #6 Posted February 6 12 minutes ago, mike avad said: This doesn't have a locking nut on it just a bolt and when I tighting the bolt the wheel hard to move? The washer needs to press against the inner race of the bearing and nothing else. If it hits the outer race or the wheel hub it will jam the wheel when you tighten it. I bought some of these a few years ago use them on the left side... 2 Share this post Link to post Share on other sites
Handy Don 15,229 #7 Posted February 6 (edited) I think Mike is referring to the keeper bolt threaded into the spindle axle. No nut involved. Yes, if you are tightening the bolt and it “freezes” the wheel, something is not aligned or spaced correctly. Loctite’s role is to make an already tight mechanical connection stay tight. it will NOT hold a bolt that is still loose in the threaded axle. So, we need pictures and measurements. My instinct is that your front wheels' bushings or bearings combined with any washers on the axle on both sides are making the wheel too wide to fit under the bolt head with its smaller washer which fits only between the bolt head and the end of the axle. Edited February 6 by Handy Don 3 Share this post Link to post Share on other sites
ri702bill 10,596 #8 Posted February 6 Yup - what Don said. A BIT of "tightness" is desired to keep the inner bearing races from rotating on the spindle shaft, but only .002 to .005 inch preload.... Share this post Link to post Share on other sites
rmaynard 16,700 #9 Posted February 6 Try a thinner washer in the back. Share this post Link to post Share on other sites
Ed Kennell 43,804 #10 Posted February 6 1 hour ago, mike avad said: bolt to hold it in place Sorry Mike. My bad for not reading ...I thought it was a nut. Share this post Link to post Share on other sites
ri702bill 10,596 #11 Posted February 6 It sounds like at least washer fits over the spindle - it is too thick. Share this post Link to post Share on other sites
mike avad 49 #12 Posted February 6 OK thanks I'LL check that out Share this post Link to post Share on other sites
mike avad 49 #13 Posted February 6 OK thank you all for your reply I will check it out Share this post Link to post Share on other sites
kpinnc 16,224 #14 Posted February 6 Probably a good time to replace the bearings too. Even if your preload from the retaining bolt is a little tight, the bearing shouldn't have enough resistance to turn the bolt. In addition to too many washers, your bearings might be worn enough to allow binding under pressure. 1 Share this post Link to post Share on other sites
adsm08 3,871 #16 Posted February 6 6 hours ago, Handy Don said: . Yes, if you are tightening the bolt and it “freezes” the wheel, something is not aligned or spaced correctly. Loctite’s role is to make an already tight mechanical connection stay tight. it will NOT hold a bolt that is still loose in the threaded axle. You've never used the green stuff. We use that stuff to glue metal parts together. 1 Share this post Link to post Share on other sites
mike avad 49 #17 Posted February 7 Yes I have tried that didn't work I think I fix it look's a real thin washer behind the big one to meany on the outside of the rim. Thank you for your reply Share this post Link to post Share on other sites
