JCM 11,172 #1 Posted February 1, 2025 I have a 1978 Martin D-35 that needed some work so I found someone local that did some repair work done to it. He told me straight out he was NOT an authorized Martin Luthier at the onset. My reply was I didn't buy it to sell it and make money, I bought it because I wanted to have fun with it and the overall sound and look of it. So I had the neck reset and a few other things as well. He mentioned there was a hairline crack between the bridge pins but was sort of reluctant to tackle that. Does anyone have experience with how difficult of a job this is and how does it effect the playing and sound. Thanks 1 Share this post Link to post Share on other sites
6wheeler 676 #2 Posted February 3, 2025 IMO, if it is just hairline cracks? And, it is just between the pin holes? It probably won't really affect the sound at this point. But, as you probably know, If the cracks are vertical. Then the spruce top could start splitting. I am not a luthier by any means. I do some things on my guitars. But, not that in depth. If you notice it starting to buzz, you should be more concerned at that point. Maybe different strings would help to prolong the issue. And, make sure the humidity is good so it doesn't dry out. But again, I don't know that for sure, but it may slow down the damage. In our family we have many different brands of guitars, including a no name "kit" acoustic. We have Acoustic and Electric guitars. Mostly Fender and Gibson. I recently bought an Alvarez for me. And, a Breedlove for my wife. Because, just like this tractor hobby? You can't have too many. They are both acoustic electrics. I have not played either one on an amp yet. They both sound nice. Although, I am leaning more towards the Alvarez. Good Luck. 1 Share this post Link to post Share on other sites
JCM 11,172 #3 Posted February 5, 2025 Thank You @6wheeler for your response. If you would like to post anything including pictures about instruments check out Musical Instruments under Non Tractor Related May 7, 2022. Thanks Again. Much appreciated. Share this post Link to post Share on other sites
