Wayne0 1,164 #26 Posted January 26 20 hours ago, Beap52 said: Actually if a fellow was to keep his thumb over the spark plug hole and hooked the spark plug wire to your pinky, it might fire up! Ask @Pullstart 2 Share this post Link to post Share on other sites
Bill D 2,246 #27 Posted February 1 Any updates on this? Curious what you found. Share this post Link to post Share on other sites
S416-8 388 #28 Posted February 1 I been slammed at work but hope to get into it today. Found another loose wire that I need to find where it goes Share this post Link to post Share on other sites
S416-8 388 #29 Posted February 1 (edited) well got some time on it and get nothing.. I'm sure a big issue on why is the fact that the ignition switch is shot. Have a new key switch ordered and then will get the wires run to it IMG_3421[1].HEIC Edited February 1 by S416-8 Share this post Link to post Share on other sites
S416-8 388 #30 Posted February 2 finally got out to the tractor and after messing around with out without ever getting it to turn over I pulled the starter and no go.. took it apart and 2 of the wries to the brushes are bard and grounding against the case.. so start point looks to be a bew starter.. Share this post Link to post Share on other sites
S416-8 388 #31 Posted February 5 Starter should be here tomorrow. Not knowing how long this Sat is there anything that should be done re-test? I did add a small amount of oil in each piston and manually spun the motor but not sure if there’s anything that should be done with pumps. Thanks Share this post Link to post Share on other sites
S416-8 388 #32 Posted February 7 (edited) Update is that I got my starter and got it installed. I wasn't able to get it started but it truns over, has great compression so now I acan work on getting plug for the ket swicth wired in, The new swich has it being deliverd tomorrow.... Edited February 7 by S416-8 wording 2 Share this post Link to post Share on other sites
S416-8 388 #33 Posted February 11 First signs of life. New switch and starter on now and got her to fire with a little gas in the carb now to drain the tank change the oil and get her running for real. Need to find what battery it needs because my spare doesn’t have the kick to it. Any fluid and filter recommendations would be great. Thanks Share this post Link to post Share on other sites
RED-Z06 2,567 #34 Posted February 11 2 hours ago, S416-8 said: First signs of life. New switch and starter on now and got her to fire with a little gas in the carb now to drain the tank change the oil and get her running for real. Need to find what battery it needs because my spare doesn’t have the kick to it. Any fluid and filter recommendations would be great. Thanks Ive started these on 145cca batteries with temps in the 60s without any real drama, 275cca would be more comfortable, but the 145cca did it fine. Share this post Link to post Share on other sites
S416-8 388 #35 Posted February 11 ok thanks.. will grab a new battery with the assumption that the other is weak seeing it struggles a bit Share this post Link to post Share on other sites
S416-8 388 #36 Posted February 11 (edited) Its alive. Using a bottle of gas and some starter fluid I got it running. Runs smooth and strong so now for the real work Found a couple issues - rotted fuel lines, no hydro fluid so need to find out what type of hydro fluid to get. Also notice that there is a 2nd blank area for a hydro lift on the dash.. is there an optional 2nd hydo control for this? Edited February 12 by S416-8 added info Share this post Link to post Share on other sites
S416-8 388 #37 Posted February 21 I’m in need of a cure. Still going through the first D and in my crazy head I bought a D200. Hope to get that one in a couple weeks so I’ll be living with monsters. Share this post Link to post Share on other sites
pfrederi 18,634 #38 Posted February 21 On 2/11/2025 at 3:39 PM, S416-8 said: Its alive. Using a bottle of gas and some starter fluid I got it running. Runs smooth and strong so now for the real work Found a couple issues - rotted fuel lines, no hydro fluid so need to find out what type of hydro fluid to get. Also notice that there is a 2nd blank area for a hydro lift on the dash.. is there an optional 2nd hydo control for this? Yes two lifts Mid mount and three point Share this post Link to post Share on other sites
S416-8 388 #40 Posted February 22 Got the electric fuel pump instealled and got it to start and run,, for 2 min's and then died and wasn't able to get it running again. Pulled the plugs and the right was wet and left dry neither looked bad but will replace these tomorrow. slowely we'll get her going.. Really tempted to find a rebuild kit for the carbs and just go ahead and get that out of the way.. Share this post Link to post Share on other sites
S416-8 388 #41 Posted February 23 Finally was able to pick up a spark plug tester and the only spark I am getting is when I first turn on the key, after that nada. Will first double check all the wires to make sure things are connected. I am guessing it may end up being a coil but open to other ideas.. thankjs Share this post Link to post Share on other sites
RED-Z06 2,567 #42 Posted February 23 Make sure you're getting a consistent 12v to the + side of the coil, with 12v power, the ignition module pulses a ground signal to the - side of the coil to create the spark. 1 Share this post Link to post Share on other sites
lynnmor 7,789 #44 Posted February 24 14 hours ago, S416-8 said: Finally was able to pick up a spark plug tester and the only spark I am getting is when I first turn on the key, after that nada. Will first double check all the wires to make sure things are connected. I am guessing it may end up being a coil but open to other ideas.. thankjs I'm only guessing because I don't know if you have an Onan or Kohler engine. It would help if you included the year and engine when discussing ignition issues so we don't have to go back thru all of your posts. If you have an Onan, download the Onan Service Manual and do the troubleshooting of the ignition module. Share this post Link to post Share on other sites
S416-8 388 #45 Posted February 24 Sorry didn’t catch I never added that. It’s a 73 18 automatic with the kohler. I downloaded the manual for the engine and will print it out today Share this post Link to post Share on other sites
RED-Z06 2,567 #46 Posted February 24 I thought we were talking about a 520-H Share this post Link to post Share on other sites
S416-8 388 #47 Posted February 24 Sorry crossed threads multitasking too much. Sorry. The 520 issue did turn out to be a valve seat. Not t sure if I’ll go have that fixed or not. Now I also picked up 2 new projects. 73 18Automatic and a D200. Sorry again about crossing the post Share this post Link to post Share on other sites
RED-Z06 2,567 #48 Posted February 24 1 hour ago, S416-8 said: Sorry crossed threads multitasking too much. Sorry. The 520 issue did turn out to be a valve seat. Not t sure if I’ll go have that fixed or not. Now I also picked up 2 new projects. 73 18Automatic and a D200. Sorry again about crossing the post In that case you can test the coil about the same way, the coil gets 12v through the + side; and the points ground the - side to create spark Share this post Link to post Share on other sites
