Red Stallion 231 #101 Posted January 6 (edited) I thought I had updated this, but many of you know where I (sadly) got to. Put it alm back together. Everything is looking great. Starter kicks every time, engine fires up within a few cranks. Happily goes forward and backward. Starting to feel pretty good, albeit a bit of changy noise. So I decided to check the vale lashing because I was pretty certain that the noise was coming from there. Strip it all apart, and sure enough the back valves probably had about 2mm of clearance. But worse upon closer inspection the dreaded valve seat looks cracked/loose or worse. Ordered some new head gaskets, due to arrive soon, and I'll pull the heads and then weigh up repower pr find someone who can resleeve with oversized valves. A bit disappointing after spending a year of refurbishing, just to have the engine cactus! Edited January 6 by Red Stallion 1 Share this post Link to post Share on other sites
Red Stallion 231 #102 Posted January 6 At least it looks pretty 2 Share this post Link to post Share on other sites
lynnmor 9,081 #103 Posted January 6 The problem is that you have two threads running about the same issue. You should not be running that engine till the valve issue is determined, that photo isn't telling me what is going on and you should have pulled that valve and taken pictures so we can clearly see. Continued running the engine will surely destroy it if the valve seat is loose. 1 Share this post Link to post Share on other sites
Red Stallion 231 #104 Posted January 6 Yeah, my innocent question in the other section, will now get merged into this main thread so I can track the history. I have not run the motor since the discovery. Still waiting for the gaskets which are now in the country, so hopefully might arrive by the weekend. Even moving it around the place, I'm back to pushing it by hand. I'm about 50/50 on doing a repower. While I like to keep things original the cost of obtaining Onan spares in Australia will make you fall off your chair (for example the oil filter seals are $35) plus I think the hot Aussie climate doesn't suit the engine setup without modification. Which gets me thinking that a cheap new motor is probably going to be as expensive and as big of a headache as a refurbished P220. But I'm still not there yet. Share this post Link to post Share on other sites
Handy Don 17,735 #105 Posted January 6 (edited) 6 minutes ago, Red Stallion said: Onan spares in Australia will make you fall off your chair No need to feel any jealousy. OEM grade Onan spares in the USA are quite pricey as well! Yet, they are what you want for important gaskets--heads, manifolds, etc. Edited January 6 by Handy Don Share this post Link to post Share on other sites
kpinnc 19,107 #106 Posted January 7 (edited) 8 hours ago, Red Stallion said: Which gets me thinking that a cheap new motor is probably going to be as expensive and as big of a headache as a refurbished P220. But I'm still not there yet. This is just my opinion, so take it as nothing more. That being said, I have to agree with you. At some point, you have a decision to make about that engine. Me personally, I stopped trying to coax more hours out of my Onan engines. Especially true of the 20hp models. If I had a P216, I'd probably have a different opinion. I have 3 P220 engines and I will no longer spend my time and money on them. While no one can argue that they are exceptional when in good shape, the climate here in the southern US is not good for them. The heat and humidity is hard on them, and they are simply too expensive for my tastes. The climate where you are is far worse than what we have here, so I can't imagine the level of pampering you will have to apply to that engine to keep it running. I would say this- if you pick an engine to repower with, do your homework and pick a good one. It's no secret that I am a fan of small block Vanguards (23hp and below) but there are plenty of good options. The tractor itself that you have is solid and will last decades more if properly maintained. The Eaton 1100 transmission is also sensitive to heat but it is easily mitigated with just keeping it externally clean and serviced. Good luck with whatever decision you make. The machine you have is definitely worth saving. If done right it will serve you well. Edited January 7 by kpinnc 1 Share this post Link to post Share on other sites
Red Stallion 231 #107 Posted January 7 That last comment is what motivating me. The rest of the 520HC is brilliant. Its rock solid, reliable, and will last me forever. To date I've spent $2k, and if I spent another $2k, it'll deliver me excellent value for money... (Or something about sunk cost fallacy) 1 Share this post Link to post Share on other sites
Handy Don 17,735 #108 Posted January 7 7 hours ago, Red Stallion said: (Or something about sunk cost fallacy) Engineering economics course in college...there was a question about this on the final related to asset valuation. Then later, in advanced accounting, it came up again! 1 Share this post Link to post Share on other sites
Red Stallion 231 #109 Posted January 8 7 hours ago, Handy Don said: Engineering economics course in college...there was a question about this on the final related to asset valuation. Then later, in advanced accounting, it came up again! As an engineering project manager I'm constantly battling the ego of "but I can make it work" and the pragmatic "it was a bad call from day one and continues to be a waste of money". I'm generally okay with it. 1 Share this post Link to post Share on other sites
kpinnc 19,107 #110 Posted January 8 1 hour ago, Red Stallion said: I'm constantly battling the ego of "but I can make it work" and the pragmatic "it was a bad call from day one and continues to be a waste of money". I have quite a few threads on here over the years where I modify and fabricate different stuff on my tractors. While many are successful, there are alot of things I don't put up when they just don't work out. Of course for me this has been part of the learning process, and this is also part of the fun at times too. Of course very little of what I work with is free, and I have several machines so if one is down I have others to cover whatever work needs to be done. If I only had one, I'd likely not make so many modifications. Point being? You need a couple more tractors to rotate through the worker lineup. 1 2 Share this post Link to post Share on other sites
Red Stallion 231 #111 Posted January 8 11 minutes ago, kpinnc said: Point being? You need a couple more tractors to rotate through the worker lineup. I probably already own 25% of the entire Wheelhorse 520hc fleet in Australia! I'm yet to find another one. I bought it because I had land that needed a small tractor and mower. But I dont have that anymore, so really its just for the love of it.... (Until I buy a new place) 3 Share this post Link to post Share on other sites
cleat 9,449 #112 Posted January 8 One of my 520's has a 16 HP Onan P216 and honestly you can't tell the difference in power so if you can find a donor machine with a 16, 18, or 20HP Onan, it will be a bolt in. That said, I plow snow with my 510HC and I have to admit that it is my favorite Whee Horse model. Share this post Link to post Share on other sites
Handy Don 17,735 #113 Posted January 8 13 hours ago, kpinnc said: Point being? You need a couple more tractors to rotate through the worker lineup. Yeah, it’d be nice to have room for another one. 13 hours ago, Red Stallion said: I probably already own 25% of the entire Wheelhorse 520hc fleet in Australia! I'm yet to find another one. Interesting statistic. I’ve yet to see another Wheel Horse anywhere in my village so my percentage for this 10 square miles may be higher! 1 Share this post Link to post Share on other sites
Red Stallion 231 #114 Posted February 22 I've decided to run my engine out until it dies properly. The noise was definitely from the valve lashings, as I put it all back together last night, and the noise has gone away. Onan P220g engines are basically non-existant down here in Australia. Parts are impossible to find, or I'm paying more for freight from the US than I am for the part. That plus the engine configuration apparently does not like the hot weather down here. However, I don't want to let the beast die out forever. So I'm looking into engine swaps. There are few reasonably priced v twin engines, but for now I'm putting it into the "future project" bucket as I've sold the land I had bought it for, so I don't have much of a use for a mini-tractor at the moment. But it's been a fun little project taking it from and old gunked up machine that was tricky to start, and now it fires every time after a couple of cranks of the starter. Thank you to everyone for your wealth of knowledge, especially for @lynnmor. I can tell your very passionate about these machines. 2 3 Share this post Link to post Share on other sites
