Easton Rich 1,230 #126 Posted February 7, 2025 Another $200 down the drain 1 Share this post Link to post Share on other sites
ebinmaine 78,849 #127 Posted February 7, 2025 Did you not have any of these parts? Share this post Link to post Share on other sites
Easton Rich 1,230 #128 Posted February 7, 2025 Nope Share this post Link to post Share on other sites
Easton Rich 1,230 #129 Posted February 7, 2025 The motor came with a carb only. It was free 2 Share this post Link to post Share on other sites
Achto 31,805 #130 Posted February 8, 2025 Does your club require a tether switch on the back of the tractor? Our club requires one that will kill the ignition and the fuel pump. For this reason I had to run an electric fuel pump on mine. Not that I mind, the one I purchased was very reasonable. https://www.amazon.com/Electric-Universal-Pressure-Transfer-Carburetor/dp/B08PY7V2MM/ref=sr_1_1_sspa?crid=2N1RZQLUTWUU1&dib=eyJ2IjoiMSJ9.00CP0jhSZANBDuq1qwWJpDrikNZvuRfTdQfDTkG33jZvW5Q1vRFaDlXhEnBARTMgGtHCsiT3RkWRSng3wTFx1ZqmAGWANAqqpSUC8SJ475mcRp7lP69inxuWc7k9MwsPq3p26QMIDzuRzMKLMxYKnaGnq8KDX3CbjfQTgjParknLNOe8la-Ed5Wdft7lDmTZVjoJwkBy6eQEh_CXyCRp-REDdOcPiJ3qJ2ndCRyfOv4.NxZo3V9wrKnOpAx2MZMqc4ud2Ci3WeUJewZyRlPGI9o&dib_tag=se&keywords=low+pressure+electric+fuel+pump&qid=1738976360&sprefix=low+pressure+el%2Caps%2C165&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 Share this post Link to post Share on other sites
Easton Rich 1,230 #131 Posted May 15, 2025 Hey, it’s been awhile but I’m back! We will paint this bad boy and get back on the engine! And to answer your question @Achto they do. How do you guys think I could fit some 26x12-12 on it? Anything appreciated 1 Share this post Link to post Share on other sites
ebinmaine 78,849 #132 Posted May 15, 2025 5 hours ago, Easton Rich said: How do you guys think I could fit some 26x12-12 on it? Anything appreciated 26 inch diameter tires won't fit without modifying the tractor. You'll have to raise the seat pan (fairly easy) AND you'll have to move the axle further away from the side steps (not easy) If you use 24x12.00-12 those will fit. Barely. 1 Share this post Link to post Share on other sites
Achto 31,805 #133 Posted May 15, 2025 7 hours ago, Easton Rich said: How do you guys think I could fit some 26x12-12 on it? Anything appreciated To fit 26x12x12 tires on my C101-ish I added 1/2" to the top of the riser under the seat. Pictures are in reverse order. This gave ample clearance from the tire to the fender. Had to do a little bending & grinding on the edge of the running board where it come close to the tire, but not much. 3 1 Share this post Link to post Share on other sites
Easton Rich 1,230 #134 Posted May 15, 2025 I might have to run 24x12-12s because this is a short frame sooooo… we’ll see! Share this post Link to post Share on other sites
ebinmaine 78,849 #135 Posted May 15, 2025 3 minutes ago, Easton Rich said: I might have to run 24x12-12s because this is a short frame sooooo… we’ll see! Is the Commando a short? Won't matter though.... The difference between short medium (1974 and 75 B80) and long is at the front. Rear fender areas are the same. Share this post Link to post Share on other sites
Easton Rich 1,230 #136 Posted May 16, 2025 It’s a commando frame and fenders with a b80 hood and foot rests. Pretty cobbled together 1 Share this post Link to post Share on other sites
Easton Rich 1,230 #137 Posted May 20, 2025 For those of you who have flipped your front axle, how did you get it so the tires aren’t angled? Share this post Link to post Share on other sites
Easton Rich 1,230 #138 Posted February 16 Back on the puller! Its been a long time, but its gone thru many changes! Still a roller but I've stockpiled a TON of parts to make this work. Its now a long frame, but still has the same rear half that it did. Instead of a 10hp, its now gonna get a stroked 14hp that was N.O.S when I bought it for $5 at an estate sale. Oh by the way, @Achto this your fault lol. I just put a LSD 8spd under it so I should be good to go after the motor goes on. Its found its way to the very back of my pile where its been for a year now 1 Share this post Link to post Share on other sites
Handy Don 16,603 #140 Posted February 16 (edited) 2 hours ago, Easton Rich said: I just put a LSD 8spd under it so I should be good to go As @Achto discovered, the LSD and pulling are perhaps not a great combination. The LSD’s design is far from a true posi-traction--it provides some, but not a lot, of power to a slipping-side wheel. To accomplish this, anytime the wheels are rotating at different speeds, there is metal-to-metal friction between the ends of the pinion gears and the diff body trying to make the wheels turn at the same speed. Over time, this wear lessens the engagement between the pinion teeth and the axle gear teeth. When the wear progresses far enough, the gear slips and that begins a rapid unplanned stripping of lots of teeth. Edited February 17 by Handy Don Share this post Link to post Share on other sites
Achto 31,805 #141 Posted February 16 (edited) 3 hours ago, Easton Rich said: I just put a LSD 8spd under The 8 speed is not an LSD. The 6 speed 10 pinion's were LSD. The 8 speed 8 pinion open is a much better tranny though. If that is what you have, then you have 's strongest tranny. 3 hours ago, Easton Rich said: Oh by the way, @Achto this your fault lol. My wife says that I'm very good at being a bad influence. Given that fact. As long as you have that 14hp apart, might I suggest a cam up grade. I plan on building a new "stock"16hp engine for mine this year and want to up grade to a K361 18hp cam ( which is hard to find ) Vogel Manufacturing will take your original cam, spray weld it, and regrind it to slightly better specs than the K361 cam. Yet it will still pass "stock" spec rules in my club. I am planning on going with their V375-CH-4K grind. https://vogelmanufacturing.com/product/single-cylinder-cast-camshaft-stock-class-grind-4-000-rpm-range/ Some 14hp blocks can also be board out to a 16hp. You need to measure the outside of the bottom of the cylinder to see if you have enough meat to do it. Not enough meat and the cylinder will break away from the block. One advantage of doing this is that the piston is centered to the crank on a 14hp. The piston is slightly off set on a 16hp. Having the top of the block fly cut .010" to .020" will allow the piston to pop up above the cylinder creating more compression. Having the head fly cut / shaved .020" to .040" will create more compression while still retaining the gasket embossing so that you can pass stock specs. All this leads to my favorite formula for engine building ( HP = $ ) Edited February 17 by Achto 1 Share this post Link to post Share on other sites
Easton Rich 1,230 #142 Posted February 17 Thanks for shedding some light on that. I planned to put a cam in it, shave the head, and put a copper gasket on it. We will see what money will allow 1 Share this post Link to post Share on other sites
Achto 31,805 #143 Posted February 17 38 minutes ago, Easton Rich said: copper gasket on it I've read that a copper gasket is only recommended if you are running a billet head. Share this post Link to post Share on other sites
Easton Rich 1,230 #144 Posted February 17 Oh ok. Will a normal one hold? I saw yours blew after a pull. Share this post Link to post Share on other sites
TonyToro Jr. 2,417 #145 Posted February 17 38 minutes ago, Achto said: I've read that a copper gasket is only recommended if you are running a billet head. I have a fully built engine. (Cam,rod,piston,crank,carb,valves etc) and even after running it on the dyno, Save your money and use a stock one. 2 Share this post Link to post Share on other sites
Easton Rich 1,230 #146 Posted February 17 Ok thank you 1 Share this post Link to post Share on other sites
Easton Rich 1,230 #147 Posted February 17 @Achto and @TonyToro Jr. you seem to be the experts on this. What would be the best cam grind from Vogel if I shave the head down .50, maybe a solid flywheel, and run bigger valves? I’m looking to make anywhere from 22-25hp? I’m new so bear with me here. Share this post Link to post Share on other sites
Achto 31,805 #148 Posted February 17 3 hours ago, Easton Rich said: Will a normal one hold? I saw yours blew after a pull. My first gasket did not have a fire ring. Replacement gasket does have a fire ring, been running a long time with the new gasket. 1 Share this post Link to post Share on other sites
Achto 31,805 #149 Posted February 17 1 hour ago, Easton Rich said: What would be the best cam grind from Vogel Do you have list of rules for the class that you want to pull in? The cam I chose will pass the "stock" specs in the club I pull with. It may not pass for "stock" with other clubs. 1 Share this post Link to post Share on other sites
Easton Rich 1,230 #150 Posted February 17 (edited) Bore can’t be more than .030 over, head can’t be shaved more than .050, and I can’t remember cam specs, but they were pretty big. Don’t want anything too crazy. Just looked, and I can’t run a solid flywheel over 22lbs in stock class. Edited February 17 by Easton Rich 1 Share this post Link to post Share on other sites
