Easton Rich 601 #126 Posted February 7 Another $200 down the drain 1 Share this post Link to post Share on other sites
ebinmaine 71,775 #127 Posted February 7 Did you not have any of these parts? Share this post Link to post Share on other sites
Easton Rich 601 #129 Posted February 7 The motor came with a carb only. It was free 2 Share this post Link to post Share on other sites
Achto 29,223 #130 Posted February 8 Does your club require a tether switch on the back of the tractor? Our club requires one that will kill the ignition and the fuel pump. For this reason I had to run an electric fuel pump on mine. Not that I mind, the one I purchased was very reasonable. https://www.amazon.com/Electric-Universal-Pressure-Transfer-Carburetor/dp/B08PY7V2MM/ref=sr_1_1_sspa?crid=2N1RZQLUTWUU1&dib=eyJ2IjoiMSJ9.00CP0jhSZANBDuq1qwWJpDrikNZvuRfTdQfDTkG33jZvW5Q1vRFaDlXhEnBARTMgGtHCsiT3RkWRSng3wTFx1ZqmAGWANAqqpSUC8SJ475mcRp7lP69inxuWc7k9MwsPq3p26QMIDzuRzMKLMxYKnaGnq8KDX3CbjfQTgjParknLNOe8la-Ed5Wdft7lDmTZVjoJwkBy6eQEh_CXyCRp-REDdOcPiJ3qJ2ndCRyfOv4.NxZo3V9wrKnOpAx2MZMqc4ud2Ci3WeUJewZyRlPGI9o&dib_tag=se&keywords=low+pressure+electric+fuel+pump&qid=1738976360&sprefix=low+pressure+el%2Caps%2C165&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 Share this post Link to post Share on other sites
Easton Rich 601 #131 Posted May 15 Hey, it’s been awhile but I’m back! We will paint this bad boy and get back on the engine! And to answer your question @Achto they do. How do you guys think I could fit some 26x12-12 on it? Anything appreciated 1 Share this post Link to post Share on other sites
ebinmaine 71,775 #132 Posted May 15 5 hours ago, Easton Rich said: How do you guys think I could fit some 26x12-12 on it? Anything appreciated 26 inch diameter tires won't fit without modifying the tractor. You'll have to raise the seat pan (fairly easy) AND you'll have to move the axle further away from the side steps (not easy) If you use 24x12.00-12 those will fit. Barely. 1 Share this post Link to post Share on other sites
Achto 29,223 #133 Posted May 15 7 hours ago, Easton Rich said: How do you guys think I could fit some 26x12-12 on it? Anything appreciated To fit 26x12x12 tires on my C101-ish I added 1/2" to the top of the riser under the seat. Pictures are in reverse order. This gave ample clearance from the tire to the fender. Had to do a little bending & grinding on the edge of the running board where it come close to the tire, but not much. 2 Share this post Link to post Share on other sites
Easton Rich 601 #134 Posted May 15 I might have to run 24x12-12s because this is a short frame sooooo… we’ll see! Share this post Link to post Share on other sites
ebinmaine 71,775 #135 Posted May 15 3 minutes ago, Easton Rich said: I might have to run 24x12-12s because this is a short frame sooooo… we’ll see! Is the Commando a short? Won't matter though.... The difference between short medium (1974 and 75 B80) and long is at the front. Rear fender areas are the same. Share this post Link to post Share on other sites
Easton Rich 601 #136 Posted May 16 It’s a commando frame and fenders with a b80 hood and foot rests. Pretty cobbled together 1 Share this post Link to post Share on other sites
Easton Rich 601 #137 Posted May 20 For those of you who have flipped your front axle, how did you get it so the tires aren’t angled? Share this post Link to post Share on other sites
