cleat
Got another one. A 416 this time.
sqrlgtr
On 2/6/2026 at 10:11 AM, cleat said:
416 Anniversary complete except for final setup of carb and hydro, and hood which will be completed next summer.
Wife took this picture.
She laughed at me taking my shoes off to sit on the tractor.
113647095_416Anniversarycompleteexceptforfinalsetupandhood2.JPG.231649c1313b839b37dd2bac4c8468d5.JPG
She's not the only one :ychain:
c-series don
As expected, it came out looking better than new! I think I speak for everyone when I say that we are already looking forward to your next project!👍🏻
ebinmaine
ABSOLUTELY
eric8
On 1/31/2026 at 8:10 AM, cleat said:
Seat pivot plate ready to bolt to seat assembly.
131994147_Seatpivotplatereadytobolttoseatassembly1.JPG.b8c727717f2145aabab748dbdc93e3df.JPG
1834986934_Seatpivotplatereadytobolttoseatassembly2.JPG.2d3ca7ef2564fbc75ba3f520070efb42.JPG
Seat bumper, fender washer, and bolt ready to install.
1209200090_Seatbumperwasherandboltreadytoinstall.JPG.70718b93d6b16ee870c66164609a6359.JPG
Seat pivot plate bolted to seat assembly.
All 8 bolts tightened.
I have the seat set to full rearward position.
605063677_Seatpivotplateboltedtoseatassembly1.JPG.342acdc1ef7a5e068906545d78ee2bfb.JPG
48741990_Seatpivotplateboltedtoseatassembly2.JPG.12b8324b5050d3b34df2612fa62468cd.JPG
1381078479_Seatpivotplateboltedtoseatassembly3.JPG.63053ef50b12352fea7fe4ea9336a3f5.JPG
My 1993 520h has no sort of seat bumper installed.  The rear 5/16" bolt heads are making contact with the rear fender pan, metal on metal.  My 520 parts catalog shows a "BUMPER SJ5514 BLACK Part #111071" that should be there.  Apparently these are made by 3m and called "Bumpon" bumpers that install with adhesive?  I assume on the rear fender pan directly beneath the bolthead?  I like the looks of these a lot better.  Do you have a part number and source?
cleat
I used this for the search on ebay.
Rubber Feet 1-1/2
If you look around the listings hopefully you will find some with a 5/16" center hole for the mounting bolts, I got lucky and found some.
kpinnc
I bought rubber bumpers more than 20 years ago and glued them on the fender on my 314-8 where the springs would contact the fender. Never had an issue with them coming loose.
About 2 inch diameter but 1.5 inches tall.
eric8
Thanks to both of you for the ideas!
eric8
Posted (edited)
I took a closer look today once home from work and found some “witness marks” from where the OEM bumpers were placed.  Just aft of the rear seat tray bolts.  Attached is photos of the OE bumpers just for reference.  I’m normally a stickler for keeping things factory pure, but this is one case when I think your through bolt with a donut bumper is far superior
edit: I’m referencing my 93 520h’s factory setup.  I realize this post was about a 416, so they may have been different
Edited by eric8
eric8
OE stick on bumper side view
ebinmaine
(Many various parts)
is far superior
I look at it this way. ... Wheelhorse Parts were well known to be Standard Parts whenever possible.
They used whatever pieces were readily available on the market when the machines were built.
Sometimes factory is best.
Times change.
Technology changes.
Sometimes we can replace originals with far superior modern items.
  • Like 4
MainelyWheelhorse
Same here, especially if I'm unsure about the routing of something. I check @cleat's posts.
kpinnc
Posted (edited)
...And so do I! :lol:
Maybe if I had access to a decent "factory correct" machine I might feel different. Yeah, no probably not. :rolleyes:
None of my tractors are particularly collectible. My 867 and 701 are as good as I will likely ever have. Even those have small tweaks. But I love them all and enjoy making certain changes to build them how I want them.
I am impressed by perfect restorations. @cleat has undoubtedly the most thorough restorations of any I've ever seen! :thumbs: Sadly if I were to hold out for that one missing part here and there, I'd have a garage full of unfinished projects.
Edited by kpinnc
