cleat
Got another one. A 416 this time.
cleat
Hydraulic hose grommet ready to be installed.
1105763221_Hydraulichosegrommetreadytobeinstalled.JPG.4567936fc87bfc44a698ee145c851f98.JPG
Hydraulic hose grommet installed.
Hydraulic supply line temporary plug removed, ready for valve installation.
2135254718_Hydraulicsupplylinereadyforvalveinstallation.JPG.3a578f78b90841e10b7b8fc0a2c5444f.JPG
Hydraulic valve assembly ready to be installed.
2010822105_Hydraulicvalveassemblyreadytobeinstalled.JPG.ea54b094c4f6cd806717594e8f7e13ae.JPG
Hydraulic valve assembly installed.
Hydraulic hoses ready to connect to cylinder.
1540220711_Hydraulichosesreadytoconnecttocylinder.JPG.6308d9648f37de3f25e025d12e34638a.JPG
Hydraulic hoses connected to cylinder.
1947348625_Hydraulichosesconnectedtocylinder.JPG.0f597fa3424fef02cf69c9720e8a2614.JPG
Hydraulic return line ready to be installed.
1119397571_Hydraulicreturnlinereadytoinstall1.JPG.741eb7178d019e8f0e6fb8b3e0c5a8d2.JPG
1189105285_Hydraulicreturnlinereadytoinstall2.JPG.b1d9dc2cff215307931ad8cfb08417f5.JPG
Hydraulic return line installed.
Hydraulic lines and fittings tightened at valve.
477383647_Hydrauliclinesandfittingstightenedatvalve.JPG.7b9e65f399477536f16ee7c73ebdef7e.JPG
Hydraulic lines and fittings tightened at filter adapter.
1173411955_Hydrauliclinesandfittingstightenedatfilteradaptor.JPG.df050f99f8ae5c72fb04008b65221b4d.JPG
Hydraulic supply line tightened at pump.
1352817483_Hydraulicsupplylinefittingtightenedatpump.JPG.f7b2e72d7ad81b6cfeba9b398c84c91a.JPG
Overview as of today.
  • Excellent 3
cleat
Hydro belt tension pivot rod assembly ready to be installed.
Hydro belt tension pivot rod bushing installed.
120497315_Hydrobelttensionpivotrodbushinginstalled.JPG.ac4fa48ccc92fbd2fa6b5f0f156c3d51.JPG
Hydro belt tension pivot rod wave and flat washers installed.
1143635239_Hydrobelttensionpivotrodwaveandflatwashersinstalled.JPG.0fe1817939a335a4fcc532f2728a481f.JPG
Hydro belt tension pivot rod greased at pivot points.
Hydro belt tension pivot rod spring installed.
1583868962_Hydrobelttensionpivotrodspringinstalled.JPG.1110eee3ecfa7ecf740194cef7f116fa.JPG
Hydro belt tension pivot rod slid into bushing and hoodstand.
Spring slid onto anchor bolt and nut spun on finger tight.
429130599_Hydrobelttensionpivotrodandspringinstalled.JPG.12c2fd63494852b092f077442db1e825.JPG
Hydro belt tension pivot rod washer and E clip installed.
190251112_HydrobelttensionpivotrodEclipinstalled.JPG.dbbcfcae5914fffb1401fe306f39f096.JPG
Hydro belt tension spring nyloc nut turned in until excess play is removed but spring is not clamped tight.
cleat
Snow storm from last Wednesday knocked out our internet and that was still out this morning when the power went out.
Power came back on after 4 hours. Luckily it was only -9 out so the house only cooled down to 15 degrees C.
When the power came back on the satellite dish also had melted off so I now have power and internet.
My post yesterday was through my phone that works so long as I am standing just outside the shop.
cleat
Parking brake lever assembly ready to install.
I am installing an early style as I do with all of my builds as I don't like the later style with the plastic knob on the left side.
266075114_Parkingbrakeleverassemblyreadytoinstall.JPG.6ee39aa735db0a60dddaa72ade2a5f45.JPG
Parking brake bolt, washers, and spacer installed.
Never seize on the SS bolt.
2106908740_Parkingbrakeboltwashersandspacerinstalled.JPG.8e74e7dadb2f9f53453d57044a3f2939.JPG
Parking brake lever assembly installed and nut torqued to 30 ft/lb.
491794515_Parkingbrakeleverassemblyinstalled.JPG.9e75220247a1fbeaa22342dbfaba61df.JPG
Parking brake lever spring installed.
Shift cover plate sat in place to verify parking brake lever location.
I cut out the slot for the parking brake earlier this past summer.
1853257228_Shiftcoverplatesatinplacetoverifyparkingbrakeleverlocation.JPG.f4dfad637a27eb6d418b4bb5c4261486.JPG
Adjusted brake spring according to manual.
Edited by cleat
  • Like 5
cleat
Front fender bracket ready to install.
Note the large washers that will hopefully prevent the Hoodstand from cracking again.
1411802094_Frontfenderbracketreadytoinstall1.JPG.9a3e000a784ea29204b6c48aff053056.JPG
1340393569_Frontfenderbracketreadytoinstall2.JPG.02c77162752f43a3deb906fb9f568167.JPG
Front fender bracket bolted into place just loose enough that it will move around.
2082087984_Frontfenderbracketinstalledandboltstorquedto204in-lb.JPG.0670e91b81efb12f2b54998b92c1a632.JPG
Fender sat on to verify bracket placement.
Turns out front fender bracket needs to be moved forward as far as possible for the holes to all line up.
I then removed the fender and checked to be sure the front fender bracket is square by measuring to the hoodstand as shown.
Both sides were 7-7/8" so good there.
1040200137_Frontfenderbracketmeasuringtoverifyitissquare1.JPG.23059ec009c31d862714e39b40cfc2db.JPG
1851125305_Frontfenderbracketmeasuringtoverifyitissquare2.JPG.bad54cb4639917d76e28e5f94e818651.JPG
I then measured side to side from hoodstand to outer edge of front fender bracket.
Just over 2-3/4" both sides.
701656874_Frontfenderbracketmeasuringtoverifyitiscentered.JPG.eabe6f96f16d15d4a2dc77ae437c660f.JPG
Front fender bracket bolts torqued to 204 in/lb.
Shown here are the large washers installed.
They are different only because that is all I had on hand.
1103234709_Frontfenderbracketinstalledshowingwashersandnylocnut1.JPG.ed1629bb4c7db316c6fb73dc941dc58f.JPG
383441370_Frontfenderbracketinstalledshowingwashersandnylocnut2.JPG.d388953445546b630a54c79086a8540e.JPG
  • Excellent 2
ebinmaine
Precision
Handy Don
10 minutes ago, cleat said:
This close tolerance would bug me until I’d emoved and shortened the bolt. :confusion-shrug:
And I am not nearly as meticulous as you are!
cleat
Sorry, the camera angle made it look close.
I can actually fit a finger between the bolt and the hydraulic line.
cleat
As recommended by Handy Don, I replaced the 5/16 x 1" bolt with a 5/16 x 3/4" bolt.
It protrudes through the nyloc by a full thread so it is good to go.
Handy Don
And you “just happened” to have that shorter bolt on hand. I’m still in awe of your work! ;)
cleat
One of the advantages of working at a large company (DuPont) and having my site shut down after cutting the maintenance department down to just me as the sole millwright is I got to take home truckloads of hardware.
This is a bit of it.
