oliver2-44 11,750 #126 Posted November 21, 2025 (edited) @cleat what finish paint are you using? Edited November 24, 2025 by oliver2-44 Share this post Link to post Share on other sites
cleat 9,333 #127 Posted November 21, 2025 Lower steering shaft support block ready to install. Block has new bronze bushings installed top and bottom. Bolts are 1-1/2" long and fit perfect even though parts manual calls for 1-3/4". Lower steering shaft showing slotted nut. Nut removed from lower steering shaft then shaft greased where it slides into block. Block slid onto lower steering shaft then bolted to frame. Bolts torqued to 30 ft/lb. Grease fitting installed. Never seize applied to shaft threads then washer and nut loosely installed. Overview of steering assembly as installed. 2 4 Share this post Link to post Share on other sites
cleat 9,333 #128 Posted November 21, 2025 9 hours ago, oliver2-44 said: @cleat what finish paint are you using? I used Home Hardware brand international harvester red for most of the tractor parts either by spray gun or using aerosol cans for small parts. For areas where a higher quality finish is requires such as the rear fender and the hood (which will be next summer), I used Tremclad farm and implement international harvester red. Of course I used primer made by the same manufacturer under the paint applied. For the black I use Home Hardware gloss or semi-gloss as required. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #129 Posted November 21, 2025 8 hours ago, cleat said: Block has new bronze bushings installed top and bottom. I'd love to learn how to do this eventually 2 1 Share this post Link to post Share on other sites
Bill D 3,156 #130 Posted November 22, 2025 1 hour ago, ebinmaine said: I'd love to learn how to do this eventually I've done it. I'm sure you could too. You have the drill press for it now. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #131 Posted November 22, 2025 2 minutes ago, Bill D said: I've done it. I'm sure you could too. You have the drill press for it now. Need to figure out some angles and clamping... 1 Share this post Link to post Share on other sites
Bill D 3,156 #132 Posted November 22, 2025 On 11/18/2025 at 12:38 PM, c-series don said: I’m not sure how many people are on this forum? Many, many people. But you sir are the most thorough in your restoration work. Perhaps the moderators can pin his restoration threads for future reference. 3 Share this post Link to post Share on other sites
Bill D 3,156 #133 Posted November 22, 2025 1 minute ago, ebinmaine said: Need to figure out some angles and clamping... It's not hard, you just need the right drill press vice. I'll have to take some pictures. 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #134 Posted November 22, 2025 7 minutes ago, Bill D said: It's not hard, you just need the right drill press vice. I'll have to take some pictures. I'd appreciate that Share this post Link to post Share on other sites
cleat 9,333 #135 Posted November 22, 2025 4 hours ago, ebinmaine said: I'd love to learn how to do this eventually Next one of those blocks that I drill out and install bushings into will get well documented. Likely next summer. 2 1 Share this post Link to post Share on other sites
cleat 9,333 #136 Posted November 23, 2025 Brake drum shaft ready for drum. Light coat of never seize applied so drum will come off easier next time. Brake drum and hardware ready to be installed. This OEM but used bolt has some form of thread locker on it. Drum installed and bolt tightened. 5 Share this post Link to post Share on other sites
cleat 9,333 #137 Posted November 23, 2025 Brake band ready to be installed. Brake band installed. Note that I used extra washers to hold band in more securely but there is still a bit of play to ensure free movement. 6 1 Share this post Link to post Share on other sites
cleat 9,333 #138 Posted November 23, 2025 Hydraulic supply line from pump to valve ready to be installed. Hydraulic supply line from pump to valve installed and nut tightened finger tight. Hydraulic supply line from pump to valve temporary plug installed. 4 1 Share this post Link to post Share on other sites
cleat 9,333 #139 Posted November 24, 2025 Hydro control plate ready to be installed. Hydro control plate installed. 4 2 Share this post Link to post Share on other sites
cleat 9,333 #140 Posted November 24, 2025 I'm sorry if this assembly is taking too long. I am really working hard to pace myself to make it last as it is my winter project. Keeps me in the shop out of my Wife's hair (not that she minds my company I'm sure). 6 Share this post Link to post Share on other sites
ebinmaine 80,695 #141 Posted November 24, 2025 8 minutes ago, cleat said: I'm sorry if this assembly is taking too long. I am really working hard to pace myself to make it last as it is my winter project. Keeps me in the shop out of my Wife's hair (not that she minds my company I'm sure). Funny you would bring that up because I was thinking this morning you're going a little too fast. Going to need another project by the end of winter. 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,504 #142 Posted November 24, 2025 56 minutes ago, ebinmaine said: Funny you would bring that up because I was thinking this morning you're going a little too fast. Going to need another project by the end of winter. And that would be a Colossus of a mistake... 6 Share this post Link to post Share on other sites
cleat 9,333 #143 Posted November 24, 2025 I do have two more on the back burner, a 312-8 and a 314H. Problem is that the cleanup and paint requires warmer weather so one of those will be next years project. 2 1 Share this post Link to post Share on other sites
cleat 9,333 #144 Posted November 26, 2025 (edited) Hoodstand ready to be installed. Hoodstand bolts ready. I ended up just using 10 of the shorter bolts, the longer ones were not needed. Hoodstand and foot control auto-center lever ready to be installed. Hoodstand sat into position on frame and two front lower bolts screwed in to hold it in position. All the lower side bolts screwed in finger tight then the top left bolts were screwed in finger tight. This will properly align the hoodstand. The foot control auto-center lever is now ready to be installed. Picture shows slightly longer bolts (7/8") but these were not required so I used the same length bolts as in the rest of the hoodstand (5/8"). Foot control auto-center lever installed. All 10 hoodstand mounting bolts including the ones in the foot control auto-center lever torqued to 17 ft/lb. The 1/4" pivot bolt in the foot control auto-center lever is just tightened enough to not have any side to side play but must pivot freely. Edited November 26, 2025 by cleat 4 2 Share this post Link to post Share on other sites
8ntruck 9,296 #145 Posted November 26, 2025 On 11/21/2025 at 7:50 PM, ebinmaine said: I'd appreciate that Eric, you will probably need a dial indicator and a holder that you can chuck up it to help line up the part you are working on. 2 Share this post Link to post Share on other sites
ebinmaine 80,695 #146 Posted November 26, 2025 1 hour ago, 8ntruck said: Eric, you will probably need a dial indicator and a holder that you can chuck up it to help line up the part you are working on. Thank you. I may have both of those tools but I've never connected the two so I don't know if one will clamp on the other okay. Share this post Link to post Share on other sites
cleat 9,333 #147 Posted November 27, 2025 Wire clips ready to install onto hoodstand. Front wire clip installed on hoodstand. Rear wire clip installed on hoodstand. Both wire clips installed on hoodstand. 4 Share this post Link to post Share on other sites
kpinnc 18,960 #148 Posted November 27, 2025 @cleat You do finer work in the places you can't see than I do on the parts you can... Simply amazing as always! 4 1 Share this post Link to post Share on other sites
cleat 9,333 #149 Posted November 28, 2025 Lift lever and bellcrank assembly ready to be installed. Lift lever bushings installed into hoodstand. They needed to be lightly tapped into place as they are a tight fit. Make sure they are fully installed and sit flat. Trunnion greased where it will slide into the bellcrank. Trunnion slid into bellcrank and clip installed onto trunnion. Clip and washer slid onto left side of lift lever. Lift lever was greased where it will slide into left side bushing. Lift lever slid through left bushing and bellcrank. Lift lever slid part way through right side bushing. Key installed and firmly tapped into place onto lift lever. Lift lever coated in never seize where the bellcrank will sit (between the two holes in the lift lever). Bellcrank slid onto lift lever after aligning key to keyway cut into bellcrank. Lift lever greased where it will slide into right side bushing. Lift lever fully slid into place. Right side lift lever washer and clip installed. Bellcrank retaining clips ready to be installed. A little never seize was applied where the retaining clip will be installed into the lift lever. Left side retaining clip installed then the bellcrank slid over until it is tight to the clip. At this point the right side clip was inserted. I then cleaned up and extra grease and never seize for a cleaner look and called this job complete. 4 1 Share this post Link to post Share on other sites
cleat 9,333 #150 Posted November 29, 2025 Hydraulic cylinder ready to be installed. This frame was missing the spacer so I am just stacking 3 thick washers instead. Tractor ready and waiting for the hydraulic cylinder. Spacer washers slid on and the shaft is greased where the cylinder will sit. Hydraulic cylinder slid onto shaft. Hydraulic cylinder pin greased and ready to be installed. Hydraulic cylinder pin installed. Overview as of today. 3 4 Share this post Link to post Share on other sites
