953 nut 61,965 #26 Posted August 22 Looking forward to another fantastic rebuild thread. 1 Share this post Link to post Share on other sites
cleat 7,641 #27 Posted August 23 Tractor lost some more parts. Some of the parts cleaned and sitting on the bench. Hydraulic tubes and hoses cleaned up. Front wheels cleaned up. The other side unfortunately does not look as good. Wire harness as pulled. I got a few little parts bead blasted. 5 Share this post Link to post Share on other sites
cleat 7,641 #28 Posted August 24 Hydraulic valve cleaned up. Here are the fittings as found showing correct angles. Valve has new Viton #111 O rings installed and all port openings are sealed off. Valve will be painted soon. 3 Share this post Link to post Share on other sites
cleat 7,641 #29 Posted August 25 Hydraulic cylinder cleaned and sanded. You can see the bolts, nuts, spacers, and O rings used to plug the ports (same setup used on the valve). Cylinder primed. Hydro cam plate bracket bead blasted and primed. Tie rods with ball tightened a bit using a hydraulic press then bead blasted and primed. 4 Share this post Link to post Share on other sites
MainelyWheelhorse 2,063 #30 Posted August 25 @cleat I’m looking forward to the final result. I do have a question for you hydro aficionados though. Would the Hydraulic lift parts off a later 520 fit a C series? Share this post Link to post Share on other sites
kpinnc 15,517 #31 Posted August 26 2 hours ago, MainelyWheelhorse said: Would the Hydraulic lift parts off a later 520 fit a C series? Probably, but you'll have to make up a new mounting bracket for the spool valve. The cylinder should have the same dimensions, and be rebuildable. 1 1 Share this post Link to post Share on other sites
cleat 7,641 #32 Posted August 26 Some painted parts drying in the window. Cylinder painted Tie rods painted. Cam plate bracket painted. Valve painted. 5 2 Share this post Link to post Share on other sites
cleat 7,641 #33 Posted August 27 No tractor work today. My Wife's Mother died this morning so we spent the day at the hospital, going to the bank, and talking to the funeral home. Her and her sister are going to the funeral home tomorrow and I am helping my daughter pack for her third year of college and I will be driving her up to Ottawa on Friday. 12 1 Share this post Link to post Share on other sites
kpinnc 15,517 #34 Posted August 27 7 hours ago, cleat said: No tractor work today. So sorry for your loss cleat. My family will be praying for yours. 3 Share this post Link to post Share on other sites
953 nut 61,965 #35 Posted August 27 Sorry to hear of your mother-in-law's passing but happy to hear your daughter is off to school to continue her education. 1 Share this post Link to post Share on other sites
cleat 7,641 #36 Posted August 27 38 minutes ago, 953 nut said: Sorry to hear of your mother-in-law's passing but happy to hear your daughter is off to school to continue her education. She is super excited to be heading back to Ottawa. We live out in the country about 10Km from Brockville. Brockville is a small city of around 22,000 people that she say is boring with nothing to do. Ottawa on the other hand has a population of around 1,000,000 people with a lot of attractions. Me on the other hand will drop her off and get out as large cities are not my thing. 1 Share this post Link to post Share on other sites
rjg854 12,484 #37 Posted August 27 Sorry to hear of your MIL's passing. for the family. 1 Share this post Link to post Share on other sites
Bill D 2,355 #38 Posted August 27 Sorry to hear of loss. My prayers for your family at this difficult time. 1 Share this post Link to post Share on other sites
johnnymag3 2,587 #39 Posted August 28 Sorry to hear of your loss. My prayers for you and your family 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,063 #40 Posted August 29 @cleat Sorry for your loss. 1 Share this post Link to post Share on other sites
cleat 7,641 #41 Posted August 29 Dughter is moved into her college residence. This is all that is left of my poor tractor now. A bunch of little parts have been painted, bagged and boxed. Hub set screws and jamb nuts, PTO rod trunnion and clip, steering shim washers bead blasted and painted. PTO rod and hoop bead blasted and one coat of paint applied. 6 Share this post Link to post Share on other sites
cleat 7,641 #42 Posted August 30 Not much happening right now. It's cloudy and spitting rain. There is a car show just up the road and I am hoping to take a car up to display. I did get the tie rods ready. I know I may need longer bolts but otherwise ready to be bolted on. 6 Share this post Link to post Share on other sites
cleat 7,641 #43 Posted August 31 Console decal as found. Console decal removed. Hood stand plate decals as found. Hood stand plate decals removed. Foot rest spare that I had left over from the GT1600 rebuild as found. Foot rest grip pad removed. 3 Share this post Link to post Share on other sites
cleat 7,641 #44 Posted August 31 Hydro lifted up using swivel 3/8" eyebolts, clevises, chains, slings, and an engine leveler. Hydro sat on three jack stands using a 3/4" bar through the rear hitch mount and a long 3/8" bolt threaded into a mounting boss. Hydro will be moved outside likely tomorrow or the next day for final cleanup and paint. 2 1 Share this post Link to post Share on other sites
cleat 7,641 #45 Posted August 31 Belt guard bracket sanded and primed. Engine plate sanded and primed. Front plate sanded and primed. Hood stand plate sanded and primed. Foot rest chemically stripped and washed. 3 Share this post Link to post Share on other sites
cleat 7,641 #46 Posted August 31 Belt guard bracket painted. Engine plate painted. Front plate painted. Hood stand plate painted. 3 Share this post Link to post Share on other sites
cleat 7,641 #47 Posted September 1 Hydro wire brushed, sanded, and final degreasing done. Primer applied (it is still wet, that is why it looks shiny). 5 Share this post Link to post Share on other sites
cleat 7,641 #48 Posted September 1 Hydro rear end now has two coats if IH red. 1 3 Share this post Link to post Share on other sites
ebinmaine 74,405 #49 Posted September 1 Wheels seals are ok? Other transmission gaskets or seals getting done? Share this post Link to post Share on other sites
cleat 7,641 #50 Posted September 1 There were no leaks so I left the seals as is. If one leaks later on i will replace it then. 1 Share this post Link to post Share on other sites
