Trouty56 568 #1 Posted September 10, 2009 The D-180 I recently purchased does not have an oil filter but has a plate instead. It is painted and bolted like it was original but I don't want to make that assumption. Could this be original and can an adapter be added if necessary? Your thoughts before I make a mess of things. Thanks for any input in advance. trouty Share this post Link to post Share on other sites
Jim_M 179 #2 Posted September 10, 2009 Yes to both. The early years had the plate installed. You can bolt on the adapter, cut a hole in your tin and you're ready to go. Share this post Link to post Share on other sites
Trouty56 568 #3 Posted September 10, 2009 Thank you Jim for the quick response. I guess I should ask if the filter is necessary. If it is then I start looking for one. I have resources that are close by. Trouty Share this post Link to post Share on other sites
Jim_M 179 #4 Posted September 10, 2009 It depends on how hard you use it and how well you maintain it. If you don't abuse it and change the oil regularly you'll be ok without a filter. Share this post Link to post Share on other sites
Trouty56 568 #5 Posted September 10, 2009 Thanks!! For now it is not working very hard at all. Runs but stalls after a bit (which doesn't take long) and seems very rich when this happens. I set the carb screws where they should be and tried to tweak from there but it just seems to choke out. It idles fine but when I throttle it about 10 seconds it chokes. Have taken the carb off and cleaned. A rebuild kit is being ordered if I can't get one locally. Thanks again!! trouty Share this post Link to post Share on other sites
Duff 206 #6 Posted September 10, 2009 Trouty, where are our manners! ! Glad you could join us. Lots of great people and a wealth of useful information to be had around here! Settle in and have a good time! Duff :scratchead: Share this post Link to post Share on other sites
Trouty56 568 #7 Posted September 10, 2009 Thanks Duff!! I really need all the help I can get. I'm really excited about owning this Wheel Horse. Hopefully, with the forums help, I can get this piece of history running and then work on getting some attachments. Looks like there are many options. Thanks, Trouty Share this post Link to post Share on other sites
Duff 206 #8 Posted September 11, 2009 Hopefully, with the forums help, I can get this piece of history running and then work on getting some attachments. You sure came to the right place. The guys will walk you through the process; we all love helping each other out. And as you've probably figured out already, around here Duff :scratchead: Share this post Link to post Share on other sites
