wheelhorseman 3,241 #51 Posted July 13 The hoses you have have number five fittings on them so you would need a #6 male to #5 female adapter to get them to work 1 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #52 Posted July 13 3 minutes ago, wheelhorseman said: The hoses you have have number five fittings on them so you would need a #6 male to #5 female adapter to get them to work The hoses I bought have larger fittings than will fit into the control head. They fit fine at the pump. #103213 / #103214 Pump Replacement Hydraulic Hoses for C-160 Wheel Horse Share this post Link to post Share on other sites
pfrederi 18,966 #53 Posted July 13 FYI to aide in identifying fittings SAE# 5 ORB have 1/2" NF Threads 20 TPI SAE# 6 ORB 9/16" NF Threads 18 TPI 2 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #54 Posted July 16 It looks like these adapters will work nicely to go from ORB-6 down to ORB-5. Any advice on how to purge the air from the system? I'll probably finish assembling tonight. Share this post Link to post Share on other sites
ebinmaine 74,524 #55 Posted July 16 10 minutes ago, Bar Nuthin said: It looks like these adapters will work nicely to go from ORB-6 down to ORB-5. Any advice on how to purge the air from the system? I'll probably finish assembling tonight. Should self purge. Just use the up/down a few times and drive around. Check and top off fluid. 2 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #56 Posted July 16 12 minutes ago, ebinmaine said: Should self purge. Just use the up/down a few times and drive around. Check and top off fluid. Cool! Once I get it working good, I think I have engineered a way lift my MightyMac (engineered in my head, at least) 1 Share this post Link to post Share on other sites
oliver2-44 10,976 #57 Posted July 16 21 minutes ago, ebinmaine said: Should self purge. Just use the up/down a few times and drive around. Check and top off fluid. 2 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #58 Posted July 17 (edited) I will need to take it apart again to address a small leak at the end of the cylinder, but it's not so bad that it can't wait awhile. Somewhere on the site is post on a hack to add an external o-ring and washer. Also needs a proper roll pin for the handle. All in all, a much easier project than I anticipated. Edited July 17 by Bar Nuthin 1 Share this post Link to post Share on other sites
ebinmaine 74,524 #59 Posted July 17 6 hours ago, Bar Nuthin said: Somewhere on the site is post on a hack to add an external o-ring and washer. @daveoman1966 did that one. 6 hours ago, Bar Nuthin said: All in all, a much easier project than I anticipated Awesome! 1 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #60 Posted July 17 3 hours ago, ebinmaine said: @daveoman1966 did that one. Not the original post I saw with photos, But an excellent explanation, all the same. 1 Share this post Link to post Share on other sites
Handy Don 14,628 #61 Posted July 17 1 hour ago, Bar Nuthin said: Not the original post I saw with photos, But an excellent explanation, all the same. In order to fit the mechanicals into the small space on the tractor, WH decided to use the “retract” motion of the cylinder rod for the “heavy” lift. This puts more fluid pressure on the rod end of the cylinder and works that O-ring seal harder. 2 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #62 Posted July 31 On 7/16/2025 at 7:32 PM, Bar Nuthin said: Cool! Once I get it working good, I think I have engineered a way lift my MightyMac (engineered in my head, at least) Well, the design I had in my head worked. This is just a quick mockup to confirm the geometry. I'll fab up better parts now that I know it works "GREAT" I must say! I think I'm going to try a boat trailer roller as the bottom support - In this video I'm just using an opened-up eye bolt. 1 Share this post Link to post Share on other sites
ebinmaine 74,524 #63 Posted July 31 Looks excellent! 1 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #64 Posted August 1 (edited) 3 hours ago, ebinmaine said: Looks excellent! Thanks! The nice part for me, only having one tractor, is being able to pop it off and wheel it around like a wheelbarrow for storage when I'm not using it. I think I dug out enough scrap steel to fab up a dedicated lift rod. Out of curiosity, we attached it to my neighbor's B-100 and it lifts pretty easy with the manual lift, too! (for the next time we shred seaweed) Edited August 1 by Bar Nuthin 1 Share this post Link to post Share on other sites
Bar Nuthin 1,480 #65 Posted August 4 On 7/31/2025 at 6:00 PM, Bar Nuthin said: Well, the design I had in my head worked. This is just a quick mockup to confirm the geometry. I'll fab up better parts now that I know it works "GREAT" I must say! I think I'm going to try a boat trailer roller as the bottom support - In this video I'm just using an opened-up eye bolt. Sorry to double post, but this project progressed on two different threads early on. Here is the final lift rod solution I came up with. Keeping it simple is always best! 1 Share this post Link to post Share on other sites
