grasscutter 2 #1 Posted December 2, 2024 Good evening everyone. I have a 1990 ? 212 hydro with a toro power plus 12.5hp. I have a broken swivel choke lever, part nn 10656 , to the best of my knowledge ! As these are unavailable now I am asking if anyone has one from a scrapper or can point me in a fruitful direction ? I'd be happy to buy the whole throttle plate assembly, nn10651 Many thanks in advance for any offers or advice. I'm near Portsmouth Cheers Andy Share this post Link to post Share on other sites
ri702bill 11,868 #2 Posted December 2, 2024 Welcome - maybe post this request in the Classifieds section under "Wanted"?? 1 1 Share this post Link to post Share on other sites
Ed Kennell 45,763 #3 Posted December 2, 2024 Call Lincoln at A-Z tractor. https://www.a-ztractor.com/ 2 1 Share this post Link to post Share on other sites
953 nut 65,265 #4 Posted December 3, 2024 Perhaps one of our European members can assist you in finding parts. @meadowfield, @ranger, @Mickwhitt, can you assist this felllow? 1 Share this post Link to post Share on other sites
peter lena 9,850 #5 Posted December 3, 2024 @grasscutter hope you can pick up the connection link , while you area right there , would be a good time to , verify how things are SAPOSED to work . whenever I see a problem related to movement , what could you possibly do ? cabling typically a dragging , rusted set up , like a 3-1 penetrating oil at every movement point , MAKE THE RUST RUN OUT , a SCHEMATIC LAY OUT , drawing of that , will show you the way. looks like the pull wire , is far stronger than the die cast end connection , good luck , pete 1 Share this post Link to post Share on other sites
