billythegoat 2 #1 Posted December 1, 2024 Briggs Stratton engine model number 252417-0664-01. on a GT1100 Wheel Horse. Cable broke at the end, Any ideas where I can purchase another? Bill on Cape Cod Mass. Thanks Share this post Link to post Share on other sites
ebinmaine 77,332 #2 Posted December 1, 2024 @Docwheelhorse is our local Briggs guru. Share this post Link to post Share on other sites
Ed Kennell 44,864 #3 Posted December 1, 2024 If the Zee bend broke, the cable can be shortened and a new Zee bend made with a couple needle nose pliers. 3 Share this post Link to post Share on other sites
Handy Don 15,938 #4 Posted December 1, 2024 (edited) 8 hours ago, Ed Kennell said: a new Zee bend made with a couple needle nose pliers Or, live large and buy an actual z-bend-maker plier! If the break is at the choke or throttle control end, you’ll realistically be looking for the full part. Have you checked out our vendors in the Classified section at the top of the page? Edited December 1, 2024 by Handy Don Share this post Link to post Share on other sites
billythegoat 2 #5 Posted December 2, 2024 2 hours ago, Handy Don said: Or, live large and buy an actual z-bend-maker plier! If the break is at the choke or throttle control end, you’ll realistically be looking for the full part. Have you checked out our vendors in the Classified section at the top of the page? Thanks for the advice. I believe I might have sufficient room to create a new z-bend. 1 Share this post Link to post Share on other sites
peter lena 9,764 #6 Posted December 2, 2024 @billythegoat https://www.amazon.com/Super-Lube-60004-Lightweight-Translucent/dp/B01IU6I214/ref=asc_df_B01IU6I214?mcid=aa00da7f1e8d31af8b43be2cd9e21e8d&tag=hyprod-20&linkCode=df0&hvadid=693405927029&hvpos=&hvnetw=g&hvrand=6650553147840997675&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1024403&hvtargid=pla-644882315889&psc=1 regularly use this on all my cabling , check temp range , have also added , a light extension spring , to related linkage hole , ASSISTING , PULL TO CLOSE . ? why would you do that ? think about it , every time you move the cable lever , its on a lubricated , spring assist , no rusty / dragging resistance , just smooth easy function . have that on all my related cables , it works , pete Share this post Link to post Share on other sites
Wayne0 1,509 #7 Posted December 2, 2024 13 hours ago, billythegoat said: Thanks for the advice. I believe I might have sufficient room to create a new z-bend. I had to do that on my throttle cable. Share this post Link to post Share on other sites
