Gravely Horse
Kohler valve train kit
Gravely Horse
I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
953 nut
1 hour ago, Gravely Horse said:
It runs fine,
:WRS:
Everybody has an opinion, mine is if it ain't broke, don't fix it.
  • Like 4
Bar Nuthin
LOL, we are not the same! :ROTF:
  • Haha 2
John2189
My Simplicity Sunstar has the ch20 it had the older style rockers that had the rounded ball pivot. One of the rockers broke in half, so I think that is the kit that I bought.
The motor has so much blowby that when it warmed up, the vacuum fuel pump would stop working. Since I just installed the new style rockers, I could install the mechanical fuel pump that is on the valve cover.
It now runs better than it ever has.
oliver2-44
iI your not getting any smoke in your exhaust that means your wrings and valve seals are still good.
If you still have good power and good compression there's no need grind and lap the valves and seats.
kpinnc
I can speak for the Kohler V twin, but those rockers and pushrods are similar to Vanguard. My question to answer your question would be how often do you have to adjust your valves? On my Vanguards, you’re supposed to check them every 100 hours if memory serves. So far I’ve not had to readjust mine.
I would say if your valve lash requires regular adjustment, maybe new rockers are in order. If not, I wouldn’t change them.
Gravely Horse
Thanks for the responses. I just bought this tractor. I haven’t drove it more than maybe 7-8 minutes. I thought these had hydraulic lifters? I’m asking because I had to rebuild the engine on my generator for our semi after a valve keeper let loose and the valve dropped into the cylinder and the piston stuffed it back up thru a brand new hole in the head. Now I’m looking around the shop at all these overhead valve engines wondering who’s next. The tractors a 98, so I didn’t know if there was a model run that there were “issues” with.
  • Sad 1
Gravely Horse
My 96-97 Murray has a 18 hp vanguard that I bought new. I’ve never touched the engine itself. Guess I should pop the covers off that this winter.
Gravely Horse
So I just checked the service manual and there’s no adjustment for the valves. Just a torque value for the bolts that hold the rocker arms.
953 nut
That being the case you have hydraulic lifters.
Wild Bill 633
Kohler Command uses SBC hydraulic lifters and with the rocker arm off the valve, torque the black (34mm long) rocker arm screw to 160 in-lbs and the silver (45mm long) screw to 120 in-lbs. Then lift the rocker arm and place on valve stem. It can be a little rough on the fingers.
TonyToro Jr.
My pulling tractor has a ch20 and has hydraulic valves. all you do is tightem them down and your good to go.
Gravely Horse
But there’s no preventative or scheduled maintenance that needs to be done I assume? Other than maybe popping the covers off and taking a look, or keeping an ear out for ticking.
Gravely Horse
Competition cams is known for selling crappy lifters in their kits, that need to be replaced with trw, sealed power, crower or some other good brand. Sometimes engine manufacturers get bad batches from their vendors too. That’s what I was getting at, but it doesn’t sound like the case. 👍🏻 Thanks for the intel.
kpinnc
You may not have the same type as what I was referring to.
Edited by kpinnc
Gravely Horse
I don’t believe so but it reminded me to check the lash on the vanguard in the Murray.
  • Similar Content
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • johnnymag3
      By johnnymag3
      416-8  clean machine, one owner, M16 Kohler...............no smoke, knocks, etc. Only 771 Hours.
      42" Rear Discharge deck   NO RUST    blades used 1 season
      48" plow very nice condition,
      Wheel Horse weights, on tractor already
      AG Tires on rear,used one season, front tires great condition. Rears are filled with beet juice, done at a Dealer professionally,  ....non toxic, non corrosive.  Traction Galore !!!
      Machine is fully serviced, ready to work. NEEDS nothing....Look below for pictures
      JOHN   845 797 5716 cell
