Alrashid2 476 #76 Posted December 17, 2024 Made a new post for anyone interested. Thank you guys for your suggestions and help! Share this post Link to post Share on other sites
Ed Kennell 46,857 #77 Posted December 17, 2024 38 minutes ago, Alrashid2 said: I was cleaning the blue dust off the engine block to "reset" and keep an eye out, Good plan. It could be that one belt got an extra heavy blue coating that is coming off. It'll good to see if it continues. 2 Share this post Link to post Share on other sites
peter lena 10,000 #78 Posted December 17, 2024 @Alrashid2 only time I use 3rd gear hi range is going up the road for some CUL DE SAC , test driving or a warm up of gear oil before draining , my 3 rd gear starts are very smooth and easy , no screaming belts and absolutely no wheels off the ground , every related movement point , works in quiet smooth operation . do not understand this issue , 3 , 12 horse tractors , no noisy belt engagement . also use every gear / range while out there , always bring a small tool kit , aerosol lube . my tractor supply belts are very good , no issues , all my pulleys and linkage areas , move in silence , steering smooth / solid . just started 2 of my horses , sleeping over a month , started right up , no issues , battery tender , incandescent heat bulb under engines . like where I am , pete 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 94 #79 Posted yesterday at 02:05 AM On 11/22/2024 at 3:58 PM, Ed Kennell said: The clutch on my 310-8 works perfectly. The clutch can be eased in with no grabbing. I use the TSC wrapped belts. Note the amount of travel in the idler pulley. Does your idler pulley have the angled plate behind the belt retainer? This plate should contact a clutch dampening cylinder that eases the belt into tension. What size belt did you use? I just replaced my belt on my 312 with a tsc belt and now I have the similar issue as the OP. Share this post Link to post Share on other sites
1987_WHEEHORSE312 94 #80 Posted yesterday at 02:07 AM On 11/22/2024 at 11:49 AM, Alrashid2 said: Appreciate the advice, brothers. I have read on here that this isn't uncommon, but it's becoming a real problem for me. My 312-8 clutch is too sensitive. It feels like there is just a quarter inch in movement of the pedal between the clutch being disengaged and it being fully engaged. Every other time, despite constantly practicing and letting off the clutch as carefully and slowly as I can, the tractor jumps forward and oftentimes I get a bit of air on the front wheels! Today it was too much. Finally got rain so out back is muddy. I was trying to go uphill, slightly to the left, and the whole thing spun out, wheelied, and i smashed the front end into a log I was trying to turn around... I got so much air that is just shot a few feet straight forward because the turning front wheels weren't in contact with the ground! Nearly flipped backwards... Not sure what to do. No, nothing is catching or grabbing on the pulleys or belt. The pulleys appear to be clean and fine, and the belt is in good shape... I know these don't have real clutches, it's just loosening/tightening the pulley. Is there anyway to allow the belt to "slip" more? Seems wrong, but could I oil up the pulleys a bit to allow some more slippage? I don't want to create a nuisance or worst, something dangerous. I have the same tractor, same issue after replacing the belt with a brand new one thats from tsc thats the exact spec. What was your fix? Share this post Link to post Share on other sites
Ed Kennell 46,857 #81 Posted 21 hours ago 9 hours ago, 1987_WHEEHORSE312 said: What size belt did you use? I just replaced my belt on my 312 with a tsc belt and now I have the similar issue as the OP. TSC 5/8 X 82 Aramid blue belt works great on my 310-8. Mine does have the clutch damper cylinder on the idler pulley, but I'm not sure the damper does anything as I can feel and feather the clutch with my foot. 1 Share this post Link to post Share on other sites
953 nut 68,290 #82 Posted 20 hours ago @Ed Kennell, get your finger out of there, you are making me nervous! 3 Share this post Link to post Share on other sites
1987_WHEEHORSE312 94 #83 Posted 20 hours ago 37 minutes ago, Ed Kennell said: TSC 5/8 X 82 Aramid blue belt works great on my 310-8. Mine does have the clutch damper cylinder on the idler pulley, but I'm not sure the damper does anything as I can feel and feather the clutch with my foot. Ok so I have the same belt you have, so I know the belt size is okay. I also found a spring that goes from the actual clutch pedal and attaches behind the dashboard. I assume that was someone's backyard fix to the blown out strut on the clutch. I have a new correct spring clutch coming in from Wheelhorse parts and more today, so ill install that and remove this other spring that is circled in the attached photo. 1 Share this post Link to post Share on other sites
peter lena 10,000 #84 Posted 20 hours ago @Alrashid2 wide open throttle clutch engagement ? dry rusty linkage / lever connections , lots of glairing areas to me . actually the belts don,t look bad at all. for me it would be , related pulley movement , EASE, QUIET , SMOOTH ? like a 2 stage , trial ? penetrating oil , for a make the rust run out , then follow up with red aerosol grease , BELTS SHOW YOU WHATS GOING ON ? yours are NOT FRAYED OR CRACKED , would also look , feel sense the movement ease to idler pulleys , regular , lubrication failure , literally stops pulley , adding to issue . clutch pedal , consoul cross shaft , probably dry / rusty , enhances , erratic clutch operation . only suggestions , pete Share this post Link to post Share on other sites
Ed Kennell 46,857 #85 Posted 19 hours ago 37 minutes ago, 1987_WHEEHORSE312 said: backyard fix I think you have found the problem. With the spring here, I can see where any slop in the clutch linkage would allow the clutch pulley to engage and grab. Share this post Link to post Share on other sites
1987_WHEEHORSE312 94 #86 Posted 19 hours ago 1 minute ago, Ed Kennell said: I think you have found the problem. With the spring here, I can see where any slop in the clutch linkage would allow the clutch pulley to engage and grab. Yea the correct spring that goes from the linkage to the trans will be here tonight so after I swap them as long as the rain calms down ill test it and report back. 1 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 94 #87 Posted 8 hours ago 11 hours ago, Ed Kennell said: I think you have found the problem. With the spring here, I can see where any slop in the clutch linkage would allow the clutch pulley to engage and grab. Yup! The correct spring did the trick! I think i am also used to the worn belt that was slipping, the as well as the worn strut. Now it feels like a true tractor not a lawn mower from lowes any more. 1 Share this post Link to post Share on other sites
