JPWH 6,544 #26 Posted November 9, 2024 I have a 225 amp stick welder, a100 amp mig, and a 140 amp mig. All are Lincolns. I use all of them but the one I use most is the 100 amp mig. I used flux core for years. I now have gas on both migs. If I had to choose one machine I would go with the 140 amp mig. It will work on 120 and 240 volt power. Easy to change wire for different needs. The 240 is nice when you need the higher amperage. The welding machines vary in type and size but the welding shield also makes a difference. I would recommend using an auto darkening welding shield. 4 Share this post Link to post Share on other sites
WHX?? 57,466 #27 Posted November 9, 2024 (edited) You go with a strait stick machine Bob I'll give you this squirt gun to play with. Have to come to Pullstart's plow day to get it tho... FYI I bet don't have but a little over 100 in this rig ... cart, mask, tools & all less the two welders. I'm about ready to move up and trying to get our buddy to sell me the green one. He kinda wants to keep it in case he needs to go portable or weld in a breeze which is a pit fall of a gas one. I keep my helmet in an old pillow case but @Achto found some nice bags in the jungle for those more expensive ones. Also I have a buddy who was a welding instructor and certifies wanna be's the secret to good flux core is the quality of wire. Edited November 9, 2024 by WHX?? 4 Share this post Link to post Share on other sites
Racinbob 13,044 #28 Posted November 9, 2024 23 minutes ago, WHX?? said: You go with a strait stick machine Bob I'll give you this squirt gun to play with. Have to come to Pullstart's plow day to get it tho... FYI I bet don't have but a little over 100 in this rig ... cart, mask, tools & all less the two welders. I'm about ready to move up and trying to get our buddy to sell me the green one. He kinda wants to keep it in case he needs to go portable or weld in a breeze which is a pit fall of a gas one. I keep my helmet in an old pillow case but @Achto found some nice bags in the jungle for those more expensive ones. Also I have a buddy who was a welding instructor and certifies wanna be's the secret to good flux core is the quality of wire. I was under the impression that MIG requires a tank where flux core doesn't? I don't think I'll have any trouble learning. When I had the Lincoln 225 stick I was actually pretty good with it but it's been over 25 years. At this point I'm kinda leaning towards a flux but I'm wondering if a stick would be a better choice for my limited usage. I'm thinking being able to weld 1/4" would be nice but I'm wanting to minimize the electrical work. Maybe I should just do the electrical and be done with it. 1 Share this post Link to post Share on other sites
ebinmaine 79,729 #29 Posted November 9, 2024 Just now, Racinbob said: Maybe I should just do the electrical and be done with it. Speaking from direct personal experience. Yes. A GOOD flux core welder could do the 3/16" and up. A cheap/inexpensive one.. won't. This will absolutely be an occasion of, you get what ya pay for. 2 Share this post Link to post Share on other sites
ebinmaine 79,729 #30 Posted November 9, 2024 We installed a 100 amp service in the barn 2+ years ago because that's what was available at the time. Lately we've been seriously considering upgrading to a 200 amp. 1 Share this post Link to post Share on other sites
Handy Don 16,961 #31 Posted November 9, 2024 11 hours ago, JPWH said: I would recommend using an auto darkening welding shield. My advice is always that you can go economy on the machine, but never on the safety equipment. Gloves, quality auto darkening helmet, apron, A-B-C fire extinguisher handy. 3 Share this post Link to post Share on other sites
Achto 32,108 #32 Posted November 9, 2024 7 hours ago, Racinbob said: I was under the impression that MIG requires a tank where flux core doesn't? That would be the only difference between the 2. 7 hours ago, Racinbob said: When I had the Lincoln 225 stick I was actually pretty good with it but it's been over 25 years. At this point I'm kinda leaning towards a flux but I'm wondering if a stick would be a better choice for my limited usage. Using a mig or flux core is pretty much the same as using a stick welder, just have to remember not to keep feeding the gun in closer. 2 Share this post Link to post Share on other sites
Handy Don 16,961 #33 Posted November 9, 2024 9 minutes ago, Achto said: Using a mig or flux core is pretty much the same as using a stick welder, just have to remember not to keep feeding the gun in closer. Wire angle, push vs. drag, actually matters as well! 2 Share this post Link to post Share on other sites
WHX?? 57,466 #34 Posted November 9, 2024 8 hours ago, Racinbob said: was under the impression that MIG requires a tank where flux core doesn't? Correct ... the two terms get interchanged but probably shouldn't. 8 hours ago, Handy Don said: quality auto darkening helmet Yeah I bought a horror fright $40 cheapy and a POS. It gets too dark and can't see. Adjustments don't work. I don't use it and just keep my eyes shut ... get better welds that way ... 😆 1 Share this post Link to post Share on other sites
adsm08 4,804 #35 Posted November 9, 2024 24 minutes ago, WHX?? said: Yeah I bought a horror fright $40 cheapy and a POS. It gets too dark and can't see. Adjustments don't work. I don't use it and just keep my eyes shut ... get better welds that way ... 😆 I have one of those too. It sounds like mine works a little better than yours, but yes, there is basically too dark, or not dark enough, and no middle ground. I do like it for cutting work though. I leave it in the Grind setting and I can see what I'm doing, but I get enough darkening to protect my eyes from the torch, and some actual eye protection too. 1 1 Share this post Link to post Share on other sites
adsm08 4,804 #36 Posted November 9, 2024 9 hours ago, Racinbob said: I was under the impression that MIG requires a tank where flux core doesn't? Right. MIG stands for Metal Inert Gas. So to truly be MIG welding you need to be using a shielding gas. The gas and the flux serve the same purpose, to keep the nasty stuff out of your welds. Flux has slag to chip away at the end, gas doesn't. But all MIG units I have ever seen are capable of both modes. 2 Share this post Link to post Share on other sites
ebinmaine 79,729 #37 Posted November 10, 2024 9 hours ago, Handy Don said: My advice is always that you can go economy on the machine, but never on the safety equipment. Gloves, quality auto darkening helmet, apron, A-B-C fire extinguisher handy. I'm not prone to using cheap safety products but HF has a particular type of gloves I like a lot. They just .. fit.. They're made for TIG welding and much thinner than any stick welding gloves. That's important to remember when handling hot 🔥 steel. 2 1 Share this post Link to post Share on other sites
Achto 32,108 #38 Posted November 10, 2024 15 hours ago, WHX?? said: Yeah I bought a horror fright $40 cheapy and a POS. It gets too dark and can't see. I suggest one of these helmets or at least one that has the true color technology. Vision is crystal clear compared to the old green tint lenses. If you are purchasing an auto tint, you may also want to make sure that it has replaceable batteries. I had a Harbor Freight cheapy with the non-replaceable battery, the batteries died mid weld. My welding project was done at that point, until I was able to purchase a new helmet. https://www.amazon.com/ARCCAPTAIN-Welding-Darkening-Viewing-Powered/dp/B0BV6RYWV9/ref=sr_1_10?crid=1ID2OZCZTC81F&dib=eyJ2IjoiMSJ9.--7_R6rGIU-FcBXQHDPqlrnHbhkO6jZyCdo4psjRis8sR2lE_4cryWYy9A6uWw878__36E0niXrUUjVhd2fCs81wKK2uXJIKHBcotRVIilRybEb5GhOuMaK4U1FmIKHtNHg8R5OzxQf_zDWcl2z-XRH5l5t5cz49ENEvTMs-9usNCreu-TSKlFemjkMEfPX1Tmy4ifMKI8Msks9yXbShnZSOZWADLLlLuKhqqXCvZxqaMFw3708iSYA9NOuCMo4oiwCZCut8n96YPqMPb-24TzRWgHH1ALgav7YOTMbRmxc.hMlDKZaijVkkaXDITfdNmoP2I50JrRJyaWv8P9RvDhE&dib_tag=se&keywords=welding%2Bhelmet&qid=1731249103&sprefix=welding%2B%2Caps%2C194&sr=8-10&th=1 The helmet above is an awesome choice for the money. 1 Share this post Link to post Share on other sites
ebinmaine 79,729 #39 Posted November 10, 2024 9 minutes ago, Achto said: The helmet above is an awesome choice for the money. Seconded. I have a very similar one. 1 Share this post Link to post Share on other sites
WHX?? 57,466 #40 Posted November 10, 2024 (edited) Don't they claim the batteries recharge with arc light? Holy crap Dan their giving it away! What's the diff between the 25 dollar and more $$ ones? Edited November 10, 2024 by WHX?? Share this post Link to post Share on other sites
Achto 32,108 #41 Posted November 11, 2024 9 hours ago, WHX?? said: Don't they claim the batteries recharge with arc light? They do recharge while welding, but they still only last just so long. 9 hours ago, WHX?? said: What's the diff between the 25 dollar and more $$ ones? Guessing the cheaper ones are just constant tint and do not auto tint. Share this post Link to post Share on other sites
adsm08 4,804 #42 Posted November 11, 2024 21 hours ago, Achto said: They do recharge while welding, but they still only last just so long. Guessing the cheaper ones are just constant tint and do not auto tint. Some of the cheaper ones are just a photovoltaic cell with no battery, so they operate a lot like a calculator. 3 Share this post Link to post Share on other sites
Handy Don 16,961 #43 Posted November 12, 2024 (edited) Yep, a good quality helmet will have a large viewing area with fine-grained control for degree of darkness and a quick response time. Also, the better the quality, the clearer the view when in non-darkened state. Most will also have a “how long do I stay dark after the arc ends” adjustment, multiple photosensors, and photovoltaic battery charging. Most also offer a switch for weld/grind states. Going further up the scale, one can get forced filtered air feed to assure non-fogging, clean air to breathe. I use a mid-level Hobart Inventor series. Edited November 12, 2024 by Handy Don Share this post Link to post Share on other sites
Racinbob 13,044 #44 Posted January 17, 2025 Right or wrong the decision is made. It came down between the HF Titanium 125 and the Arccaptian 130 based on my needs and the reviews. Thinking back when I had a Lincoln 225 I don't think I ever cranked it past 125 amps. A plus is that I don't need to do anything electrical to get the max out of either one. Pricing wasn't really a consideration but Arccaptain made me an offer I bit on this morning. With the sale price, an 8% discount plus tax it came to $118.13 delivered. Yet again, red beats green. 5 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #45 Posted January 17, 2025 (edited) I don't think there's a wrong choice. I got the green one a few years ago and it's been really handy. One improvement though I would recommend for any of the budget flux setups is to see if it has a copper ground clamp. If it doesn't I would upgrade to one. They are less than $10. I thought I was the worse welder as I could never get a nice looking bead. They welds were strong, just ugly. Switched out the cheap clamp with the copper one and man it made a huge improvement. Much better and consistent burn and less popping. And plugging it in to the closest outlet is always a convenience Edited January 17, 2025 by OutdoorEnvy 1 Share this post Link to post Share on other sites
19richie66 17,930 #46 Posted January 17, 2025 Guess Im too late but I got rid of my stick welder when I bought my mig. It welds anything I have ever wanted to do from sheetmetal to steel angle. Not a pro by anymeans but never had anything break. Just bought a tig welder and I am icthing to try it out. Best warranty in the business too. 3 year no hassle. I want to learn to do aluminum. If I can pull it off, might get into making some more fuel tanks. 4 Share this post Link to post Share on other sites
Bar Nuthin 2,657 #47 Posted January 18, 2025 Picked up the Hobart 110V Flux on marketplace for $80 still new in box. Guy bought it for his dad for Christmas, only to find out his dad had went out and bought himself one already. The plasma cutter on the bottom is 110 or 220. I needed it for a project for work, so my company paid for it and told me to keep it in case we ever needed it again - and I have the only garage space for projects. 4 Share this post Link to post Share on other sites
Lee1977 7,710 #48 Posted January 18, 2025 (edited) Rich I bought a PrimeWeld CT520D when my Miller Thunderbolt quit working. Edited January 18, 2025 by Lee1977 1 1 Share this post Link to post Share on other sites
Racinbob 13,044 #49 Posted February 17, 2025 I narrowed it down to the HF Titanium and The Arccaptain and went with the Arccaptain to have the capability of flux core or stick. It came with some .030 wire and I picked up a few types of rod within it's capabilities. I decided to go with a simple flip helmet and not a powered one. I think this will do pretty much what I need. I can't load pictures all of a sudden. I keep getting a triangular ! symbol and a -200 pops up. What's with that? Share this post Link to post Share on other sites
HyperPete 939 #50 Posted February 17, 2025 (edited) 15 minutes ago, Racinbob said: I narrowed it down to the HF Titanium and The Arccaptain and went with the Arccaptain to have the capability of flux core or stick. It came with some .030 wire and I picked up a few types of rod within it's capabilities. I decided to go with a simple flip helmet and not a powered one. I think this will do pretty much what I need. I can't load pictures all of a sudden. I keep getting a triangular ! symbol and a -200 pops up. What's with that? 200 OK The HTTP 200 OK successful response status code indicates that a request has succeeded. A 200 OK response is cacheable by default. A 200 OK response has a different meaning and format depending on the HTTP request method. Here's how they vary for different methods: GET: A resource was retrieved by the server and included in the response body. POST: An action succeeded; the response has a message body describing the result. HEAD: Identical to GET, except there is no message body. TRACE: The response has a message body containing the request as received by the server. ==================== Can you try with a different browser (as a test)? Edited February 17, 2025 by Pete D Share this post Link to post Share on other sites
