Inspectorjoe 473 #1 Posted November 5, 2024 (edited) Over the years, I've had four Wheel Horse single stage snowblowers, but for several reasons, I've never actually used one. I currently have a C-145, a C-175, a short chute blower in good shape, a 42" plow in fair shape, two walk-behind blowers and a 1947 Farmall Cub with a 54" blade. I've eliminated one shed and will soon be eliminating another, greatly reducing my covered storage space, so I have some decisions to make. I can use the two Wheel Horses with a blower and blade, or I can use a walk-behind blower and the Cub and blade. I've used two-stage walk behind blowers my entire adult life, and know how to get the best out of them. My reservations with a single-stage WH blower are the limitations of a single stage unit and the short box height compared to a walk behind unit. It's not unheard of to get an occasional 30" snow in my area, and there may be times I have to wait for it to stop before clearing it. I welcome thoughts on this. The link is to the Cub plowing snow. https://youtu.be/JBIIPo699f0?si=9dvoNTFctLXiVtqT Edited November 5, 2024 by Inspectorjoe 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #2 Posted November 5, 2024 @Maz91 you may be interested in this thread. @OldWorkHorse you've run a Wheelhorse Single Stage. Any comments? Share this post Link to post Share on other sites
OldWorkHorse 3,156 #3 Posted November 5, 2024 I've used a single stage short shoot for about 4 winters now and it moves some snow with my 314-8. Havnt met anything it won't chew though sometimes just got to go slow and it throws it a very good distance. Hit slush a few times and it will bog down but still throws it's. I do have a worn belt on mine that has slipped a few times so with a new belt might even be a bit better. I've blown snow 3+ inches deeper than the face of the blower still no issue. I've recently upgraded to a single stage tall shoot hoping that will be just as good. 2 Share this post Link to post Share on other sites
ri702bill 12,696 #4 Posted November 5, 2024 (edited) It's all about speed -WOT on the blower auger, but SLOW forward motion. Low range 1st or 2nd gear on an 8 speed tractor works best. My 32" blower is a 1963 model - those tractors came only as 4 speeds. The manual tells you to use the clutch to "adjust" the forward speed.... My 854 has the Unidrive from a C81 8 speed . Edited November 5, 2024 by ri702bill 2 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,523 #5 Posted November 5, 2024 I’ve been using my C-145 with a tall chute single stage blower now I think for 3 or 4 seasons. Works great with the lighter snow and wet. As long as it isn’t slush it will throw it. (In the videos it was like a foot of kinda wet snow but mostly powder.) IMG_3377.mov cm-chat-media-video-1:921c5e01-9961-3138-8733-92850a611703:10989:0:0.mov 2 1 1 Share this post Link to post Share on other sites
peter lena 9,993 #6 Posted November 5, 2024 @Inspectorjoe moved a lot of snow with the single stage , also enhanced / verified the drive set up , again the PTO drive , AND RELATED MOVEMENT POINTS ARE CRITICAL FOR ROTATIONAL MOVEMENT EASE . agree on the type of snow , I am right on the wet / dry snow loading, area also have a walk behind blower , dry snow rarity , is terrific with blowers , also have a plow set up on another horse , lubrication faced plow blade , moves / slides snow with very easy angle sliding . another thing I notice is people using their stuff at hi speed , wrong gear , @ri702bill plows like I do , always looking / sensing traction / loading , I also " plow with the sun angle " knowing the sun will be at areas throughout the day , move snow , to sun side of driveway , starts melting , goes to street drain , that blower frame / pulley movement area , can be lubrication enhanced , on the rusty " movement spots , also those idler pulleys are known to lubrication fail , " what could you possibly do ? my blower auger chain drive is adjusted and chain / open gear aerosol , works at EVERY MOVEMENT AREA . auger moves easily pto down drive belt , no screaming clutch engagement . mention this , movement related , drag / rusty spot on any attachment point . went after , every drag point , eliminated them , problem tracking , will show you the way / you have to change / improve the movement hang up point , pete 2 Share this post Link to post Share on other sites
Ed Kennell 46,797 #7 Posted November 5, 2024 I have used short and tall chute single stages to clear several of those 30" snows that we used to get. They work best in the deep dry snows. Not so well in the 3" slushy stuff we get now. For the singles to work efficiently, the housing must be kept full. To do this, the ground speed must be varied and IMO, this can only be accomplished with a Hydro. I sold my blowers 5 years ago as we have not had a decent snow in 10 years. I do have a dual stage that will probably never be used....got it in a trade deal a couple years back. If you ever get one of those 30"ers Joe, call me. I would love to use this dually before I sell it. 4 Share this post Link to post Share on other sites
ML3 2,464 #8 Posted November 5, 2024 I guess it depends on how much snow you typically get. Where I live snowfall has been significantly less than normal last few years. I sold my single stage along with my C105. Just didn't perform well especially in heavy, wet snow. Right now i have a 2stage Toro walk behind snowblower. My plan is to get a 520H with a 2stage. We get "lake effect " snow events that can dump every bit of a foot + of snow in a short time. A 2stage is definitely needed at least in my area. 3 Share this post Link to post Share on other sites
Ed Kennell 46,797 #9 Posted November 5, 2024 1 minute ago, ML3 said: My plan is to get a 520H with a 2stage. Come to the big show next year. My 520H with heated cab and dually Ber Vac may be there for sale. 4 Share this post Link to post Share on other sites
ML3 2,464 #10 Posted November 5, 2024 2 minutes ago, Ed Kennell said: Come to the big show next year. My 520H with heated cab and dually Ber Vac may be there for sale. I plan to attend. I been there the last 2yrs. The Ber Vac is the bad boy of the 2stages. My dad has one on his Troy Bilt GTX20. It's a beast of a snow removal machine! 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #11 Posted November 5, 2024 https://youtu.be/PX4qUILtQ1Y?si=rxHZEFH55QBiXrY6 2 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #12 Posted November 5, 2024 23 minutes ago, AMC RULES said: https://youtu.be/PX4qUILtQ1Y?si=rxHZEFH55QBiXrY6 Craig that link doesn't work automatically but if I highlight it my phone has an option to click "open". Good stuff there. 1 Share this post Link to post Share on other sites
wallfish 20,383 #13 Posted November 5, 2024 The more HP the better the performance. Going too slow of a ground speed will clog them up MUCH faster if it isn't powder. Too small of an engine won't allow it get loaded up enough in the wet stuff to perform well. Yes, they will still work even with an 8 hp. But there is a very noticeable difference when using a 12 and up. I tried going from a 16 hp down to a 10 hp and and changed it back quickly because of the noticable difference in performance. My opinion, big engine and a good ground speed, just fast enough until the engine grunts just a little, that seems to be the "sweet spot" 2 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #14 Posted November 5, 2024 But... it is working there in your quoted link. 3 Share this post Link to post Share on other sites
Handy Don 17,197 #15 Posted November 5, 2024 12 minutes ago, wallfish said: engine and a good ground speed Applies equally to walk-behind two-stagers. Gotta keep ‘em well fed but not choking! 1 Share this post Link to post Share on other sites
Ed Kennell 46,797 #16 Posted November 5, 2024 (edited) 55 minutes ago, wallfish said: My opinion, big engine and a good ground speed, I used my single tall chute on my C-12 Hydro. It worked but ran out of HP in the deep stuff. On the 520H...no problem. Good ground speed means keeping the housing full of snow. To do this, the ground speed needs to be varied to match the depth of the snow and this can only be done with a hydro. The hydro lift is also a must for us old guys. Edited November 5, 2024 by Ed Kennell 2 1 1 Share this post Link to post Share on other sites
ebinmaine 80,087 #17 Posted November 5, 2024 27 minutes ago, AMC RULES said: But... it is working there in your quoted link. Yeah I saw that as soon as I hit submit. Odd ehh? Share this post Link to post Share on other sites
Inspectorjoe 473 #18 Posted November 14, 2024 Thanks for the replies, everyone. I'm sorry I haven't been back with a response. Last week, I went to work in the afternoon and ended up going in for emergency major abdominal surgery at 3:30 AM. So far, the recovery hasn't been very easy. I think I'll put the blade on the C-145 and the blower on the C-175. They're both hydros. I guess I'll put the Cub up for sale, as much as I don't want to, but it takes up a lot of space for something that has such a limited use over the year. It really does a great job plowing, and it's fun to use. It has a very, very low serial number and is still in its original paint and decals, so I'd really hate to get it wet if I don't have to. And being the 308th Cub made and still being original, it has a manual lift which works surprisingly easily, but I don't know how well I'll handle it after this surgery. 1 1 1 Share this post Link to post Share on other sites
rjg854 13,269 #19 Posted November 14, 2024 I you're feeling better. 1 Share this post Link to post Share on other sites
BuffaloD200 53 #20 Posted January 17, 2025 My single stage is hot garbage. Painfully slow ground speed, and shoots snow a whopping 4'. Clogs with every kind of snow. I can do my driveway in less time with a two stage walk behind half the size. 1 Share this post Link to post Share on other sites
midpack 1,148 #21 Posted January 17, 2025 I have a single stage mounted on a machine with a Magnum 18, it's a pure beast! Eats up the road snow plowed mound and the engine growl gives you shivers when it hits the deep sloppy stuff Share this post Link to post Share on other sites
Ed Kennell 46,797 #22 Posted January 17, 2025 1 hour ago, BuffaloD200 said: My single stage is hot garbage. Painfully slow ground speed, and shoots snow a whopping 4'. Clogs with every kind of snow. I can do my driveway in less time with a two stage walk behind half the size. Single stage blowers need to be operated at the design RPM. Correct diameter jack shaft pulley Good belt on the inside larger PTO pulley Good spring on the idler pulleys Engine at wide open throttle 3600RPM Ground speed fast enough to keep the housing full of snow...hydros work best for this. If you let the housing go empty, there is nothing to push the snow out the chute and it will freeze and clog. They do very well in deep dry snow and not so good in the 2" sloppy wet stuff. H#!!, my two stage Ber Vac on the 20 HP 520H even clogs in the 2" slop. Share this post Link to post Share on other sites
BuffaloD200 53 #23 Posted January 17, 2025 12 minutes ago, Ed Kennell said: Single stage blowers need to be operated at the design RPM. Correct diameter jack shaft pulley Good belt on the inside larger PTO pulley Good spring on the idler pulleys Engine at wide open throttle 3600RPM Ground speed fast enough to keep the housing full of snow...hydros work best for this. If you let the housing go empty, there is nothing to push the snow out the chute and it will freeze and clog. They do very well in deep dry snow and not so good in the 2" sloppy wet stuff. H#!!, my two stage Ber Vac on the 20 HP 520H even clogs in the 2" slop. Stock pulleys with stock size belts. I did shorten the blower belt to increase tension - still no dice. Super simple setup with 2 pulleys, no idlers. Always run at WOT. I've run balls out and snail mode and everywhere in between. D-180 with a hydro. Ran in through the fluffiest snow you can imagine all the way to neutron star dense by the road. I lube the absolute hell out of the chute with silicone spray. This blower just does not blow. Share this post Link to post Share on other sites
Ed Kennell 46,797 #24 Posted January 17, 2025 41 minutes ago, BuffaloD200 said: This blower just does not blow. That is strange. Is there any possibility it is turning in the wrong direction or the auger is not turning under load? auger slipping on the shaft one of the chain sprockets lost a key runs at idle, but slips under load Jack shaft pulley lost key 1 Share this post Link to post Share on other sites
BuffaloD200 53 #25 Posted January 17, 2025 1 minute ago, Ed Kennell said: That is strange. Is there any possibility it is turning in the wrong direction or the auger is not turning under load? auger slipping on the shaft one of the chain sprockets lost a key runs at idle, but slips under load Jack shaft pulley lost key It seems to be turning the right direction. Passenger side view moves clockwise, shoving the snow to the back of the unit and up through the chute. The auger definitely bogs down when the chute clogs up. Chute is usually clogged after one pass of my 200' driveway. Sometimes significantly less than that. I have no doubt that something is wrong but I have no idea what. I rebuilt the PTO clutch because the original was gone, replaced the key as the original was too short, and have tried several different belts. The auger seizes and the PTO spins and melts the belt. The blower chute is a little crusty, but not awful. So I assume some of my issue lies there. If anyone has any insight, I would glad to hear it. Share this post Link to post Share on other sites
