Scot 1966 8 #1 Posted October 13, 2024 Hello everyone. i have been working on a 1980 C-145 hydro, with a sunstrand that I bought as a project. It now runs well, but I am having a problem with the drive belt. The belt that was on it was missing several pieces, so I bought a new one From researching on this site, and measuring the old belt, I bought a 7478 belt, which measures 5/8” X 84”. The belt is so short it won’t fit the 2 pulleys even without going under the tensioner pulley. I tried an 5/8” X 85” and it seems too long, as the tensioner pushes it down so far, it almost touches the other side of the belt. Also, it flies off as soon as you engage the tensioner. Does anyone have any ideas as to what I’m missing ? Share this post Link to post Share on other sites
Ed Kennell 46,607 #3 Posted October 13, 2024 (edited) to the Scot. Yes, pictures will help us diagnose the problem. One inch in lingth should not make that much difference.file:///C:/Users/ED/Downloads/Tractor%201980%20C-145%20Auto%2001-14KS01%20TIPL.pdf Edited October 13, 2024 by Ed Kennell Share this post Link to post Share on other sites
953 nut 67,462 #4 Posted October 13, 2024 The 7478 is a good part number for your C-145 and should work. One or both of those belts could be labeled incorrectly. I have used Tractor Supply Kevlar 5/8 X 82" belts on hydros with good results. 2 Share this post Link to post Share on other sites
Scot 1966 8 #5 Posted October 13, 2024 Thanks everyone. I will double check the length of the 7478 belt tomorrow, and get some pictures. Share this post Link to post Share on other sites
Scot 1966 8 #6 Posted October 14, 2024 I took the belt off, and it measures 84”, however, it is thicker than 5/8”. It measures .700” across the flat, which is .075” over 5/8”. I’m wondering if my problem is because the belt is wider, the width is preventing it from properly seating in the pulleys? The brand of this belt is D&D power sports, and came from Amazon. The top picture is with me pulling it down as far as I can, and the tensioner is all the way up, so you can see that there is no way the tensioner pulley will fit on top of it. I’m thinking of trying the TSC Kevlar belt that was recommended. 1 Share this post Link to post Share on other sites
953 nut 67,462 #7 Posted October 14, 2024 Your belt cross section should be the HB as shown below, 21/32", same as a 5L belt 1 Share this post Link to post Share on other sites
Scot 1966 8 #8 Posted October 15, 2024 1 hour ago, 953 nut said: Your belt cross section should be the HB as shown below, 21/32", same as a 5L belt It’s close, but the 21/33” on the flat is .700” 1 1 Share this post Link to post Share on other sites
peter lena 9,949 #9 Posted October 15, 2024 @Scot 1966 would also detail in that idler pulley set up , pulley move smooth / easy quiet ? also related spring tension linkage ? have seen more often than not , related connections with numerius rusty hang up points , KNOCK R LOOSE PENETRANT , pretty serious on rust , then aerosol red grease , extension tube , verify function . BTW every related wide rubber side shield bearing , like on that idler pulley , has been cleaned out and RE GREASED with lucas green chassis grease , movement ease is amazing , hi temp / stress , polyurea rated , imagine no bearing whine / noise , pete Share this post Link to post Share on other sites
Scot 1966 8 #10 Posted October 15, 2024 The slot was worn in the tensioner arm. I welded the oval section, and machined it. It moves freely now, and the pulley turns with ease. My first issue is the 84” belt seems too short, and will not fit under the tensioner pulley. 2 Share this post Link to post Share on other sites
BBQVultureWings 160 #11 Posted October 20, 2024 I found a C-145 for $200 with a snowblade & mowing deck so I am going to get it tomorrow. Did the repair to the tensioner arm fix your problem? Curious as I am about to embark on a new project. I have a 257-H I am also working on. Just put new tires on the rims today. Gonna put a new drive belt on to see how it does. the 257-H has a snowblower attachment so 1 way or another I am moving snow with ease this year.... Share this post Link to post Share on other sites
Scot 1966 8 #12 Posted October 27, 2024 On 10/20/2024 at 12:14 AM, BBQVultureWings said: I found a C-145 for $200 with a snowblade & mowing deck so I am going to get it tomorrow. Did the repair to the tensioner arm fix your problem? Curious as I am about to embark on a new project. I have a 257-H I am also working on. Just put new tires on the rims today. Gonna put a new drive belt on to see how it does. the 257-H has a snowblower attachment so 1 way or another I am moving snow with ease this year.... The repair did not fix the problem. I need to try the Kevlar belt that people are recommending from TSC. I just haven’t had the time lately. If you get a new drive belt, please let me know how it works for you. Share this post Link to post Share on other sites
953 nut 67,462 #13 Posted October 27, 2024 On 10/14/2024 at 8:38 PM, Scot 1966 said: It’s close, but the 21/33” on the flat is .700” The wider belt is not setting down into the "V" far enough, effectively the same as having a shorter belt. Share this post Link to post Share on other sites
Scot 1966 8 #14 Posted October 27, 2024 3 minutes ago, 953 nut said: The wider belt is not setting down into the "V" far enough, effectively the same as having a shorter belt. That’s what I was thinking. I will be trying the TSC Kevlar belt. Thank you! 1 Share this post Link to post Share on other sites
BBQVultureWings 160 #15 Posted October 28, 2024 On 10/27/2024 at 6:32 AM, Scot 1966 said: The repair did not fix the problem. I need to try the Kevlar belt that people are recommending from TSC. I just haven’t had the time lately. If you get a new drive belt, please let me know how it works for you. I am on my way to TSC now to get a belt. I will let ya know as soon as I get it running. I just spent the past hour cleaning All the electrical connections (Battery terminals, Ground connection, starter & Solenoid connections, Bothe ends of the plug wire, the high side of the coil where the plug wire goes in, points & Everything else....) before I even attempt to start it for my first time with this machine. I prefer to get every single thing clean & ready so I don't have to guess later. It most likely needs points as they were baddly corroded but I have gotten lucky before with just cleaning them. I cleaned them with some 220 sand paper & set the gap. Gonna check & lubricate where possible, all my pulleys & everything before I install the belt.It might be a couple days as Wheel Horse fun time is a luxury with all the other stuff needing attention around here. Share this post Link to post Share on other sites
Scot 1966 8 #16 Posted October 29, 2024 Hello all. I received the Max Power Kevlar reinforced belt from TSC today. I’m happy to report it fits perfectly, and stays on as it should! Thank you to everyone who offed suggestions! BBQVW… I was right where you are not long ago. Cleaning all connections, and filing points! Mine had been sitting for quite a while! 1 2 Share this post Link to post Share on other sites
