siebenaler 114 #1 Posted October 11, 2024 Looking to buy the longer bar so I have down pressure what's your thoughts concerned it could damage things doing this. Share this post Link to post Share on other sites
ebinmaine 81,198 #2 Posted October 11, 2024 Just now, Mark siebenaler said: Looking to buy the longer bar so I have down pressure what's your thoughts concerned it could damage things doing this. We've used down pressure to clear snow for several years. It's great it's scraping ice or really hard snow after tires have crushed it down. With a manual lift tractor I'm not so sure you could push hard enough to do much damage. I'd be extremely cautious and very aware about using it on a hydro because it will lift the front end very easily. 3 Share this post Link to post Share on other sites
Handy Don 17,702 #3 Posted October 11, 2024 (edited) 3 hours ago, ebinmaine said: because it will lift the front end very easily. The rear axle bracket is plenty sturdy, but supporting most of the weight of a tractor on the hydraulic lift rock shaft-to-plow frame lift link and then scraping along, well, I would avoid the risk! The C-195 and the GT-14 (and maybe others?) have a float position on their hydraulic control, of course. Edited October 11, 2024 by Handy Don 1 Share this post Link to post Share on other sites
c-series don 12,695 #4 Posted October 12, 2024 I have done it with a hydro for years and have never damaged anything. As long as you don’t operate it like an idiot, you’ll be fine. 1 2 Share this post Link to post Share on other sites
ebinmaine 81,198 #5 Posted October 12, 2024 Just now, c-series don said: I have done it with a hydro for years and have never damaged anything. As long as you don’t operate it like an idiot, you’ll be fine. Wellllll...... I'm out then.... 1 3 Share this post Link to post Share on other sites
oliver2-44 11,836 #6 Posted October 12, 2024 I’ve dug and pushed a fair amount of dirt with my C160 and Dozer blade with down pressure. As Don said just don’t go crazy. The granite gravel clay in my area can be rock hard when dry. But with the right amount of moisture and some finesse is dig-able. 2 Share this post Link to post Share on other sites
kpinnc 19,069 #7 Posted October 12, 2024 (edited) 1 hour ago, ebinmaine said: Wellllll...... I'm out then.... Same… The hydraulic cylinder has a very small diameter ram. It gets around this weakness by lifting implements on the pull stroke. Using down pressure will place all of the stress in the push stroke. Depending on how far out that rod is extended when you hit something solid, it will bend like a plastic straw. Just something to think about. Edited October 12, 2024 by kpinnc 3 Share this post Link to post Share on other sites
953 nut 70,466 #8 Posted October 12, 2024 Any slight change in terrain will result in a rapid loss of steering control if you have down-pressure applied to a grader blade. Many people add weight to the blade itself. 1 Share this post Link to post Share on other sites
ebinmaine 81,198 #9 Posted October 12, 2024 57 minutes ago, 953 nut said: add weight to the blade itself Agreed. That's what I did to my 60 inch WIIIIIIDE plow. Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #10 Posted October 12, 2024 I've got manual lift rigs and wondered about adding a little front weight to the plow as well. How much is a good range to do without over doing it? I know it's more to lift manually but is around 50 pounds a good target? Almost thought of filling a 5 gallon bucket with concrete and using that to put on the plow and maybe another for rear weight on my 2" receiver. Thoughts? 1 Share this post Link to post Share on other sites
ebinmaine 81,198 #11 Posted October 12, 2024 44 minutes ago, OutdoorEnvy said: I've got manual lift rigs and wondered about adding a little front weight to the plow as well. How much is a good range to do without over doing it? I know it's more to lift manually but is around 50 pounds a good target? Almost thought of filling a 5 gallon bucket with concrete and using that to put on the plow and maybe another for rear weight on my 2" receiver. Thoughts? I think you'd be headed the right direction. I would highly advise you make a solid link out of heim joints which will reduce the wear and tear on both the plow frame and the tractors rock shaft. Personally, I'm a huge fan and advocate of fluid filling tires. That puts the weight inside the tire where it should be which has the double benefit of creating traction and not increasing wear and tear on the transmission. 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #12 Posted October 12, 2024 24 minutes ago, ebinmaine said: I would highly advise you make a solid link out of heim joints which will reduce the wear and tear on both the plow frame and the tractors rock shaft. That's a good idea. Any chance you have a pic of that setup? 2 Share this post Link to post Share on other sites
ebinmaine 81,198 #13 Posted October 13, 2024 7 hours ago, OutdoorEnvy said: That's a good idea. Any chance you have a pic of that setup? Thought I did but can't find it. Get a pair of 7/16" male/female tie rods. I use McMaster Carr. Get some matching 7/16" thread rod and jam nuts. 7/16" because the 3/8" holes in the tractor and implement are almost always egged out. Drill that to correct the holes to round. Also because the slightly larger size is exponentially stronger. Male side goes through the tractor and implement. Female side is for attachment using thread rod. Measure the pin-to-pin length of the original Wheelhorse solid link. Cut the thread rod to duplicate that length with the tie rods at or near being bottomed out on the rod. More thread engagement is more strength. 1 Share this post Link to post Share on other sites
Wayne0 1,661 #14 Posted October 13, 2024 22 hours ago, OutdoorEnvy said: I've got manual lift rigs and wondered about adding a little front weight to the plow as well. How much is a good range to do without over doing it? I know it's more to lift manually but is around 50 pounds a good target? Almost thought of filling a 5 gallon bucket with concrete and using that to put on the plow and maybe another for rear weight on my 2" receiver. Thoughts? I attach a 3' piece of rail road track on top of the blade. Plenty heavy. 2 Share this post Link to post Share on other sites
Handy Don 17,702 #15 Posted October 13, 2024 (edited) 19 hours ago, ebinmaine said: exponentially stronger Yep, because the rod’s cross section is equal to πr^2 (pi times the radius squared!) 👍 Edited October 13, 2024 by Handy Don 2 Share this post Link to post Share on other sites
Lee1977 7,811 #17 Posted October 14, 2024 Not sure what you are trying to do. If leveling a lawn it's best to till it first, your not doing to move much hard dirt. Wheel Horse tiller or walk behind. As has been all ready said crushed stone can get hard. I have crusher run stone on my drive it get as hard as pavement. Here is what I used on my drive. I also made a longer clevis hitch and it work much better than the WH clevis hitch with this implement. I built this one, it's a Pulverizer larger ones are used to plant grass with three point tractors. The wench is used not because I couldn't lift it, but it's heavy enough that made it almost imposable to press down the release. The release on manual lift 300, 400, and 500 doesn't go straight down it has a small radius. This post doesn't say anything about "Down Pressure". Just showing something that works. 1 3 Share this post Link to post Share on other sites
peter lena 10,118 #18 Posted October 15, 2024 @Lee1977 totally agree with that center blade mount , much easier all around on function , qnd frame stress , another glairing issue rarely thought of with plowing , is the added stress on front wheel bearings . regular checks of everything , shows something developing . thats your , get after it wake up , pete Share this post Link to post Share on other sites
1988_wheelhorse312 104 #19 Posted 3 hours ago Does the hard link allow float on the manual lift tractors? I have one but I read it doesnt. I have a gravel driveway so I need it to float. 1 Share this post Link to post Share on other sites
ebinmaine 81,198 #20 Posted 3 hours ago Just now, 1988_wheelhorse312 said: Does the hard link allow float on the manual lift tractors? I have one but I read it doesnt. I have a gravel driveway so I need it to float. It does allow float. Float occurs when the lever is not being manually pushed down. The lift lever will go up and down as the ground contour changes. KEEP YOUR HAND CLEAR OF THE AREA BETWEEN THE LIFT LEVER AND STEERING WHEEL. 1 Share this post Link to post Share on other sites
Bar Nuthin 3,555 #21 Posted 3 hours ago 3 minutes ago, 1988_wheelhorse312 said: Does the hard link allow float on the manual lift tractors? I have one but I read it doesnt. I have a gravel driveway so I need it to float. It will float but your lift handle will move along with it. A better solution would be to use chain instead of the solid link. Less abuse on things. 1 Share this post Link to post Share on other sites
1988_wheelhorse312 104 #22 Posted 3 hours ago Just now, ebinmaine said: It does allow float. Float occurs when the lever is not being manually pushed down. The lift lever will go up and down as the ground contour changes. KEEP YOUR HAND CLEAR OF THE AREA BETWEEN THE LIFT LEVER AND STEERING WHEEL. Thanks! I just went through the trouble of taking the hard link out after a grading job. Ill have to use it next year for sure. 1 Share this post Link to post Share on other sites
Handy Don 17,702 #23 Posted 3 hours ago 4 minutes ago, 1988_wheelhorse312 said: Does the hard link allow float on the manual lift tractors? I have one but I read it doesnt. I have a gravel driveway so I need it to float. This is a two year old thread! Yes, manual lift allows float but beware that means the lift arm will be moving! 1 Share this post Link to post Share on other sites
953 nut 70,466 #24 Posted 2 hours ago If you use a short chain or link between the implement lift that a mower deck would be attached to rather than the Rock Shaft the lift handle won't move when floating. Share this post Link to post Share on other sites
1988_wheelhorse312 104 #25 Posted 2 hours ago 1 hour ago, Bar Nuthin said: It will float but your lift handle will move along with it. A better solution would be to use chain instead of the solid link. Less abuse on things. I just swapped over to my chain lift from the hard link. 1 Share this post Link to post Share on other sites
