Wheelhorse newb 0 #1 Posted October 6, 2024 Hello inherited a mid 90s model 520h. Pretty nice shape. There’s a wheelhorse model 260 blower attachment available locally. Done a little bit of online search but not clear if this will fit my tractor or if I’m better off with something else. thanks tom Share this post Link to post Share on other sites
ri702bill 13,189 #2 Posted October 6, 2024 Welcome! Look at the Implement Interchange file under The Implements and Attachments heading..... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #3 Posted October 6, 2024 The 260-Series uses engines with a vertical crankshaft so the pto drive is horizonal. Your pto is vertical. For a single-stage blower you need one of these Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 1 Share this post Link to post Share on other sites
WHX?? 58,302 #4 Posted October 7, 2024 We've had guys before wanting to do this before and while we're sure it can be done with some cutting and fab work we came to the conclusion it would be better off looking for one better suited. for a horizontal shaft tractor. They are common and pop up quite abit in your area. Share this post Link to post Share on other sites
Wheelhorse newb 0 #5 Posted October 7, 2024 Thanks both. Looks like some good options and you are correct, don’t want to fab where no fab is needed. It’s an interesting beast, especially the drive system. Belonged to my now elderly father in law. Attached a pic of it relatively new with him and my wife and two kids. He must have liked the deep dish mag look as he ran it without the rear hub caps Share this post Link to post Share on other sites
