Keaton 466 #1 Posted September 3, 2024 yesterday afternoon I went to get a tractor I guess you could call it off Facebook market, and I got there and went to take a look at it and it was a lot smaller than I thought, it is a 1965 toro professional 58 in cut reel mower, it has 2 bat wing reels in the front, it runs ok, carb leaks and needs rebuild and tank has crap in it, but pretty simple, I had it running for a good 2 minutes playing with the choke. its neat looking and I got pictures of the manual because he had the toro dealer book, he only had one horse a suburban that he would not let go of and a few springfeild type toros, he had over 100 tractors in a barn down the road I have not seen them yet but I want to buy a reel mower a push one he has also. but enough of that I'll get a few pics of it and it has a big crack in the hood. its plastic so we can plastic weld it. and the back wheel folds in for a storage mode I guess, I will add pics after I get home I just have 3 now. 7 2 Share this post Link to post Share on other sites
peter lena 10,071 #2 Posted September 3, 2024 @Keaton looks good to me, lots of steel in that one , might try running that in on a seperate gallon of heavily treated gas . carb bowl is probably loaded with debris . those reel mowers were very stout , get after the , linkage ends , moving mount areas , penetrating oil first , for creeping action , then red aerosol spray grease , extension tube for detailing. neat project , pete 1 Share this post Link to post Share on other sites
Keaton 466 #3 Posted September 3, 2024 Thanks Peter I got a few more pics and a few of it in “storage mode” and the mower ID and the engine ID 5 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #4 Posted September 3, 2024 Suspect Toro uses 58" Professional as a model name. Do you have the model number? Possibly 03100? Share this post Link to post Share on other sites
Keaton 466 #5 Posted September 3, 2024 @gwest_ca I just put the tractor ID tag and engine one it may have not updated on your end yet Share this post Link to post Share on other sites
Joe Shmo 160 #6 Posted September 3, 2024 That is awesome. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #7 Posted September 3, 2024 Can't find anything on the 03100 which is 4hp. Found this on the 03102 which has a larger engine. https://www.partstree.com/models/03102-toro-58-professional-reel-riding-mower-sn-007000001-007999999-1967/ 1 Share this post Link to post Share on other sites
peter lena 10,071 #8 Posted September 3, 2024 @Keaton as stated , noticing , dry cable , rusty connection areas , made a point of that on a number of tractors sold , like waking it up from the dead . those older units were very solidly built , NAPA has a very good chain / cable lube MACS # 1370 , would be perfect on that , like lucas chassis grease , shell rotella oil .30 wt , stay at it , pete Share this post Link to post Share on other sites
C-85 822 #9 Posted September 4, 2024 This is a great machine to have, I guess this is the older version of the zero turn! We sold and maintained several of these '58s', they worked great, hopefully you'll be able to find someone to sharpen it! I'm going to guess that it will be hard to find parts for the Toro part, but the B&S parts should be available. I don't believe this has a carb bowl, and has something like a flow jet carb/tank version (the carb sits right on top of the fuel tank). Back when these were built, they all had the Toro with bullhead logo, which I recently saw on something new I saw, so it was good to see it back! C-85 Share this post Link to post Share on other sites
Keaton 466 #10 Posted September 4, 2024 14 hours ago, peter lena said: NAPA has a very good chain / cable lube MACS # 1370 , would be perfect on that , like lucas chassis grease , shell rotella oil .30 wt I have a good lube and chain lube and I got some of that tacky red greese I will lube it all 15 hours ago, Joe Shmo said: That is awesome. thank you, it is pretty neat 15 hours ago, gwest_ca said: Can't find anything on the 03100 which is 4hp. I cant find anything on it, does not show the model on parts tree either. 12 hours ago, C-85 said: This is a great machine to have, I guess this is the older version of the zero turn! that was my guess alsom I need to change the oil and lube it then I should be good to go try it out. and I'm shure I'll make new friends with a flat file because I want to go buy another reel mower from the same guy that had 2 reel mowers that attach to it. so I got the tank cleaned out last night with solvent and BBs it took 4 tires but I was happy, the carb gas pickup tibe was clogged bad, I got it cleaned and put all back together, and of course my luck the recoil spring broke. and I had another engine that was parts that was all taken apart so I took the spring from that and put it in the toro second try the first time it was not wount up enough, I got it though on my first try unlike my lawn ranger recoil, I took the head off because how bad the inside of the carb was and blew the dirt and crap out, and cleaned under the head, and I did not the patience till wait to Saturday for new gaskets so I made my own, they should do for now. I'll work on it more today and I think my dad is going to plastic weld the hood for me because it was cracked down the middle pretty bad. that's all for now, thanks for the help, -Keaton Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #11 Posted September 4, 2024 Looks like Toro thinks they used a 7-digit serial number Share this post Link to post Share on other sites
Keaton 466 #12 Posted September 4, 2024 @gwest_ca I found the manual and parts list so I have that now I forgot to look on the toro website, dumb of me but after school I plan to get it running Share this post Link to post Share on other sites
Keaton 466 #13 Posted September 5, 2024 I got myself in a pickle again, like always like a bad habit that comes back around I cant ever figure out throttle linkages, I have never been able to, I doubt anyone can really help me on here I may reach out to a few more local small engine shops after tomorrow night if I cannot figure it out. don't have any pictures that are worth a darn so, I gotta to try to figure it out, in the mean time I greesed and lubed the machine and changed oil because it was low and miky last time 1 Share this post Link to post Share on other sites
peter lena 10,071 #14 Posted September 7, 2024 @Keaton like 3-1 orange can penetrating oil , very good on cabling / throttle / choke , take advantage of any higher starting spot , letting it creep on its own , to lower areas , might even add a small extension spring to end point cable hook up , having spring constantly pull toward closure , thats like a power cable pull assist , have that on all my throttle / choke set ups . also love KROIL penetrating oil , pete Share this post Link to post Share on other sites
