Dennis A. Ryan 1 #1 Posted September 1, 2024 I have a 1990s 267 Hydro lawn and garden tractor. It has developed a lot of play in the steering and I can see the steering shaft gear is not firmly meshing into the toothed plate, probably due to wear. I’m afraid it will get to the point that one or the other will strip and I’ll no longer be able to steer it. I’ve lubricated these gears to make steering easier, but wondering if there is a method to adjust one or the other to have them mesh together closer and tighter? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #2 Posted September 1, 2024 In case you do not have it 1 Share this post Link to post Share on other sites
ebinmaine 78,003 #3 Posted September 1, 2024 @PWL216 I know you have a 200 series mower. Any thoughts? Share this post Link to post Share on other sites
rmaynard 17,019 #4 Posted September 1, 2024 I have no experience with your model, but download the section of the manual shown below. It has the procedure for adjusting steering backlash. 1 Share this post Link to post Share on other sites
PWL216 1,148 #5 Posted September 1, 2024 1 hour ago, ebinmaine said: @PWL216 I know you have a 200 series mower. Any thoughts? I never had any issues with the steering, so unfortunately I can’t help here. 1 Share this post Link to post Share on other sites
ROK2024 6 #6 Posted September 2, 2024 I have a 267H, in 2020 I replaced the Lower shaft bushing and pinon gear/steering shaft. The half moon sector gear and upper bushing were pretty good and kept them. Because it has Tilt steering I was able to shortcut to the Service manual instructions and able to R&R the parts after I loosened and lifted the dash without removing it. Mostly out of necessity as I couldn't get the steering wheel off. With some gentle persuasion I separated the shaft from the Tilt U-Joint. I'm looking at some pics and notes and using a few foggy memories to help decipher what I have.. wish I could be more precise. For steering slop check the front axle tie rod bushings too. That's on the to do list. Parts Manual FORM NO. 3318–934 REV. A for Model 72085 SN pg 7900001 & Up (1995) Parts item PN# ⦁ 10 92–6702 1 Shaft–Steering Lower ⦁ 106-8262 SECTOR-GEAR (Replaces 78-2610) 20200219 Order $134.97 item 171552641900) PN 92-6702KIT Toro Steering Kit 106-8262 Sector Gear, 110391 Lower Shaft Bushing, 109189 Upper bearing Lower shaft , 111418 Eccentric Share this post Link to post Share on other sites
ROK2024 6 #7 Posted September 2, 2024 Oh good, I did replace that Sector gear too. Share this post Link to post Share on other sites
