23 Reo 242 #1 Posted July 16, 2024 Are 24x12-12 rear tires too big for a 520H? Share this post Link to post Share on other sites
Pullstart 71,259 #2 Posted July 16, 2024 Stock? Most likely. You may be able to raise the fender however. These are 24x12-12s on my 520Xi for reference. 1 Share this post Link to post Share on other sites
ebinmaine 80,755 #3 Posted July 16, 2024 Depends on the brand of tire and actual measurements. 3 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,381 #5 Posted July 17, 2024 The width of the rear wheel will also affect the tires overall height…narrower wheel means a taller tire once it’s inflated. I think most 520’s have the wider wheels, not sure about the 1988-1989 models though. 3 1 Share this post Link to post Share on other sites
clueless 3,439 #6 Posted July 17, 2024 8 hours ago, Sparky said: The width of the rear wheel will also affect the tires overall height…narrower wheel means a taller tire once it’s inflated. I think most 520’s have the wider wheels, not sure about the 1988-1989 models though. Why do you want the wider tires, for looks? 1 Share this post Link to post Share on other sites
pfrederi 21,163 #7 Posted July 17, 2024 That is the tire size WH used on many D series... they were mounted on 10.5" wide rims C series 7.5" some 520s 8.5" 1 1 Share this post Link to post Share on other sites
23 Reo 242 #8 Posted July 17, 2024 (edited) I just thought they would look good on my 97. I always put bias ply G60s or G50s on the back wheels of my cars in the 70's. Do you think I would be better off staying with the stock size? Edited July 17, 2024 by 23 Reo 3 Share this post Link to post Share on other sites
ebinmaine 80,755 #9 Posted July 17, 2024 20 minutes ago, 23 Reo said: I just thought they would look good on my 97. I always put bias ply G60s or G50s on the back wheels of my cars in the 70's. Do you think I would be better off staying with the stock size? IMHO that depends on your opinion and the desired task of the tractor. Your opinion... because it's an aesthetic issue. Personally I like big wide rear tires. Desired task because wide tires do well on loose aggregate or mud but not great for snow. 2 1 Share this post Link to post Share on other sites
23 Reo 242 #10 Posted July 17, 2024 Thanks Eric, I have dedicated plow tires with chains and wheel weights. Looks like I' m getting the fatties. 2 Share this post Link to post Share on other sites
ebinmaine 80,755 #11 Posted July 17, 2024 Just now, 23 Reo said: Thanks Eric, I have dedicated plow tires with chains and wheel weights. Looks like I' m getting the fatties. Pictures to follow??? Share this post Link to post Share on other sites
Thor27 892 #12 Posted July 17, 2024 24x12-12 airlock. This was a 520 under the black hood & kohler. 3 Share this post Link to post Share on other sites
Thor27 892 #13 Posted July 17, 2024 Those are on a 10" rim, they were hard to stretch that wide, they would be easier to mount on 8.5"s. 1 Share this post Link to post Share on other sites
Thor27 892 #14 Posted July 18, 2024 6 hours ago, pfrederi said: That is the tire size WH used on many D series... they were mounted on 10.5" wide rims C series 7.5" some 520s 8.5" Didn't the Ds with 12s use 26x12-12? Share this post Link to post Share on other sites
JoeM 10,280 #15 Posted July 18, 2024 Put a set of 24 12 12 on 10 inch rims, The rims had a little deeper back-set unlike the shallow ones WH used and I had to put spacers on so the tire did not contact the hydro brake. C141 plenty of room under the fender tho. I would be concerned if using a mower,. gauge wheels might hit the tires. this one is for looking and not cooking. 5 Share this post Link to post Share on other sites
Pullstart 71,259 #16 Posted July 18, 2024 1 hour ago, Thor27 said: Didn't the Ds with 12s use 26x12-12? Good point. I think my Xi has 26’s as well! 1 Share this post Link to post Share on other sites
Monstrosity 1,153 #17 Posted July 19, 2024 (edited) These are 28X12 on 10.5 rims but I made them fit with gt14 rear tins. No spacer and they clear the trailer hitch mount. Edited July 19, 2024 by Monstrosity 2 2 Share this post Link to post Share on other sites
ebinmaine 80,755 #18 Posted July 19, 2024 On 7/17/2024 at 9:30 PM, JoeM said: this one is for looking Interesting color! Any more pics around? Share this post Link to post Share on other sites
JoeM 10,280 #19 Posted July 19, 2024 2 hours ago, ebinmaine said: Any more pics around? 3 Share this post Link to post Share on other sites
