tallen4392 71 #1 Posted June 27, 2024 Does anyone have a clue what this nut and bolt are for does not go to anything ?? Share this post Link to post Share on other sites
lynnmor 8,898 #2 Posted June 28, 2024 They are called transport level stops, it is right there in your owners manual. 1 Share this post Link to post Share on other sites
peter lena 9,942 #3 Posted June 28, 2024 @tallen4392 those R/D decks , as well as others , really benefit from son sun time , break the grunge cycle , clean , oil soak dow , hot sun , also finish season with decks oil soaked , propped up to wall beams , screw eyes , extension spring hold up , detailed go over , for anything , lucas H/D green grease in avery related bearing , no whyining bearing noise , small fine file blade touch up . once you do this , you are a convert , pete Share this post Link to post Share on other sites
Brockport Bill 2,427 #4 Posted June 28, 2024 it regulates the verticle travel distance up and down of the lift assembly carriage -- it would also be obvious if you had the deck off the tractor and grabbed the front horizontal cross bar and lifted it up and down you would see the bolt/nut stop of how the deck floats -- you will note that bolt has a height adjustment in the slot to maximize or minimize the up/down travel -- one of the reason the WH decks give such a nice cut is because it floats -- many other mower decks from other companies are not designed to float the same way and therefore do not cut as evenly on your lawn 1 Share this post Link to post Share on other sites
tallen4392 71 #5 Posted June 28, 2024 Thanks for that great explanation appreciate it .. have a good day 1 Share this post Link to post Share on other sites
quahog 14 #6 Posted July 6, 2024 New to this ; Got a three blade 42 deck that once engaged seems to make a noticeable or pitch change while cutting in !st gear . kind of like a turbo engaged but not on all passes across the lawn I have to assume all 3 blades are always engaged at same speed. Cut is not always level on flat turf? I need help says quahog Share this post Link to post Share on other sites
Rick3478 454 #7 Posted July 6, 2024 1 hour ago, quahog said: New to this ; Got a three blade 42 deck that once engaged seems to make a noticeable or pitch change while cutting in !st gear . kind of like a turbo engaged but not on all passes across the lawn I have to assume all 3 blades are always engaged at same speed. Cut is not always level on flat turf? I need help says quahog Reading between the lines, I'm guessing you are in 1st gear because thick grass. So I'll guess the PTO clutch or drive belt may be slipping under load, may need to be tightened up a tad. Share this post Link to post Share on other sites
