Tucker 701 1 #1 Posted June 25, 2024 I need help I have no clue what I am doing. I have the right wire and a diagram of they it all gose but I am running a different kind of starting with only a key and I dont know where to route the wires so they don't melt.if you have pics of one done please send them to me. Share this post Link to post Share on other sites
953 nut 69,409 #2 Posted June 26, 2024 54 minutes ago, Tucker 701 said: I am running a different kind of starting with only a key A little more information on the switch you are using and type of starter would be helpful. The only wire on a 701 that runs to the front of the engine is the wire to the coil. You can run it with your fuel line under the flywheel cover where it will be out of danger. 1 Share this post Link to post Share on other sites
rmaynard 17,582 #3 Posted June 26, 2024 No solenoid? Share this post Link to post Share on other sites
Achto 32,768 #4 Posted June 26, 2024 One note - you will not be able to use the original 701 starter solenoid. The factory solenoid uses a negative signal to power the magnetic switch. You will need to replace it with a newer solenoid that uses positive power to power up the magnetic switch. 4 Share this post Link to post Share on other sites
Pullstart 71,259 #5 Posted June 26, 2024 There are two ways to handle this successfully. If you are sure you don’t know what you’re doing, I’d suggest keeping to the original wiring diagram and not changing switch styles. 2 Share this post Link to post Share on other sites
Keaton 466 #6 Posted June 26, 2024 I re wired most of my 701 last year when I got it I was 13, someone put a cub cadet solinoid on it and I just color coated the digraham and went off that, it works, but, I just kept the original push button and got a on/off switch from Menards, because the plastic dash on mine was ruined, I put a diamond plate dash on mine, and I just have a 2 prong on.off switch and the original push button, o dont have any pictures of it now, I don't know if this will help any erither, but good luck. Share this post Link to post Share on other sites
Tucker 701 1 #7 Posted June 26, 2024 Ok I kind of wanted to just keep a key switch since it was wired you like that back in the day but got torn apart Share this post Link to post Share on other sites
Tucker 701 1 #8 Posted June 26, 2024 Do you have some pictures of it and where you ran you wires so they don't melt Share this post Link to post Share on other sites
rmaynard 17,582 #9 Posted June 26, 2024 If you are using just a high amperage switch, it will have to be wired with 6 gauge wire. You won't have to worry about that melting. Share this post Link to post Share on other sites
953 nut 69,409 #10 Posted June 27, 2024 6 hours ago, Tucker 701 said: Ok I kind of wanted to just keep a key switch since it was wired you like that back in the day but got torn apart The key switch that came on your 701 just turns the power to the ignition coil on and off. That will work fine as is. On 6/25/2024 at 7:29 PM, Tucker 701 said: I am running a different kind of starting with only a key Are you going to use a newer engine that has a starter rather than a starter/generator or are you just using a modern type solenoid? Share this post Link to post Share on other sites
Tucker 701 1 #11 Posted June 27, 2024 I am keep in all of it original motor and all Share this post Link to post Share on other sites
Tucker 701 1 #12 Posted June 27, 2024 What I meant my melting is like there has to be a wire connection to the ignition coil and I was wondering where to run it so it don't melt. Share this post Link to post Share on other sites
rmaynard 17,582 #13 Posted June 27, 2024 You can run it anywhere that it doesn't directly touch the exhaust pipe or muffler. Most 14 or 16 gauge automotive wires are good to about 300 f. degrees. 1 Share this post Link to post Share on other sites
Tucker 701 1 #14 Posted June 27, 2024 12 hours ago, 953 nut said: The key switch that came on your 701 just turns the power to the ignition coil on and off. That will work fine as is. Are you going to use a newer engine that has a starter rather than a starter/generator or are you just using a modern type solenoid? I think what I will do is just go buy a button and the switch to make it easier and I won't have to guess where stuff goes 1 Share this post Link to post Share on other sites
Tucker 701 1 #15 Posted June 27, 2024 Just now, rmaynard said: You can run it anywhere that it doesn't directly touch the exhaust pipe or muffler. Most 14 or 16 gauge automotive wires are good to about 300 f. degrees. Ok that's what I thought but didn't know Share this post Link to post Share on other sites
953 nut 69,409 #16 Posted June 27, 2024 I would run the fuel hose and the ignition coil wire below the fan shroud on your engine keeping them both out of harms way. Share this post Link to post Share on other sites
rmaynard 17,582 #17 Posted June 27, 2024 (edited) Just my two-cents worth. The 701 wiring is pretty simple as it is. I am not sure that I understand why you want to alter it. Mine has been working perfectly for 63 years. Edited June 27, 2024 by rmaynard Share this post Link to post Share on other sites
Tucker 701 1 #18 Posted June 28, 2024 21 hours ago, rmaynard said: Just my two-cents worth. The 701 wiring is pretty simple as it is. I am not sure that I understand why you want to alter it. Mine has been working perfectly for 63 years. That is the same one I have Share this post Link to post Share on other sites
Tucker 701 1 #19 Posted June 28, 2024 21 hours ago, 953 nut said: I would run the fuel hose and the ignition coil wire below the fan shroud on your engine keeping them both out of harms way. That's what I was going to do Share this post Link to post Share on other sites
Tucker 701 1 #20 Posted June 28, 2024 I ran the wire on the side of the engine but I think I am going to go under the fan shroud just so it don't melt Share this post Link to post Share on other sites
Tucker 701 1 #21 Posted June 29, 2024 I found the starter button part but don't know where to find the other switch Share this post Link to post Share on other sites
