Dlevin 3 #1 Posted June 23, 2024 I recently purchased a 2 stage blower Model # 79361. Price $100. It is missing the chain to drive the auger and The belt bracket that holds the anti sway bracket (included) Is there a source for the chain, and how important is the anti-sway bracket? I can't find a part number for the belt cover bracket. Thanks for any help from the forum. Share this post Link to post Share on other sites
ebinmaine 77,564 #2 Posted June 23, 2024 The chain is a fairly easy thing to find. Just a cut to fit number 40 roller like you'd find on a lot of bikes or motorcycles Etc. Do you have any pictures of the bracket that you are asking about? I think I'm running a two stage without that as well. Here's a video of mine after we replaced the chain last fall. Share this post Link to post Share on other sites
Dlevin 3 #3 Posted June 24, 2024 Thanks for the info on the chain. I can get it on Amazon for a reasonable amount, and cut it to the length I need . I don't see the part on your video. It is a bracket that bolts to the frame and the pulley cover attaches to it, 1 Share this post Link to post Share on other sites
ebinmaine 77,564 #4 Posted June 24, 2024 8 hours ago, Dlevin said: Thanks for the info on the chain. I can get it on Amazon for a reasonable amount, and cut it to the length I need . I don't see the part on your video. It is a bracket that bolts to the frame and the pulley cover attaches to it, I believe I have one on the shelf but didn't install it. @JCM Or @WHX?? You both have Two Stage Tall Chutes. Any thoughts? Share this post Link to post Share on other sites
JCM 10,802 #5 Posted June 24, 2024 @Dlevin Part # 117550-01 guard bracket available and bumper bracket / sway bracket N / A. There are small parts you will need to get that set up. Go on Parts Tree and enter in # 79361. Maybe a member on here would have what you need to save some money. Sway bracket keeps the 2 stage lined up so it doesn't walk side to side when you get into the heavy wet snow and ice at the end of your driveway when the belt starts to wear a groove in your hood. I wouldn't use it without it. JMO. Good Luck 1 1 Share this post Link to post Share on other sites
